12-08-2021, 01:56 AM | #1 |
Rep 305
Ambient lighting. We’re there different options?
My car does have the ambient lighting. However, on the doors, it only lights up the open door handle. I can also change the light color to white or orange. I’ve seen some pics where the plastic strip also had lights underneath. I know there are aftermarket options but I think there was a factory option because the aftermarkets are very bright while the factory one is very dim. I think mine was the first year of the LCI as mine was still labeled 328 instead of 330. Maybe they changed the lights in the later LCI years?
Can anyone confirm? |
12-08-2021, 03:37 AM | #2 | |
Rep 14,108
Drives: G82 M4C X-Drive
There are aftermarket plastic strips that basically catch the light and have it visible. Basically the plastic trim lights up and you will end up seeing a bar of light if that makes sense. Here is it installed in my F80. It's not terribly bright, but it improves the interior a bit.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
12-08-2021, 04:53 AM | #3 | |
Rep 305
jmg18663.00 |
12-08-2021, 09:49 AM | #4 |
Rep 1,788
I have an LCI F32 and the OEM lights aren't very bright either. Those plastic strips help focus the light so it's more visible but brightness remains the same.
If you're interested in changing the colors of your ambient lighting while making it brighter (or just making it brighter) there's a German company that sells replacement LED modules that are super easy to swap out. It provides a different color and white combination instead of amber/white and they also offer the standard amber/white combination. I've bought from the company and done the swap myself and bought the blue/white modules. They were supposed to come out with a replacement module for the LCI radio trim, but I've yet to see it released unfortunately. They're super bright but you can lower the brightness within iDrive of course if you'd like. For the door ambient lighting strips (need 4 of these): https://www.benzinfabrik.com/de/led-...htung-fuer-bmw For the floor board (need 2 of these): https://www.benzinfabrik.com/de/led-...htung-fuer-bmw Check out the thread at the link below for more info and pictures. https://f30.bimmerpost.com/forums/sh...5&postcount=62 Last edited by eff32fl; 12-08-2021 at 11:35 AM.. |
12-08-2021, 03:47 PM | #5 | |
Rep 305
tex26702411.00 |
12-08-2021, 04:15 PM | #6 | ||
Rep 343
Max. The ambient lighting inside the door trim does dim along with the instrument cluster. So if you have your instrument cluster dimmed through the control next to the lights auto/on/off then most likely your ambient lighting is dimmed. |
tex26702411.00 |
12-08-2021, 04:28 PM | #7 | |
Rep 305
My wife got the G20 and I was so jealous of the ambient lighting... lol |
12-08-2021, 04:30 PM | #8 | ||
Rep 14,108
12-08-2021, 05:24 PM | #9 |
Rep 305
The whole thing lights up. But since it’s only a single light source and the strip is only a diffuser, it gets dimmer and dimmer towards the rear. And all 4 doors are like this. It was so dim that I never knew it was there for the whole 5 years I had the car! Hope the aftermarket ones fixes that. Combine with the rip off diffusers from Amazon hopefully can somewhat replicate the G20.
12-08-2021, 05:26 PM | #10 | |
Rep 14,108
12-09-2021, 01:15 PM | #11 |
Rep 1,058
I installed these. They are super bright. Better than the plastic strips. They Work well with the I drive settings. Easy install, just takes some patience. Matches the LCI radio trim as well. I have them set at below 1/2 brightness all the time.
Interior Car Lights, Car LED Strip Light Upgrade 2 Colors Car Door Panel Ambient Light Fit for 3 Series F30 2013-2019 https://www.amazon.com/dp/B08K3HQLD3...6ZQ4E221FPF0RC Install video + brightness.
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
12-14-2021, 12:10 AM | #13 |
Rep 305
Attachment 2764959I got the ones where you can change 9 colors from Aliexpress. Still on its way... but I did get the Amazon plastic strips and they work OK on the stock lights. Hopefully the aftermarkets will really make these pop.
12-15-2021, 08:47 AM | #14 | |
Rep 4,446
Drives: '23 X1 28i xDrive
12-20-2021, 06:42 PM | #15 |
Rep 305
Finally got everything done. It is very involved and at least 8 hours of work but the end result is, well, see for yourself.
It is much brighter than stock. Visible in day time. All controlled through iDrive. Minor coding which is very easy if you’ve coded before. The color displayed in iDrive is wrong though and I’m trying to figure out if I can change the color names... the last color is interesting as it slowly cycles through the spectrum. Together with the $63 Amazon diffusers (collector?), it looks very classy and professional. But god damn it’s a lot of work... total about $250 spent. |
12-20-2021, 06:45 PM | #16 |
Rep 305
Also, what’s great is that it’s on even if you don’t have parking lights on. It turns on when you open the door, and stays on about 30 seconds after you close it.
The kit: https://a.aliexpress.com/_mqxmkP6 The Amazon diffuser: https://www.amazon.com/dp/B07SG65LWJ...p_mob_ap_share |
12-20-2021, 10:05 PM | #18 |
Rep 14,108
Wow that looks pretty good! Any night shots? Any humming while it's on like the other Chinese kits? I wish this was around sooner so I could have enjoyed it with F30 and F80!
12-21-2021, 12:26 AM | #19 |
Rep 305
No humming no noise at all. This is at 1/3 brightness. Full brightness is too bright.. Wife’s car was next to the mine in the garage so couldn’t open the door all the way...
