07-26-2019, 10:51 AM | #23 |
Rep 139
For the AH3, GA8P70H transmission, both BMW and ZF recommend transmission fluid changes at 30-35,000 miles with pan/filter replacement every third change.
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150 2021 RnineT 2022 K1600B |
07-26-2019, 11:01 AM | #24 |
Rep 5,992
Yeah it's risk benefit based on failure rates versus odds of the fluid change itself causing problems within the warranty period. Had this happen on another car that the transmission started slipping not long after a fluid change.
07-26-2019, 07:04 PM | #26 | |
2006 TIME Person Of The Year
9720
Rep 6,445
07-26-2019, 07:58 PM | #27 | ||
Rep 50
They're pretty clear in this link... https://www.zf.com/unitedkingdom/en_...hange_oil.html |
BMWILUVU809.00 |
07-26-2019, 08:11 PM | #29 | |
Rep 3,539
I wonder if he'd run oil that was out of spec for its viscosity in his engine, because my blackstone lab sample showed my transmission fluid had deteriorated outside ZF Lifeguard 8 specs.
upsidedownfunnel1996.00 |
07-26-2019, 10:29 PM | #30 |
9720
Rep 6,445
No. The point I'm making is that transmission fluid service interval IS spelled out. It is a lifetime fill. The point I am NOT making is the wisdom of this prescribed service plan. My pushback is entirely focused on people claiming that the official service interval is anything but lifetime. That is simply the fact for our F30/32 vehicles.
07-27-2019, 06:26 AM | #31 | |
Rep 529
For the Google impaired: podman |
07-27-2019, 10:19 PM | #32 |
Rep 499
I like how, in the video, they say, "Just watch how easy it is".
Uh, OK. Let's see here.... Drain the old fluid, drop the pan (spill oil everywhere), get a whole new pan (special order), acquire super-special (AKA "super expensive") fluid, *FILL THE FLUID FROM UNDERNEATH THE CAR (because that makes sense), USING A PUMP THAT YOU DON'T HAVE*, while car is perfectly level on a lift YOU DON'T HAVE. Then get the car to the right temp range (using specialized software THAT YOU DON'T HAVE), run all the gears, and top-off with the drain open (spilling oil everywhere again). Oh, I'M SORRY -- I MISSED THE "EASY" PART!!! ARE YOU F@#$ SERIOUS?!??? For starters how about giving us a fucking dip-stick and oil-fill location from above the car? Could they MAKE it any harder?!? Last edited by natesi; 07-27-2019 at 10:26 PM.. |
Mr Podman220.50 |
07-28-2019, 05:13 AM | #34 | |
Rep 552
I did a diff swap and used the recommended long life oil. I can't remember but I think the oil life was rated at about 130k miles. So at 60k it probably doesn't need changing. The transmission is a bigger job. |
ASportLineGuy38.50 |
08-02-2019, 04:15 PM | #36 |
Resident Pedant
503
Rep 792
There's no dipstick because then dipstick owners would check it every week and introduce dirt into the system and ruin the transmission.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
08-03-2019, 06:55 AM | #37 | |
9720
Rep 6,445
This is information is not specific to BMW, and directly contraindicated by the specific instructions provided by BMW. You know ZF is a brand that makes different models, right? Again, im not suggesting that you shouldn't service your ZF transmission fluid. I'm not even saying ZF doesn't suggest servicing fluid in their transmissions generally. My point is very easy to grasp... The official service interval for ZF transmissions in BMW vehicles is lifetime. All other information is either fake news, or conjecture derived from information sourced from other vehicles. The official service interval for ZF transmissions in BMW vehicles is lifetime.
08-03-2019, 09:00 AM | #38 | |
Rep 529
Here is what BMW is telling you: The "lifetime" of your transmission ends when it stops working. Here is what ZF is telling you: It is recommended you change your transmission fluid if you want to achieve a long transmission lifetime. See how both are true? See how one is more useful to you than the other? See how one is marketing and the other is maintenance? This summer I bought a brand new pontoon boat directly from the manufacturer. It came with a Honda outboard motor. The pontoon boat manufacturer gave me a set of instructions for how to maintain that Honda outboard. The Honda owners manual also has instructions for how to perform maintenance but many of the maintenance frequencies are different. Question: For my pontoon boat, should I follow the pontoon boat manufacturers instructions or Honda's instructions for performing maintenance on the outboard throughout its "lifetime"? podman Last edited by Mr Podman; 08-03-2019 at 09:12 AM.. |
Phyrexia502.50 |
08-03-2019, 11:07 AM | #39 | |
Rep 1,503
IMHO it’s like a company offering a lifetime warranty on a shirt. Then the fine print says, “lifetime is defined as 60 days”. |
08-03-2019, 03:19 PM | #40 | |
9720
Rep 6,445
Again, I'm not debating the wisdom of this plan, or even the transmission manufacturer's position. I'm only trying to correct the record when people state that BMW's position is anything but. The lead technician at Park Ave BMW told me directly that they haven't done a transmission fluid service "since the 90s."
08-05-2019, 07:00 AM | #41 | |
Rep 529
"The transmission long-term rated fluid does not need to be changed except when necessary during repairs to the transmission." BMW is essentially telling you they won't change your fluid for free. They'll only change it after your transmission breaks. The word "lifetime" doesn't appear in BMW's Service & Warranty document. The exact quote out of ZF's service document says this: "Depending on the driving style, ZF recommends a transmission oil change every 80,000 to 120,000 km or after eight years at the latest." Last edited by Mr Podman; 08-05-2019 at 07:20 AM.. |
08-05-2019, 07:32 AM | #42 | ||
Rep 5,392
I've seen the actual ZF pan/filter combo for sale for $150 vs $300 from BMW. I see various fluids for sale. What should I use? I believe it takes 9 quarts. Thanks! |
08-05-2019, 08:16 AM | #44 | ||
9720
Rep 6,445
Because I can already forsee someone commenting on the wisdom of this plan, I will again reiterate... I'm not recommending any service schedule myself. I'm only working to clarify that BMW has; and their official position is the ZF transmission fluid is not a part that requires maintenance. For whatever reason those promoting rumors suggesting otherwise continue to resist acknowledging this clear reality.
