11-01-2019, 05:45 PM | #1 |
Rep 96
Drives: 2013 BMW 328i xDrive
Stuttering when getting in the throttle?
Driving home from work last week, I was cursing at highway speeds (45-55mph) and I was about to pass someone. The engine was around 2400rpm and I stepped on it a bit to speed up to pass another car. When I did that, the car hesitated a bit and stuttered for a second and then I starting making more power and was able to pass the car in front of me.
(Sport mode, car shifting itself) I wasn't sure what the issue was but it did happen again and I thought perhaps it was an ignition issue. I checked my records and saw it was about time to replace my spark plugs. So I did that with ngk iridium plugs gapped at 0.025 since I am modified w/ higher boost (will list modifications & etc. at the end). After I did that, the issue did not reoccur. Driving home from work yesterday, the same issue happened again. Hoping to get some other thoughts on where I should start looking to resolve this. The car is a 328i xDrive (N20) 8-speed ZF Auto FBO BM3 stg. 2 tune Miles: 86k If anyone has any thoughts, had a similar experience, or could point me in the direction of where I should start looking that would be great! I do all of my own work so I would like to get some thoughts rather than take it BMW or any other shop. If I can go about resolving the issue myself, I'd rather do that. Thanks!
Bootmod3 stg. 2 FBO |
11-02-2019, 04:01 AM | #2 |
Rep 878
Is the hesitation from the engine or the gearbox? My 335i sometimes does this, almost like it forgot what gear or speed the car was doing.
NicksN20F3072.50 |
11-02-2019, 10:35 AM | #3 |
Rep 560
My 335 does this too, on hard throttle, sometimes. Already replaced the LPFP, plugs and coils. Maybe boost leak, maybe bad gas, or could be the HPFP crashing.
11-02-2019, 10:44 AM | #4 |
Rep 96
It definitely seems like it's coming from the engine rather than the gear box. Because right before it stutters, the car picks up just a little bit, stutters, then does what it's suppose to. No cel's or nothing either.
11-02-2019, 10:46 AM | #5 |
Rep 96
Yeah it's inconsistent. It doesn't happen every time but sometimes for sure. Highly doubt it's my gas, could be coils. I hope it isn't HPFP lol
11-02-2019, 05:39 PM | #6 |
Rep 878
I think in my case it’s the gearbox where it’s in too high a gear, it then drops a cog or two and you’re away. Doesn’t happen too often but when it does the ends up lurching forward.
NicksN20F3072.50 |
11-02-2019, 06:26 PM | #7 |
Rep 2,498
Have you ever changed your transmission fliud? If you're modded and driving hard a lot, at 86k miles, it might benefit from a fluid change. Even if BMW claims it's a "lifetime fluid", there's no such thing.
NicksN20F3072.50 |
11-02-2019, 06:32 PM | #8 | |
Rep 96
However I have heard of people changing fluids in these cars, specifically the trans fluid, and that's when problems end up occurring that weren't present before. What's happening with the stuttering isn't making me think there is a problem transmission wise but rather something with the engine. I'll look into though. My thought was that if I take this car to 100k miles, at that point I would change the trans fluid regardless. But maybe it would be wise considering I am modified.
11-02-2019, 06:37 PM | #9 | |
Rep 2,498
11-25-2019, 07:14 PM | #11 |
Rep 96
Update 11/25:
I mean to update before this but I noticed the stuttering more frequently and it felt it was coming from the transmission. After doing some research I thought to believe it was the trans fluid as the symptoms for bad fluid where what I was experiencing. Today I had taken my car to a shop that works primarily on German vehicles to have a transmission fluid change. Mechanic said that the old fluid was dirty and that I should notice a change in performance. Got it back about and hour ago and drove it home. Night and day difference. Stuttering is gone, rough shifts gone, completely smooth now and how it should be. I was leaning against something transmission related because I know how well the ZF transmissions in these cars and many others perform. I also didn't think the fluid needed to be changed because of BMW's claim that it's a "lifetime fluid". I didn't fully believe it to begin with but from other BMW owners experience, they have claimed they've made it to 100k miles before changing. Car is running smooth again and performing waaaay better. I definitely should have done this long before now. Also for anyone else, ZF recommends every 50k miles for a fluid change if I'm not mistaken. One more thing is if you want/ need this done, make sure you say transmission fluid CHANGE and not flush. ZF states that the process of a transmission flush can cause damage. Hope this helps anyone else having a similar experience and shoutout to anyone who said transmission to begin with lol.
05-25-2024, 11:58 PM | #12 |
Rep 5
F30 N20 Experiencing Stuttering when accelerating
Hi guys, I'm new to the forum but not new to the F30. I have a 2012 328i rwd with n20. Recently I have been experiencing some stuttering/slippage when doing hard acceleration.
It is very easy for me to reperform this stuttering when I just press the gas a bit deeper and the car downshifts and starts speeding up around 2k+ rpm. It feels like a misfire that happens for a split second, however no code about misfire or no code at all. I have been doing some datalogs to see what is going on and it seems like the the knocks happen more frequently during the beginning phase of my hard acceleration action. Both forums and mechanic at the shop suggested that it could be bad gas, I filled up a new tank of 91 from Chevron along with techron injector cleaner. The stuttering still happens but not as frequent, this also reflects in the datalog, because now I'm seeing smaller values for the knocks (all under 0.5) comparing to the knocks I had with previous tank of "bad gas" (0.5 and 1 knocks only). The car is 2012 F30 328i rwd N20 with 67000 miles. Kies' turbo inlet pipe and charge pipe and bm3 stage 1 tune. Sparkplugs and coilpacks were replaced months ago so they shouldn't be a problem. I played around with flashing and unflashing the tune on both the tank of "bad gas" and 91 Chevron gas, but the stuttering still happens. I am out of ideas but after researching more, I came up with some possibilities: 1. Air / Vaccum / Boost Leak 2. Bad injector 3. Needs transmission fluid flush for the ZF8. If you guys had similar issues and was able to solve it, reply to this thread as It's really annoying me and I have to drive back to norcal from socal in less than 3 weeks. Link to datalog with "bad gas" https://www.bootmod3.net/log?id=664d...33f04fe73d8b30 Link to datalog with "techron cleaner and Chevron gas" https://www.bootmod3.net/log?id=664d...33f04fe73d8b30 |
