05-23-2024, 06:42 PM | #1 |
Rep 93
Oil cooler not working N55 F30
My F30 335i stage 2+ heats up to as high as 260F and when I add gas a drivetrain malfunction pops up, it doesn't cut power or anything like that just turn the car off delete the error and nothing comes back until the car is warmed up to that temperature again. What bothers me is that I changed the oil cooler to one from ebay because I threw the previous one away after the accident and despite warming the car to these temperatures it remains cold and the hoses that lead to it don't seem to pump oil at all because they are also cold. Below I leave the errors I can't clear 130F20 120408 101F01. The car had a seized camshaft which I repaired also I'm thinking if I just need a better computer to clear the errors because BimmerLink can't handle it but I don't know. I can't sleep at night because of this situation and would be very grateful for any tips
05-23-2024, 06:59 PM | #2 |
Rep 7,733
If you arent circulating oil to the oil cooler then you probably have a problem with the oil t-stat. You can either try to diagnose that or you could try something like the t-stat bypasses that are cheap and easy to install to see if that gets your oil circulating, but then you will probably have the opposite problem that the oil never warms up. Would only do that as a test.
130f20 errors |
