07-18-2018, 02:50 AM | #23 |
Rep 8
Thanks guys.
As I was up near Inverness when the car broke down, I have left it with a mechanic up there. (Reccommend garage from a friend). I am still waiting to hear from them what the damage is....so fingers crossed. In the meantime, I have a 3cyl 1.0l fiesta turbo on hire for the week, and its a fantastic yoke. fast and smooth! Swirl flaps are little butterfly valves within the inlet manifold. I know these were a problem in older model 3 series, but not sure about the F30 series... What happens to the swirl flaps is they can get clogged with gunk, and/or break apart whereby the bits can fall into the cylinder causing major damage. Is there a procedure on how to remove the inlet manifold? And EGR cooler? |
07-19-2018, 03:50 AM | #24 |
Rep 8
Just heard back from the mechanic...
EGR cooler is blocked, which caused the inlet manifold to heat up and melt. New EGR cooler + valve, inlet manifold, MAP sensor & gaskets. £1100 on parts 4.5hours on labour. Going ahead with the fix. Next question is should I sell it? or is it safe to keep.... |
07-21-2018, 12:56 PM | #25 |
Rep 1,808
The N47tu/N57 has swirl flaps, but they are of a different design than on m47/m57. It looks more robust.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 07-21-2018 at 01:02 PM.. |
