09-06-2016, 05:33 PM | #67 | |
Rep 3,128
09-18-2016, 12:41 PM | #69 |
Rep 38
I have a 328i Xdrive. Recently changed to Kelleners sport springs and Bilstein B8. Huge difference and I was really happy with the car until I tracked it yesterday. Way to much body roll in the corners. I never thought I had to change the sway bars too. Looks like another trip to the shop.
2014 BMW F30 328i Xdrive M-sport Alpine White. Wagner IC. Kelleners sport springs and Bilstein B8s.
09-21-2016, 10:02 AM | #70 |
Rep 521
This may not be the right thread, but I don't see a thread for the dinan springs...
I found a lot of posts from people guessing about why there's no sport suspension/lowered options available from the factory on f3x xdrives.. lots of people guessing front CV joints/diff being put out of tolerance by being lowered below stock. What is your stance on the longevity of the front drivetrain components when lowering xdrive? Is there some truth to the suppositions, and you designed your spring set to stay within tolerances, or was it all just ill-informed guessing? I haven't taken delivery of my 340 yet, but the springs and sways will be on my radar if I'm not happy with the m adaptive suspension. |
09-21-2016, 10:11 AM | #71 | |
Rep 3,128
09-21-2016, 11:12 AM | #72 | |
Rep 521
Versipellis130.50 |
01-21-2018, 12:12 PM | #73 |
Rep 357
01-21-2018, 08:51 PM | #74 | |
Rep 3,469
But anyway, the ACS springs worked great, seemed to be engineered well for the car's weight (rather than a one-size-fits all like the H&R and a few other companies). I had shockware done too, which I highly recommend if you are going to increase the spring rate-you have to increase the damping at the same time.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
01-26-2018, 01:17 PM | #75 | |
Rep 682
2017 440i Gran Coupe xDrive MPPSK M-Sport Estoril Blue II w/ Individual Golden Brown Full Merino & Fineline Anthracite Wood
Track Handling + Premium + Cold Weather + Technology + Driver Assistance Packages |
05-25-2018, 02:17 PM | #76 | |
Rep 357
Everything Dinan_Engineering or JamesNoBrakes say in their comments/review is accurate. They were also helpful with spec requirements and instructions.
These work with the Dinan Shockware Adaptive program, installed a year ago. The upgrades eliminate any considerations I may have had towards the 340i, as I exceeded specific cornering benchmarks that I noted when driving 340i M Performance Demos. 340i would also require suspension upgrades. Driving it, I understood the trade-off design philosophy of the OEM springs. Lower spring settings, even 18 mm, is more uncomfortable but multi-fold sporty. Noisier. Drivers uninterested in driving dynamics would find it too connected, too sporty. BMW could have offered a better option, but there may have been no R&D interest in the F3x chassis. At least Dinan did that homework. Yet, clearly, some lessons were incorporated in the 340i, which I suspect mainly Adaptive Flash, a stiffer ZF rack and the rear multi-link change. Yet R&D is not easy- some known brands offer generic products, springs bottoming out or spring rate ill-suited to Adaptive M. For example, although lower, I scrape less the lip in one particular location, as the car does not bounce up or down anymore. So higher, softer BMW OEM spring was worse in that aspect than the lower Dinan. Last edited by Musashi; 05-25-2018 at 02:29 PM.. |
isenc2146.50 |
