05-29-2017, 02:26 AM | #155 |
Rep 598
Let's Try Once Again
Ceramic 6 Pots Calipers with 370mm M Performance Discs? Possible? Anyone DONE? Using these calipers with M Performance 370mm discs on F30 http://cdn3.volusion.com/ofeb6.fdp3x...jpg?1484327020 Cheers |
Jadar1752.50 |
05-29-2017, 11:55 AM | #156 | |
Rep 1,084
rwalker@rwalker.com (I really dislike Private Messaging)
05-30-2017, 05:34 AM | #157 |
Rep 598
01-13-2018, 04:13 PM | #158 | |
Rep 793
01-25-2018, 10:14 AM | #159 |
Rep 127
So if I have a 2017 F31 X-drive with M-sport package, regardless of the packages, I should have the standard X-drive brakes which are the 312mm/300mm right? If the car had the optional M-sport brake package, it would have the 340mm/345mm rotors with the M-sport calipers?
I took a glance at realoem.com So first question is- to upgrade to the M-sport brakes on an X-drive, it seems all you would need would be the rotors, calipers and pads? Is the mounting the same? Second question is, can the M-performance brakes (340mm/345mm) be fitted to the X-drive cars?
2017 330i Wagon | Glacier Silver/Black/Anthracite, M-sport, Nav, Tech, Premium, DA, DA+, Cold, LED's, Carplay
oceanview207.00 |
01-27-2018, 08:50 AM | #160 | |
Rep 348
Since you know how to use Realoem you should do a side-by-side comparison of parts to see if there are any other hardware differences. M-performance = 370/345. Choose your pads wisely. Especially if you have a particular aversion to excessive brake dust. Look at the attached instructions for the M-performance kit for reference. M-performance calipers = Red, Yellow or Orange. M-sport caliper = blue.
02-15-2018, 02:07 PM | #161 | |
Rep 127
02-17-2018, 04:16 AM | #163 |
Rep 603
They are lighter! About 3.5 ounces per rotor
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
03-28-2018, 03:10 PM | #164 |
Rep 2
Hi. I have read all the posts so far, other posts and websites about the brake upgrade. Just one more clarification.
I have 2018 440i LCI that has grey 4 piston front and 1 piston rear setup with 19 inch wheels. If i ever considered upgrading brake, can i do folllowing? Option 1. Upgrade front rotor only to 370mm since the front 4 piston is same as blue m sport brake and leave rear rotor as it is. Option 2. Upgrade rear brake to 2 piston M sport brake and rotor, and upgrade the front rotor only to 370mm. Option 3. Upgrade rear brake to m sport 2 piston brake and rotor and leave front brake as it is. I.e. stock grey 4 piston with 340mm. What would be the most value for money upgrade? Or if all the options arent safe or can't be done, change all of them to msport front and rear? Thanks in advance guys. |
03-28-2018, 03:56 PM | #165 | |
Rep 3,539
The cheapest option for you is to go with your "option 3" of just upgrading the rear caliper and rotor to 345mm/two-pistons. You'll probably still need to code that configuration into the car. Unless you're tracking the car, you're not going to see a difference between the 340 and 370mm front rotors, and there's really not much functional value in upgrading either the front or rear. If you're doing it just for cosmetics, then I'd just upgrade the rear and paint the front caliper (but then again I'd go all the way if it was for cosmetics and get M-Perf rotors and the 370mm front caliper too). |
03-28-2018, 10:30 PM | #166 | |
Rep 2
Thanks for the advice. This clarified my dilemma v. easily!! Thanks. |
03-29-2018, 10:54 AM | #167 |
Rep 2,152
Does anyone know if switching from the 370 m performance calipers to the 340 m sport calipers would create more wheel clearance? My current 370 m performance brakes rub a little on the barrel of my new wheels.
03-29-2018, 11:33 AM | #168 | |
Rep 3,539
You'd also get the benefit of lighter rotors (go with the new ECS ones!). |
03-29-2018, 12:21 PM | #169 |
Rep 2,152
ok i guess second part of my question.. can i use my yellow m performance brakes with a 340 mm front rotor? i'm guessing there might be a different bracket, and i just gotta buy that bracket.
03-29-2018, 12:37 PM | #170 |
Rep 3,539
Nope, since the mounts from the caliper to the hub are built into the caliper itself. There's no intermediate bracket between the hub and caliper like other designs. If you wanted to keep the yellow color you'd have to get a pair of 335/340i base front calipers and paint them the same yellow.
03-29-2018, 01:04 PM | #171 | |
Rep 2,152
03-29-2018, 02:58 PM | #172 |
Rep 3,539
You'll need to find M-Sport brakes from a 328ix, 330i/ix, or a 2-series (328i has smaller rear inner hub than the xDrive, and 335/340 use the 370mm front rotor/caliper on their M-Sport brake kits).
04-24-2018, 03:19 PM | #173 |
Rep 268
I've read all these posts and cant see that anyone has referenced the number stamped on the back of the Brembo four pots. The standard unfinished Brembo 4 pot has 340 stamped on the rear. The majority of the blue Brembo four pot (M sport) also have 340 stamped on the back. Then if you look hard enough there are Brembo blue calipers that have 370 stamped on the back. the radius between the the two mounting holes is clearly larger lending itself to fit a larger disc. From this I question the posts that say the standard grey Brembo and the blue brembos can take a 370mm disc. It would appear you actually need the blue brembo 4 pot that has 370mm stamped on the rear.
You then go into the m performance brakes and M3-M4 370/380mm calipers. |
04-24-2018, 04:00 PM | #174 | |
Rep 3,539
Blue = may or may not depending on if it was a blue caliper from a 328i/30i car (can't take 370/80mm rotor), or 335i/40i car (can take 370/80mm rotor). |
12-02-2018, 10:39 AM | #175 |
Rep 23
Hi
I have a BMW F32 420d Coupe Europe B47 with 19’ inches wheels model 442M with M Sport kit. The original brakes are: Front rotor disk - 312x24mm Rear rotor disk - 300x20mm Last week i bought a second hand m sport calipers but I don’t have the rotors yet. My doubt is if is it possible to install with this calipers the m performance rotors? I’m thinking to buy this parts: 34206797600 - 345x24mm _ rear disks 34106797603 - 370x30mm _front disks Thanks in advance Last edited by Anastomose; 12-02-2018 at 11:29 AM.. |
12-04-2018, 02:56 PM | #176 | |
Rep 603
Just that you know, both of the numbers you have listed are for the dimpled and slotted version (not flat rotor surface). 1. There are two types of front calipers for M Sport brakes. One will fit for the 340mm rotor, one will fit for the 370mm front rotor. So if you have the blue calipers, you need to make sure, for which front rotor size your caliper is made. (If you have a red, yellow or orange caliper, they are only available for 370mm front rotor) 2. 34106797603 would be fine if your calipers are for 370mm rotors 3. Rear rotor: I checked realoem.com and as far as I can see, for the 420d with B47 engine the 345mm rear rotor is 34206797600. (This is important as the emergency brakes are different. If you have the wrong rotor part number, it will not fit to your rear emgergency brake!) The 420d with the N47N engine would need 34206797598 as rear rotor. http://www.realoem.com/bmw/enUS/show...diagId=34_2313 The best would be you ask your dealer to verify the needed parts based on the VIN Code of your car.
