BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > M4 brakes on my F33 (420d SE from 2015) adapters needed?
      09-23-2019, 05:24 PM   #1
fuxshiba
Drives: F33 2015
Unhappy M4 brakes on my F33 (420d SE from 2015) adapters needed?
M4's Brembo brakes on my F33 (420d SE from 2015), apparently custom made adapters needed?
I am new to this, would love some help from the pros out here.
As preparation, I have already upsized my wheels from stock 17" to 19" to fit the M4 brakes which I luckily got from someone who decided to upgrade his brakes of his fairly new M4 (only covered 3000 miles).
I was dumb enough to think they could fit right on, without doing too much research. And clearly they didn't fit. Apparently some custom made adapters are needed.
Any thoughts and recommendation?
Much appreciated.
      09-23-2019, 06:40 PM   #2
teaston
Drives: X3 M40d
The calipers will fit straight on (they are the identical calipers which are in the F3x M Sport brakes) but you need to get 370mm discs to fit. The holes on the M4’s hubs are 10mm further out to allow these calipers to fit the 380mm discs.
      09-23-2019, 06:49 PM   #3
LaNcE01
LaNcE01's Avatar
Drives: freelander 2, 328i,
Originally Posted by teaston View Post
The calipers will fit straight on (they are the identical calipers which are in the F3x M Sport brakes) but you need to get 370mm discs to fit. The holes on the M4ís hubs are 10mm further out to allow these calipers to fit the 380mm discs.
So does that mean that all is required is to get the Fx 370 rotors to install them?
      09-24-2019, 03:37 AM   #4
doncarlyon
Drives: Megane RS 300 Trophy
My eyes hurt looking at those wheels
335dX167.50
TiredGeek268.00
Watsey3866.00
dizzy619428.00
      09-24-2019, 06:03 AM   #5
aquazi
Drives: 18 M4C
Look like BBS LM reps/ style... looked ok with a nice rear dish on the Golfs 10 years ago.. dont really suit the F33
      09-24-2019, 06:06 AM   #6
teaston
Drives: X3 M40d
Correct, best to get TRW or Brembo 2 piece ones from Autodoc or similar.
      09-24-2019, 10:01 AM   #7
fuxshiba
Drives: F33 2015
Thanks, the brake kit I got comes with 370 rear disks and front 380 front disks (very mean looking). Do you think its worth custom making the adapters for calipers to compensate the 10mm? Cheers
      09-24-2019, 10:03 AM   #8
fuxshiba
Drives: F33 2015
Now you hurting my feeling. It was indeed a lot of effort to get hold of these rotiform for my bolt pattern.
      09-24-2019, 12:33 PM   #9
R99
Drives: 2016 330d F31 Touring
The 380mm don't fit - nor do the 370mm rears....
You may as well sell the ///M discs and follow the advice on here to purchase 370mm fronts and 345mm rears.
There is someone I have seen on the FB groups that posted pics of 380mm ///M discs on his F3x but he did not post pics of the mounting solution and seemed to want to keep it guarded - not sure why, but maybe worth looking for the post and asking?
I avoided the problem entirely and had brackets made to fit F10 M5 6pots with 400mm discs!
      09-24-2019, 04:56 PM   #10
fuxshiba
Drives: F33 2015
Such a shame, those M disks seem incredible and in great condition. If no other solutions found I will look into front 370 fronts and 345 rears. Thanks man!
      09-24-2019, 04:59 PM   #11
fuxshiba
Drives: F33 2015
will handbrakes be affected by this modification?
      09-24-2019, 05:24 PM   #12
teaston
Drives: X3 M40d
Thereís different rear 345mm discs, ones for smaller handbrake shoes, and ones for the larger ones.
      09-25-2019, 04:25 AM   #13
doncarlyon
This really is more work than its worth.
IK6SPEED4327.50
      09-25-2019, 01:55 PM   #14
fuxshiba
Drives: F33 2015
So, in my case the blue M4 calipers came with fairly new Textar brake pads for their bigger M4 front and rear disks, would they need to be replaced for smaller pads to suit the smaller 370 front and 345 rear disks? (just trying to budget the whole thing as too many mistakes have already been made.)
Also are M4/M3 brake calipers definitely the same Brembo things as M Performance or M Sport calipers seen on other 3-4 series with M packages, which also have front 4 rear 2 pots, but with different colour variance?
Cheers.
      09-25-2019, 02:57 PM   #15
dizzy619
Drives: F31 340i
I was under the impression that the m4 hubs were needed to fit the m4 full set up...
      09-25-2019, 03:25 PM   #16
teaston
Drives: X3 M40d
Cheers.
Yes absolutely the same pads fit, they are identical calipers, if you look on the back of them they say 370/380 on them.
      09-25-2019, 03:29 PM   #17
Watsey
Drives: F31 330D sDrive M Sport
That's what I'd expect as well, but I may be wrong.
Current : F31 330sD, DMS remap, XHPflashtune, Ohlins Road & Track, Millway Motorsports top mounts, SuperPro poly bushes, Quaife LSD, Stoptech Trophy front BBK / MSport rear discs and calipers, Pagid RSL1 pads all round, Eibach ARBs, Michelin P4S.
      09-26-2019, 10:32 AM   #18
R99
Brake pads are identical between 340mm 370mm and 380mm.
///M are obviously a different compound from factory.
      09-27-2019, 08:34 AM   #19
fuxshiba
Drives: F33 2015
came across this guy on a chinese forum fitting the same M brake kit from an M3 on to his F30 (b48).
He had to cut the brackets in order to mount the custom brackets so the the 380 and 370 ///M discs can be used.
seems hard work.
link to the post: https://www.xcar.com.cn/bbs/viewthre...2133263&page=4
      09-27-2019, 09:32 AM   #20
B58_Touring
B58_Touring's Avatar
Drives: F31 340i
Surely the simplest solution is just to buy the correct discs for your car? Straight forward bolt on upgrade over what you have then. Sell the part worn M discs to offset the cost a little
F31 340i | MPPSK | Bilstein B14 PSS | Michellin PS4s | 405m | 10mm Front 12mm Rear | Custom M Performance V2 wheel
Instagram: @b58_touring
IK6SPEED4327.50
      09-27-2019, 09:50 AM   #21
Eddamoo
Drives: BMW 430dX
Not a chance in hell would I be using fabricated adapters to mount the calipers! Stick with a new set of discs or look at replacing the entire hubs. Hubs shouldn't be expensive, but you have to add M tax which will be undoubtedly astronomical!
IK6SPEED4327.50
      09-27-2019, 09:55 AM   #22
R99
Nothing wrong with using fabricated brackets - lots of calipers are a radial mounted design and use brackets from the factory.....
However, those brackets from China look rather dubious as it appears that the caliper body may have been machined to allow fitment
IK6SPEED4327.50
420d, brembo, f33
