04-18-2021, 03:17 AM | #1 |
Rep 183
Drives: BMW F36 435i FBO
Hi guys!
I would like to have some feedback about my boost spike problem. Stage 2 91 octane Car spec: BMW 435i 2015 48k miles Vrsf IC Vrsf catless Dp Fresh oem bosch plugs And aluminium chargepipe I'll post 3 logs but they are all the same, the boost spikes at low rpm and then it cannot hold boost targets and the wastegate is working very hard at high rpms. Recently changed o-rings on IC and chargepipe but it doesn't helped. I'm going to pressure test also next week Log 1: https://www.bootmod3.net/log?id=6079...729b05a6a061b2 Log 2: https://www.bootmod3.net/log?id=6079...0b43443dbc9256 Log 3: https://www.bootmod3.net/log?id=6079...90c62c0ecf046d All Done in 4th gear dsc off, no throttle clusures |
04-18-2021, 08:58 AM | #2 |
1296
Rep 3,532
havw you checked your diverter valve?
04-18-2021, 09:14 AM | #3 |
Rep 183
04-18-2021, 02:05 PM | #4 |
Rep 7,597
I am really not sure what your concern is? This looks like every other BM3 stage 2 OTS map log - overboost at low RPM then slightly under target at higher RPM. That's basically the way the BM3 maps are designed, they allow boost to exceed target (in most cases, especially right at tip in) without throttle closure. WGDC in the upper 80s/low 90s at high RPM, especially over 6k, seems on par with other logs. So i just don't see a "boost spike problem" unless im missing something.
https://f30.bimmerpost.com/forums/sh....php?t=1732327 |
Elgendyyy0.00 |
04-18-2021, 03:10 PM | #5 | |
Rep 183
If you look at the wgdc almost att revline it bounces alot and I could really feel it in the car. It kinda jerks a little bit after 6k rpm |
