01-13-2018, 07:05 AM | #1 |
Rep 1,162
Guide to retrofitting the 'missing' dimming mirror.
With the build changes that removed the dimming function of the passenger side mirror quite a few have shown a desire to retrofit the dimming function.
I've done a bit of research on this and have performed the retrofit myself using donor parts sourced from a breakers in Germany. This is a guide on how to perform the retrofit yourself. In short there are two components that need replacing to get the dimming function and there is no coding required. The first component is the mirror glass itself. The part number for this is 51167285005. This can be sourced quite easily on ebay (at the time of writing I have a spare as I was unsure if I would be getting the glass from the donor car - yours for £75 delivered). The second part required is the mirror electronics. This is a small sealed computer unit with a number of wires and connectors. There is a power cable and databus cable which go to the mirror/door interface. There is a cable that goes to the indicator repeater, a cable that goes to the mirror fold motor, a cable that goes to the mirror adjust motors, two wires that go to the mirror heat connectors and finally a cable that plugs into the dimming circuit on the mirror. The part number from the donor car is 67137286049 this appears to cost about £30 direct from BMW (however we need a Guinea Pig to try it). As for tooling you will need the following: A trim removal kit to remove the door card and mirror glass. I used this kit from Amazon A Torx T25 screwdriver bit. A Torx T9 screwdriver to dismantle the mirror assembly. A pair of needle nose pliers. A pair of circlip pliers (not essential though - just makes lie easier removing a dust cap). 14mm socket and ratchet. What to do: Firstly remove the door card. I followed an excellent video from our friends at BavSound. You can view it here. Next is to remove the mirror assembly. To do this first release the connectors onto the mirror. These will vary depending on whether or not you have surround view and blind spot detection. These are keyed connectors so you don't need to label them. Next you need to undo the 3 nuts that hold the wing mirror in place using a 14mm socket. Be careful to support the mirror as you do this - it will drop off if you're not careful. Once you have the mirror off you need to remove the glass. The way to do this is to gently prise it using the widest trim removal tool from the centre of the lower edge (ignore any video that suggests doing it from the side with a knife). The glass is very securely clipped in but will come away eventually. Next disconnect the two spade connectors from the heating circuits. Use needle nose pliers so to avoid damaging them. The next step is to dismantle the mirror housing. Please follow the attached pdf file for this. You will need the needle nose pliers and the T9 screwdriver for this. Label up each screw you remove - as there are several different threads / lengths used within the mirror and you'll end up with quite a few at the end. Next remove the mirror electronics again following the pdf attachment. This is a bit fiddly. You should take great care not to damage the exposed pins on the connectors. Wrapping them in masking tape can make it a little easier. Next with the replacement mirror electronics just reverse everything you've done. When putting the mirror back on the car be careful about the weather seal around the mirror so as not to pinch it. I've attached a photo of the mirror electronics that I used showing the part number. I've also attached a copy of the wiring diagram for the mirror electronics for those that are interested. |
Southern Jay539.00 jamojdm15.50 kevinm0356.50 JLR19691882.00 JustChris17489.00 454697819312.50 kingmonkey880.50 AntF32446.50 IanW555484.50 frenchi89.00 john lummis141.50 edmfperez12.50 SirMoo3.00 firehawk61831.50 |
01-13-2018, 07:15 AM | #3 |
Rep 1,162
01-13-2018, 01:59 PM | #4 |
Rep 191
Great how-to! Thank you very much! I just stripped my donor mirror last night and planned to start my research how to do it tonight, you saved me a lot of heartache!
One question, is the door card removal on the F36 identical to the F30/F80 in the video linked above? |
01-13-2018, 02:12 PM | #5 |
Rep 32,881
Bloody ridiculous that BMW removed this, that is penny pinching to the Nth degree!
ar68149.00 kingmonkey880.50 |
01-13-2018, 02:54 PM | #7 |
Occasional Lurker
190
Rep 589
Is this an anti dazzle mirror, or the dip in reverse feature?
Current: F87 M2 Competition
Gone: F36 420D M Sport, F30 Tanzanite M-sport, E90 lci Bluewater M-sport, E90 Le mans M-sport, E46 lci 320d SE Topaz blue, E36 318d Compact Montreal blue, E36 318d Compact Titan silver |
01-13-2018, 04:17 PM | #8 |
Rep 1,643
Drives: 2020 Audi SQ7 & 2019 AM DB11
Location: The Democratic Peoples Republic Of South East England
I ha e been in a brand new uk spec S class merc all week. Top of the range and all the bells and whistles. That to does not have a dimming passenger wing mirror. Is this a safety issue.
01-13-2018, 05:17 PM | #9 | |
Rep 1,162
kevinm0356.50 |
01-13-2018, 05:18 PM | #10 |
Rep 1,162
04-20-2018, 04:03 AM | #11 |
Rep 53
F80 / surround view
Great post!
I was gutted to discover my £60k car was missing this feature. Will this module work with the surround view cameras or is that a seperate connection? Also, I am considering changing both mirrors to F80 if I can get over the cost! The fact that a module within the housing can just be added plug and play suggests to me that if I ordered a pre-LCI set of F80 mirrors then they would come with the correct electronics in anyway... Any help/thoughts much appreciated. Last edited by TufftyUK; 04-20-2018 at 04:09 AM.. Reason: Missing info |
04-20-2018, 07:31 AM | #12 | |
Rep 191
My F36 has surround view and it didn't affect the retrofit. The module has nothing to do with the camera. The camera has its own independent wire going to it. I don't think the change had anything to do with the LCI change. My F36 is pre-LCI (July 2016 build) and it only had the driver's anti-dazzle glass. The change date was late Q1 or early Q2 2016. |
04-20-2018, 12:05 PM | #13 |
Rep 1,338
Drives: 2014 F30 320D X-Drive
I might sound naive bug I thought dimming wing mirror is just mirror glass with some special coating and no electronics needed ?
04-21-2018, 12:56 PM | #16 |
Rep 53
04-21-2018, 12:57 PM | #17 | |
Rep 53
09-16-2018, 07:01 PM | #18 | ||
Rep 53
12-14-2018, 06:26 AM | #20 | |
Rep 148
Source from Germany though at a fraction of the price! Nick |
12-15-2018, 06:17 AM | #22 |
Rep 1,162
In reality the best way to get hold of the bits is either via a breaker or Ebay.
I bought a LHD driver's side mirror off of eBay when I did mine. |
