03-24-2018, 10:13 AM | #1 |
Rep 47
F30 335i all clutch upgrades and retrofits
Has anyone retrofitted a m3/m4 clutch kit on a f30 335i?? Using the stock dual mass?
03-25-2018, 12:03 PM | #2 |
Rep 1,782
Sub'd
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
03-25-2018, 07:27 PM | #3 | |
Rep 196
What I don't understand is how M gets away without misfires from the DMF. After going PS2 I was plagued with misfire until I went SMF. BTW the 550i is a hell of a clutch for the price. |
03-25-2018, 09:03 PM | #4 | ||
Rep 808
03-26-2018, 08:58 AM | #5 | |
Rep 1,499
How is the chatter with the SMFW?
03-26-2018, 02:34 PM | #6 | ||
Rep 196
Obviously it only chatters in neutral with clutch out, for my commute this is a very small fraction of driving time so it doesn't bother me. You can also use the start/stop if going through a ton of red lights.... or turn up radio which will mask it. The noise sucks but eliminating the misfires makes up for it... |
03-27-2018, 02:41 PM | #8 | |
3441
Rep 79,211
The aftermarket clutch kits for E90/E92 335i and 135i also fit the F30 335i, that would likely be the easiest solution.
It's one thing with a regular single mass flywheel where you need to worry about hot spots, glazing and uneven surface wear but the DMFW has that extra piece of internal components to add to the list. Depending on your mileage and abuse, you may want to replace it. Unfortunately like any flywheel, you have to inspect it before anyone would know for sure. The F chassis should be similar to the E chassis which is about a 6 hour install for a proficient mechanic. |
03-27-2018, 04:18 PM | #9 | |
Rep 1,499
Yep I remember the same thing when I installed a SMFW on my e36 M3 #racecar
Using the start-stop function is a good idea. I used to hold my clutch in to prevent the chatter b/c people would look at me like my car was broke, but whatever! Quote:
03-28-2018, 11:42 AM | #10 | |
Rep 196
You may want to change it though, since the clutch is self adjusting to replace flywheel and reuse clutch you'll need to hold it in with a puller. This was scary as hell with all the potential energy... felt like I was diffusing a bomb while handling the pressure plate... |
03-29-2018, 06:44 AM | #11 | |
Rep 1,499
Can you help me understand the link between the PS2 and the misfire with DMFW? I know the DME detects misfire through the crankshaft sensors, but what aspect of the PS2 made the crankshaft do wonky things that the DME translated into a misfire? Have other N55s with PS2 and 6MT experienced the same thing?
03-29-2018, 03:24 PM | #12 | |
Rep 196
Havent been able to get an answer but I wonder when/if the S55 guys need to go SMF. |
03-29-2018, 03:29 PM | #13 | |
Rep 1,499
Gotcha! I was wondering b/c there are several people with PS2 running 450+ WHP but the misfire thing doesn't seem to be widespread.
12-03-2018, 07:47 PM | #14 |
Rep 295
I'm pretty sure the n54 and early n55 used a single crank trigger device, whereas the 2012+ n55 use a dual trigger system. I dm wonder if that would correct those misfires in any way?
12-04-2018, 07:37 AM | #15 |
Rep 1,105
I'm in the process of getting the PS2 for my 435i but have the automatic transmission...is the misfiring only with the manual transmissions??
06-28-2019, 12:31 PM | #16 |
Big Turbo Boys N Girls
327
Rep 579
Yes only manuals and small percent only. Auto's don't have this issue as it uses a Torque Converter.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
07-31-2019, 02:56 PM | #17 |
Rep 252
Drives: 2017 Model S P100D
reviving because I'm 95% sure my clutch is slipping. Pretty sure the CDV caught me one too many times... was previously a honda guy and never had to deal with this (or had extra power from upgrades)
is the 335is/550i clutch 100% compatible? I've gone to a few local shops and they all get scared when I say it is a clutch from a different vehicle and then don't give me a very good quote. i'm thinking it will be this or a spec st2+ clutch. And from what I read might as well replace the flywheel because the springs inside wear down so I'll be getting a new DMFW Any input on either clutch setup would be great |
07-31-2019, 04:06 PM | #19 |
Rep 1,499
DMF or DMFW = dual mass flywheel
SMF = single mass flywheel DME = digital motor electronics. Other manufacturers all it an ECU (Electronic control unit) or ICU (ignition control unit). CDV = clutch delay valve
08-10-2019, 12:38 PM | #20 |
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
will the 550i clutch bolt on to a 2013 f30 335ixdrive?
08-10-2019, 12:59 PM | #21 |
Rep 529
Yes.
Plenty of threads and info available on this forum and on the internet in general that you can easily search for and read for yourself.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
08-14-2019, 12:49 PM | #22 |
Rep 323
with a 2013 bmw F30 335ix 6mt can you just purchase the 335is/550i and bolt it right up with stock flywheel? or do you need to get a different flywheel?
