BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Brakes and Rotors
proTUNING Freaks
      02-10-2024, 09:30 PM   #1
SleeperBMW69
Drives: BMW 430I
Brakes and Rotors
Looking at R1 rotors and pads vs power stop. Looking for any advice
      02-11-2024, 06:25 AM   #2
Tommy D
Drives: '17 BMW 440i GC, 2005 BMW 330i
For your BMW I'd recommend Zimmermann rotors and decent set of pads, such as OEM, Hawk or Akebono. Check out sites like FCPEuro and ECStuning etc.
      02-11-2024, 01:09 PM   #3
SleeperBMW69
Drives: BMW 430I
Thank you
      02-11-2024, 02:36 PM   #4
cfm56d7b
Welcome!
There is a dedicated forum for suspension, brakes questions. Your question will receive more attention there.
Echoing the same recommendation provided earlier.
There are many brake pads options to consider. Some produce less brake dust (usually at the expense of rotor's useful life).
Do you OEM brake pads now?
      02-11-2024, 02:46 PM   #5
SleeperBMW69
Drives: BMW 430I
Yes still on oem pads. I have 96k miles on them and honestly could probably get another 15k out of them. I just wanted a more aggressive brake now that I'm not traveling as much.
      02-11-2024, 04:53 PM   #6
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Don't forget ATE rotors.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      02-11-2024, 04:59 PM   #7
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Stay away from the Hawk 5 pads, they squeal like banshees. No matter how many times I broke them down, cleaned, greased, rinse/repeat they would not quiet down. Switched to Duralast gold pads in the interim and squealing is completely gone.
      02-11-2024, 06:45 PM   #8
WallySlash
WallySlash's Avatar
Drives: 2014 428xi Sport Line
2014 BMW 428xi  [9.00]
FCP Euro for the W.
Zimmermann Rotors and Akebono pads. Pads included the wear sensors.
Replaced the rotor screw with stainless steel version, replaced caliper bolts, and anti rattle clips too.
      02-12-2024, 07:01 AM   #9
Runner340
Runner340's Avatar
369
Drives: F30 340i xDrive
Weird. Are you using the BMW/Brembo dimpled/slotted rotors? I'm on my second year and ~15k miles with the Hawk 5.0 pads on stoptech drilled and directional 345/370mm rotors. No issues with noise.
BMWCCA Member #132862
      02-12-2024, 12:55 PM   #10
XxThe_RemedyXx
967
I'm not. I purchased OEM Zimmerman rotors from FCP when I did my brake/rotor job.
