11-06-2018, 03:44 PM | #23 | ||
Rep 16
Drives: 2015 328i
11-06-2018, 04:20 PM | #24 |
Rep 16,075
The entire point of the cold/warm checks is so the car can warn you that you've got a bulb out when it most matters, during the day, so you can go buy a bulb and replace it before dark.
11-06-2018, 04:39 PM | #25 | |
Rep 153
I also found out this morning that if I turn off daylight running light in settings, and turn the light switch to off, there is no check for my low beams during day time. I stood in front of my car for about 5 minutes with engine running and there was no blinks. |
11-07-2018, 10:21 AM | #26 | |
Rep 153
It works fine without flickers when it is totally dark, or when it is sunny with light off. The issue is during the transition time of dark to sunny. I don't want to worry about flicker during those dark to sunny transition time. So, is this still the best one to use? https://www.amazon.com/gp/aw/d/B06XG...TF8&th=1&psc=1 I think based on reviews, the Bluetooth version still works and wifi version not working anymore? Use it with Bimmercode app, correct? Thanks! Last edited by Pdxway; 11-07-2018 at 10:32 AM.. |
11-09-2018, 02:04 PM | #27 |
Rep 102
I changed my Halogen bulbs to LED as well as my fog lights.
When I first start the car I get a flicker/strobe light effect that I actually don't mind. I'm sure it can be coded to allow the car to not send the signal but I like the flicker. It doesn't bother me. I'm looking to upgrade the DRL bulb and turn signals next.
Silver 2014 328i xDrive AWD // Metallic Black Roof Wrap // Gunnetal 19" VMR v710s // 10 mm Rear Spacers // H&R Springs // MSport Conversion Kit // MPerformance Exhaust // Injen Intake // ER FOB // BM3 Stage 2 93 Oct AGG
11-09-2018, 02:19 PM | #28 | |
Rep 153
During daytime driving when only DRL are on and low beams are off, every minute or so, the low beams would blink due to warm check. The driver in front of you might get confused about getting blinked by you. All you need to check is this: keep the car running with just DLR on, stand in front of your car and observe the low beams for a few minutes. |
11-09-2018, 02:33 PM | #29 | |
Rep 102
I coded off my DRL's. I didn't like the look of the halogen bulb with the LEDs. So I just coded the DRLs off. I'll turn them back on when I get the led bulbs for DRL.
11-09-2018, 10:13 PM | #30 |
Rep 153
I decided to do coding anyway. Bought Vgate iCar Pro Bluetooth 4.0 (BLE) from Amazon and bought Bimmercode app. Able to turn off cold and warm check for the low beams. I turned back on my DRL for daytime driving.
