BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2012 328i Rearview Forward Facing Camera
      05-01-2013, 11:19 AM   #1
myaccount
Drives: 2012 328i
I just noticed that my rearview has a forward facing camera. I have been reading about it and found out that it reads speed signs on the roads and displays the speed limit info on your HUD or onboard computer if you don't have HUD. I don't have HUD, but can't figure out how to get the speed limit info displayed on the onboard computer. Some say that the option is available under Settings/Info Display. But, I don't have Info Display as an option. Any suggestions?
      05-01-2013, 12:19 PM   #2
Frogman
Drives: 2012 F30 328i
Speed limit info is only available if you bought the option. It did not come standard with navigation.
I would have gotten it as it was only a $100 add-on, but it required the $2100 driver assistance package (side cameras and parking assistant) which I didn't want.
It's a shame as I'm sure the navigation database has the speed limit info, but doesn't show it without the camera package to read the signs.
      05-01-2013, 12:21 PM   #3
myaccount
Drives: 2012 328i
ahhh now I understand why I don't see the option. thanks
      05-01-2013, 01:01 PM   #4
claykin
Drives: various BMW
Seems BMW uses the windshield camera only for speed limit info. Camera detects speed signs and a few other road caution signs and displays accordingly on HUD or cluster. Some other manufacturers use a combo of GPS database (mapping) and camera to determine speedlimits. For instance my parents Caddy XTS seems to use both. Where they live the car starts out showing 40MPH limit when they leave their home, but as soon as first sign appears it switches to 35. Seems the mapping database is wrong for that street and the camera corrects. I think BMW waits until it sees a sign. And yes, you need the speed limit info option for this to work.
      05-01-2013, 02:19 PM   #5
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
If i have driver's assistant package does that mean the camera is already there?
      05-01-2013, 02:29 PM   #6
Roki_014
Drives: 2024 i5 M60
but if there is a camera already there can we just have it show the speed limit with codding the car???
      05-01-2013, 02:39 PM   #7
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Camera is used for the Auto High beam too....
SOLD: 2012 335i Mineral Gray
      05-01-2013, 02:46 PM   #8
Roki_014
Drives: 2024 i5 M60
but it seams like everyone gets the cam even if no option?
      05-01-2013, 04:18 PM   #9
Frogman
People have tried coding it with no real success on F10's. Apparently you need an FSC code to enable it.
Also, you may need the KAFAS camera which only comes when you order the driver assistance package. The Xenon light camera may not be sufficient.
For the gory details, see the following:
Pre-requisites:
Drive Assistence package (Lane Departure warning, High Beam Assistence)
What we did so far:
1) 8TH to VO
2) HU_CIC, 3001 EXBOX, SPEEDLIMIT_INFO = aktiv
3) KOMBI, 3000 Anzeige_Konfiguration, SPEED LIMIT GENERATION = sli_gen2
4) KOMBI, 3003 FZG_Ausstattung, SPEED_LIMIT = aktiv
5) KAFAS, 3010 SLI_CODING, SLI_ON_OFF = SLI_ON
6) KAFAS, 3010 SLI_CODING, CODE_ELECTRIC_HORIZON = nicht_aktiv
7) KAFAS, 3010 SLI_CODING, Country_code_display = wert_3
8) KAFAS, 3010 SLI_CODING, UNIT DISPLAY = wert_4
9) KAFAS, 3020 KAFAS_COMMON, COUNTRY_VARIATION = wert_3
10) Turned on Speed Limit Info in the display.
This wil read speed limits once in a while but the speed limit info stays for few seconds only...
enabling CODE_ELECTRIC_HORIZON makes the icon stay permanently but the car stops reading the speed limits. All our cars comes with CEH active whihc gives us a feeling that it must me activ and there are osme other dependent parameters whihc are required to be configured
I don't know if anyone has tried this on an F30 or not.
You'll can start by adding 8TH and maybe 8TD to your VO and then VO code the affected ECU's (HU_CIC, KOMBI, and maybe ICM and FEM_BODY).
      05-01-2013, 04:22 PM   #10
Frogman
Since you have this package, you probably do. Do you have a KAFAS ECU in your SVT list?
Do you have 8TH and/or 8TD in your VO?
I still think (based on the previously referenced thread) that even if you have the KAFAS camera, you will need to find someone to provide you with an FSC code to enable SLI.
      05-01-2013, 06:20 PM   #11
claykin
Drives: various BMW
KAFAS camera is only installed in vehicle if you have lane departure warning and/or speed limit info.
      05-01-2013, 06:38 PM   #12
tdizzle
Drives: 2017 F80 ZCP
Pretty sure that's the only option that I don't have on my car. Fail!
      05-01-2013, 08:54 PM   #13
claykin
Drives: various BMW
Let it go. Not such a big loss.
      05-02-2013, 12:56 AM   #14
UhhItsANT
no clue... I'll plug up my car and check it out... what is the "8TH and/or 8TD in your VO" you mention. How do i find out?
      05-02-2013, 04:50 PM   #15
Frogman
You can check on bmwvin or by expanding your FA, expand the SALAPA elements to list the option codes on your car.
8TH and 8TD are the speed limit option codes. But, if you don't have SLI, then you won't have these.
Again, this is mostly moot as you would need an FSC code to enable SLI anyway.
      05-02-2013, 04:59 PM   #16
UhhItsANT
8TH and 8TD are the speed limit option codes. But, if you don't SLI, then you won't have these.
what is SLI?
      05-02-2013, 05:19 PM   #17
Frogman
what is SLI?
SLI = Speed Limit Info
      05-03-2013, 12:22 AM   #18
dbpe
Drives: 2019 X3 M40i
If you have the option, the camera not only reads the speed limit signs (and it is extremely accurate!) but also is the basis of the lane divergence system. It reads the lane stripes and gives steering wheel feedback if you stray from your lane (also very accurate).
2019 X3 M40i Black Saphire Metallic/Black w/Blue stitching
2018 X5 50i MSport Alpine White/Espresso
      05-03-2013, 07:24 PM   #19
EdDuran
EdDuran's Avatar
Drives: 2014 328xd M-Sport
2014 328xd  [0.00]
DVR?
What is the possibility that the forward facing camera can record video, say the last 15-30 minutes, should you ever need evidence of an accident, etc.. I read the new nav system will have a 200Gig drive which would be perfect for this /ed
      05-10-2013, 05:03 PM   #20
EdDuran
EdDuran's Avatar
2014 328xd  [0.00]
bump
