BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Groove in FR rotor
      06-17-2021, 09:38 PM   #1
435MSport6Speed
435MSport6Speed's Avatar
408
Drives: 435i M Sport 6 Speed
Groove in FR rotor
11,000 on brakes. No noise or vibration. Anyone have an idea of what's going on?
Thanks for the help.
14 435i M Sport 6 speed, MG/Coral, MusicarNW Stage 3+ Upgrade for HK, M Brakes, MPPK, MPE, M Rear Spoiler, M Side Molding, full Expel wrap
      06-17-2021, 10:50 PM   #2
Logicoeur
Logicoeur's Avatar
739
Drives: F30 335i xDrive
Debris took a trip between the pad and rotor.
F30 335iX | Remus Axleback Circuitwerks Catted DP | 18X9 ET32 19lb TR-1 | 255/40/18 ECS | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter
      06-18-2021, 07:32 AM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
That. Don't worry about it, it's not wide enough to create any problem. If you had a bunch of them then you'd want to resurface the rotor, and replace the pad if it was scored as well. Whatever you did to one side you'd do to the other as well, to keep them the same.
      06-18-2021, 10:15 AM   #4
435MSport6Speed
408
Thanks Bill
      06-18-2021, 11:23 AM   #5
cfm56d7b
435MSport6Speed, what brake pads does your vehicle have? OEM or aftermarket?
      06-18-2021, 11:38 AM   #6
435MSport6Speed
408
OEM. Blue caliper M brakes.
      06-18-2021, 12:03 PM   #7
cfm56d7b
Thanks for confirming. OEM pads are softer by design to preserve rotor life. It's most likely road debris.
I haven't seen road debris getting trapped between the pad and the rotor.
On a rare chance that brake pad has been tapered for some reason - in other words uneven pressure resulting in one corner having a slight gap - it's worthwhile to inspect the brake pad when you have a chance.
      06-19-2021, 10:41 AM   #8
casualDIYer
Drives: 340i xDrive M Sport
Whatever you got got in there must have been pretty durable to cut a little line in the rotor. As bill mentioned, I wouldn't worry about.
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
