10-17-2021, 04:29 PM | #1 |
Rep 112
Best intake combo?
I ended up ordering an upper silicone inlet pipe as well as an afm drop in. From what I'm reading, keeping the stock box is good, and the drop in adds some responsiveness and noise. I'm addition, I figured for the low price that I would do the silicone upper inlet pipe (which deletes the resonator). Is this the "best" intake combo for these b58's (stock turbo). In addition, do the lower turbo inlet pipes prove to be effective? Thanks
10-17-2021, 09:27 PM | #2 | |
Rep 5,391
10-18-2021, 04:15 AM | #3 |
Rep 3,860
<5% ?
Rather <1%. And potentially increase engine wear due to compromised filtering. Not sure why people do that (other than for sound/noise and unless heavily tuned / bigger turbo, etc.).
10-18-2021, 05:15 AM | #4 |
Rep 112
I have often heard that is the case with intake systems rather than drop ins.
10-18-2021, 05:27 AM | #5 |
Rep 3,860
Let's put it like this - the stock air-filter and inlet of the B58 is established to be adequate for up to about 500PS-550PS.... just a reference figure but indicative.
Why improve something which needs no improvement.
10-18-2021, 06:40 AM | #6 |
Rep 112
I figure it would be a good supporting mod for when I run e30 and tu pump in the near future. I have seen some testing results showing that the drop in provides a slight bit of power and torque against the OEM, whereas the aftermarket intake systems actually cause timing to be pulled and result in lower power and torque numbers.
10-18-2021, 06:53 AM | #7 |
Rep 3,860
Consider potentially increased engine wear.
The only way to allow more air in without increasing the filter area itself is to filter less.... Filtering less, means more (bigger) particles going in to the turbo/engine. For 3PS more... no thanks.
10-18-2021, 07:41 AM | #8 |
Rep 1,597
Considering that BMW MPPSK decided not to upgrade the stock intake, I think it would be safe to say the stock intake with the excellent particulate filter is adequate as you say at least up through 370 hp or so with minimal gains on filter mods.
10-18-2021, 08:35 AM | #9 |
Rep 112
Do you think then maybe (since b58 filter is adequate) installing an upper intake silicone pipe (resonator delete) may be the best solution then? It is after the filter and can allow for smoother and more airflow. Plus you'll get some intake notice I presume.
10-18-2021, 09:12 AM | #10 |
Rep 3,860
Depends on what you are hoping to achieve…
I personally think you should be looking at changes/upgrades of the exhaust system for both performance and sound, and not the intake. You get much more of both through exhaust changes. I wouldn't touch the stock intake (at least not unless you go for bigger turbo, etc). But that's just me.
10-18-2021, 09:20 AM | #11 | |
Rep 112
I actually am catless with MPE as it is. BM3 Stage 2 |
10-20-2021, 03:56 PM | #12 |
Novice
300
Rep 693
I would go with the MST closed box intake as it will be shielded from the heat produced by the turbo and may provide protection against any particles in the air but who knows.
10-21-2021, 10:31 AM | #13 |
Rep 190,632
Open intakes will add 5-10 whp on a stock turbo non-tuned car. The main difference between the brands is sound. Injen, BMS and VR are the most popular
If you are not looking for a loud intake, get the MST Dyno w/ BMS intake
10-21-2021, 11:39 AM | #14 |
Rep 3,860
5-10 WHP are in reality within the tolerance and repeatability of a dyno/engine.
Unless this is the averaged result of e.g. 10 measurements pre-mod and post-mod under the same environmental conditions. I wouldn't bother still, given the potentially increased wear. But that's just me.
10-24-2021, 04:45 PM | #15 | |
Novice
300
Rep 693
10-24-2021, 07:30 PM | #16 |
Rep 148
At this point I am convinced open air intakes are unwanted in the long term. Higher IATs (how does that translate to turbo output heat?), 40-50% less filtering in of particles in some cases [1] (bad things getting into your turbo & engine). It doesn't affect emissions, as far as I can tell. Thus, to me, if open air intakes were positive, OEM standard would've been high flow from the start. I'm not saying the DYNO won't show a positive net gain at high RPM (not low), I don't know the affect of this over time. I have to err on the side of caution and say it's negative over time (long period not just a dyno session). I will say that K&N filter acceleration in the study linked showed 5.87s K&N vs 5.99 stock OEM. I didn't see the goal/threshold for speed; but to me, not worth it unless you really like the wooosh. Make an educated decision with the data.
Although, I do love the WOOOSH sound from open air intakes... 1- https://www.sciencedirect.com/scienc...01475-main.pdf Last edited by vektorprime; 10-24-2021 at 08:20 PM.. |
Skyhigh1879.00 |
10-24-2021, 09:47 PM | #17 |
Rep 1,452
You get an intake for the turbo noises.
2022 CT4-V Blackwing 6-speed
10-25-2021, 12:58 AM | #18 |
Rep 3,860
Isn't that a 1990's thing?
Just saying… it's 2021… everyone has at least one turbo… incl. the 1.2 litre engines.
10-25-2021, 02:32 AM | #19 |
Rep 1,452
True. But the sound is muted from factory, especially on economy cars. I like hearing the turbo spool and intake noises, as do other people. Just different preferences, that's all.
Skyhigh1879.00 |
10-25-2021, 10:00 AM | #21 | |
Rep 4,871
Has there been a study that actually shows the difference in filtration? Sure, using an cotton filter like a K&N does have lower pore size vs paper, but you don't run it dry, you oil it. So there is a 2-stage effect going on there with dust being attracted to the oil. Oiled foam filters (much large pore size) were used in engines (including lawn mowers) for years with no ill effects. With that study, they did use tissue paper around the filter. What happens when that gets oily and seals the filter more? Obviously really hard to saturate both with dust equally for a true scientific test. |
10-25-2021, 11:12 AM | #22 |
Rep 3,860
There is not a single third party filter manufacturer (reputable or not) that has published a study or test result comparing the filtration efficiency in comparison to a stock filter (that I know of!)….. that alone should tell you enough
The answers are almost always in what's not written rather than in what's written
