11-23-2021, 09:51 AM | #16039 |
Rep 40,765
PM sent.
11-25-2021, 11:22 AM | #16041 |
Rep 40,765
Your Receive PM function is disabled. PM me when working.
11-29-2021, 03:29 AM | #16042 |
Rep 5
Hi guys,
I am new to Esys coding. I used NCS expert for E series, but planning to buy G31 and I want to have same ability to do small changes. 1) I have problem with Launcher. I have MAC and I virtualise WIN1903 via parallels. E-Sys_Setup-3.27.1_RC_b44813 E-Sys Launcher PRO 2.8.2_Build_162b BFU Edition ESysLauncherPremiumSetup_2.8.2_Build_155 PSDZDATA 4.27.22 I did all installation but when I run Launcher Preminum, it did not start at all. I figured ou that for virtualisation I need Launcher PRO. All is good until providing password and activating. App falls down and when I want to open activation window again it falls down. Do you have any clue what could be the issue? I have installed JAVA 8, C++ version 2010 x86/64, WIN 20H2 and nothing helped. I have read that there is version 3.x to use, but TM has disappeared and don't know how to activate it. 2) does any of you any have cheat sheet for G31? 3) if I mess anything with car. Will I be able to return back with backed up ECUs? 4) If I talk only about coding ECUs, is Bimmercode good alternative with same options (especially expert mode)? Thank you for any help. Michal |
11-29-2021, 01:22 PM | #16043 | |
Rep 40,765
Cheat Codes are built into E-Sys Launcher. I can't comment on "mess anything with car". That would depend on what if anything got messed up. Generally speaking, if just coding, it can always be set back to factory just by VO Coding. I also can't comment on Bimmercode. I don't use it myself.
11-30-2021, 04:23 AM | #16044 | |
Rep 5
OK, I will have to use my wife's laptop Just to confirm - to fix via VO coding you mean remove VO and add it back. right? for that I need full version od PSDZData, don't I? What version of Esys and Launcher would you recommend? Thank you. Michal |
11-30-2021, 07:05 AM | #16045 | |
Rep 40,765
11-30-2021, 09:45 AM | #16046 |
Rep 5
11-30-2021, 10:56 PM | #16047 |
Rep 4
Hi Shawn -- would you mind sending me the most current Esys and psdzdata info? I have an F30 that I'd like to code.
Using what I've found around the web seems to tell me that 3.27.1 is the "best" version to use, but that with a newer psdzdata results in an error in KisAlAdapater "Unsupported major.minor version 52.0", which I guess means that was compiled against Java 8 and we depend on Java 7 for Esys 3.27.1. **Update** The above error is the result of running Esys Launcher in a VM. There are published workarounds that require using VMware (not VirtualBox) and editing the .vmx file for your VM. In a VM, Esys is a bit slow and requires slightly more effort to get functioning, so it's recommended not to use a VM unless you are pretty comfortable with what that may entail. Last edited by AriZoNaiCe; 12-05-2021 at 03:03 PM.. |
11-30-2021, 10:59 PM | #16048 | |
Rep 40,765
AriZoNaiCe0.00 |
12-02-2021, 09:07 PM | #16050 |
Rep 40,765
Depends on car.
12-05-2021, 02:40 PM | #16051 | |
Rep 4
This is also true if using a VM, in which case you need to disable the default Firewall on *BOTH* the Host machine and the VM. Thanks to Shawn and the entire community -- hugely helpful! |
12-05-2021, 02:48 PM | #16052 | |
Rep 40,765
12-08-2021, 04:10 PM | #16053 |
Rep 21
Drives: 2019 430i Convertible
Hi Shawn,
Could I also get the latest E-Sys package? My car is a 2019 F33 if that makes a difference. Thanks! |
12-08-2021, 04:12 PM | #16054 |
Rep 40,765
PM sent.
mmmm_beer4.50 |
12-12-2021, 06:46 PM | #16055 |
Rep 13
Hi everyone,
I have a F30 340i on which I have used e-sys to do coding. I would like to code to deactivate "IHKA - Recirculation Function Changes from Manual to Automatic", as I prefer to keep air recirculation permenantly ON when I toggle Manual. I was reading official dealer service bulletins such as the below: https://testing-public.carmd.com/Tsb...0B64%2005%2015 https://static.nhtsa.gov/odi/tsbs/20...48058-9999.pdf In which they used ISTA-P to alter the IHKA function Is there a way to do the same using e-sys? Many thanks! |
12-12-2021, 06:58 PM | #16056 | |
Rep 40,765
12-12-2021, 07:31 PM | #16057 |
Rep 13
Thanks Shawn!
Regarding your advice, "Add HO-Wort "DAUE" to FA and VO Code IHKA" I will look up what it means! I saw another forum post which suggested the following changes under IHKA module: mist avoidance BESCHLAGSVERMEIDUNG = NICHT AKTIV auto recirculation off UMLUFT AUTO AUS = NICHT AKTIV HEIEN IN UMLUFT = AKTIV Not sure if anyone has had experience with the above, and whether they work to keep Manual mode cabin air recirculation to stay on |
12-12-2021, 07:39 PM | #16058 | |
Rep 40,765
Per SI B64 05 15 Heating and Air Conditioning you attached: Perform a conversion with ISTA/P "Deactivation of the automatic air recirculation control". ... The final report shows the VO modified with K-Word "DAUE". The air recirculation button will function in manual mode only.
12-13-2021, 09:12 AM | #16060 |
Rep 40,765
PM sent.
