09-01-2021, 07:56 AM | #1 |
Rep 66
Could JB4 Map 1 cause DME 118602/P2096?
I have a '15 435i that has sporadically given me DME 118602/P2096 - Oxygen sensor before catalytic convertor fine mixture control, exhaust gas after converter too lean.
I understand this could be attributable to several things...more air in the system or a bad O2 sensor. Here's the thing - it only comes on when I have JB4 Map 1 turned on. Additionally, it takes a really really really long time for it to come on, like months after switching to the map. It takes so long that I forget about it until one day it pops up. The first time this happened, I cleared the code and switched to JB4 Map 0...the code never came back in over a year. Then I installed the MPE and was playing around with the exhaust flap settings and decided to turn Map 1 on again. That was several months ago...and then the code came back yesterday. Would there be something in the Map 1 tune that could be causing this condition? If I came back within a few months with the Map 1 off - I'd consider starting to poke around to check for any air leaks..but its just fine with Map 1 off, so its got me confused. I have a chargepipe and upgraded intercooler - but other than everything is stock. Car drives fine with or without the CEL on. Thanks! Last edited by Crispykickz; 09-01-2021 at 08:01 AM.. Reason: edit title |
09-01-2021, 10:02 AM | #2 | |
1296
Rep 3,533
contact burgertuning and they will help you out.
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
