11-13-2018, 06:57 PM | #24 |
Rep 64
01-20-2019, 12:27 PM | #25 |
Rep 16
Setting up a 435i Xdrive for drifting (not my idea). Working out the complications.
1. Was just going to pull fuse #32 but this sounds better 2. They pulled the rear ABS sensors to install hand-brake calipers, have to take signal from front or disable DSC and ABS completely 3. installed a manual trans so coding that auto out tomorrow I hope Very open to good ideas. Somewhat open to other ideas too |
01-20-2019, 12:57 PM | #26 |
Rep 1,934
There's a mobile app, xHP Flash tool that will be able to do this for us. It's new release date is tomorrow, Monday. It was pushed back from sometime in December. It's already being used in the E9x.
Edit: it's a completely different app from the same company. xDelete is the application.
01-21-2019, 10:34 AM | #27 |
Rep 2,671
01-21-2019, 02:04 PM | #28 |
Rep 16
Thanks for that link. I had not found that one yet. We'll see if I can:
1. code it like a non-xdrive (so no dsc/abs lights) 2. mirror the front ABS sensor signals for the back 3. auto to manual coding 4. default dsc/abs off Gunna be interesting |
TK335iMSPT299.00 |
02-24-2019, 11:33 AM | #30 |
Rep 15
02-24-2019, 12:11 PM | #31 | |
Rep 1,934
10-19-2019, 12:50 AM | #32 | ||
Rep 68
10-23-2019, 10:52 AM | #33 |
IG: AndrewRodriiguez_
86
Rep 281
Drives: 2013 335i x Drive Sport 6M/T
Garage List 2013 BMW 335xi [0.00]
2002 Lexus IS300 [0.00] 2004 Subaru WRX (SOLD) [0.00] 2010 Honda Civic Si ... [0.00] |
I'm subscribed to Bryan_KiesMotorsports on Youtube and he posted this a couple weeks ago. All info in description on the video.
[COLOR="Black"]M4 Style Spoiler, M Style Black Kidney Grills, ER CP, VRSF DP, MPE, BMC Drop-In Oiled Filter tuned by RK-Tunes. BC Racing Coilovers
10-29-2019, 05:58 PM | #34 |
Rep 716
Drives: BMW M3 xDrive
18' 340i XDrive
Does pulling the fuse still work on a 2018 340i xdrive??? If so will I have problems like the car being stuck in limp mode or will I just have little light in the dash on?
12-04-2019, 07:45 PM | #35 |
Rep 146
Just code the car, much better than pulling the fuse. DSC > C_Funktion_LaengsMomentVerteilung_aktiv_e > aktiv change to nicht_aktiv. You have to change VCM so DSC has a build code for a non-xDrive.
01-29-2020, 12:00 AM | #36 |
Rep 1
Do you have a VCM build code for a non xdrive that will work for my F31 sportwagon 328D? I’m tired of seeing the Chasis Stabilization warning light on all the time.
02-29-2020, 09:36 AM | #37 |
Rep 13
it should be doable by manipulating only the software via FDL coding
comparison between s28i and x28i US version. No other car optionals have been taken in consideration(like Hill descent control etc). An example for my F25 but it should be the same for F1x/3x/4x/etc XDRIVE DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Cp_Hinterachse = initwert [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Cp_Vorderachse = initwert [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_HillDescentControl_aktiv_I = aktiv_mph DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_LaengsMomentVerteilung_aktiv_e = Allrad [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_OHB_BFS_aktiv_I = inaktiv [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_OHB_BPS_aktiv_I = inaktiv [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Variante_Antrieb_e = Allrad [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Variante_Karosserie_e = F25_Basis DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Variante_Motor_e = Wert_01 DXC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_BBV_Korrekturfaktor_HA_c = Wert_03 [Default] DXC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_BBV_Korrekturfaktor_VA_c = Wert_03 [Default] DXC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_GMR_Uebersteuer_0_c = 4WD DXC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_GMR_Uebersteuer_1_2_c = 4WD SDRIVE DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_AllradAktuator_Schutzfunktion = inaktiv DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Cp_Hinterachse = initwert [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Cp_Vorderachse = initwert [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_HillDescentControl_aktiv_I = nicht aktiv [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_LaengsMomentVerteilung_aktiv_e = Heck DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_OHB_BFS_aktiv_I = inaktiv [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_OHB_BPS_aktiv_I = inaktiv [Default] DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Variante_Antrieb_e = Heck DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Variante_Karosserie_e = F25_Basis DXC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Variante_Motor_e = Wert_06 DXC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_BBV_Korrekturfaktor_HA_c = Wert_03 [Default] DXC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_BBV_Korrekturfaktor_VA_c = Wert_03 [Default] DXC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_GMR_Uebersteuer_0_c = 2WD DXC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_GMR_Uebersteuer_1_2_c = 2WD |
08-08-2021, 04:44 PM | #38 |
Rep 17
I know this is quite old topic but have anyone managed to change car production model so car is not giving DSC errors ? I'm also getting ABS error, still haven't tested if ABS still working even error comes.
08-09-2021, 02:01 PM | #39 |
Rep 17
09-09-2021, 11:29 AM | #40 |
Rep 4
Sending out the driveshaft for servicing, so will try the fuse trick to see if the car can be driven at all or if this is all a cruel joke. Hoping it's real!
