09-10-2021, 09:54 AM | #45 |
New BMW owner
325
Rep 842
what about the AA—300?
2018 BMW M2 LCI BM3 Stage 2 + MPE + FTP charge pipe + MST V2 Inlet + TurboSmart DV + CSF FMIC + AA Hi-flow Downpipe + Turner Rear Shifter Bushing + Wiechers Strut Brace + Bilstein B16 PSS10 + Apex VS-5RS
09-10-2021, 03:21 PM | #46 |
Rep 7,602
The AA is a GESI cat and its 400. https://store.activeautowerke.com/pr...atted-downpipe
Also, im pretty sure stock is WAY higher than 300 per section (meaning before and after the 2nd O2). I dont have a source onhand, but you can see when you compare it side by side with any other aftermarket one as i did with my fabspeed. |
09-11-2021, 05:27 AM | #47 |
New BMW owner
325
Rep 842
i wonder how AA's 400 count performs against the Fab's 200.
09-11-2021, 02:14 PM | #48 |
Rep 7,602
11-18-2021, 09:42 AM | #50 |
Rep 881
I have similar Q to the above. I’m n55 EWG Xdrive (435iX GC), and I don’t see either the AA or Fabspeed ‘no CEL’ DPs being available for my car? So N55 Xdrive has no great catted DP option?
11-18-2021, 11:22 AM | #51 |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
Both will fit. Xdrive doesn't effect the fitment. I have the Fabspeed downpipe and it fits fine.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
visionaut1305.50 |
11-18-2021, 12:31 PM | #52 | |
Rep 881
It’s just very odd that neither mentions Xdrive when they list all the compatible models for these DPs, and in fact remove the DP as an available part when you do specify you have an Xdrive… |
Boostedphil698436.00 |
11-18-2021, 06:34 PM | #53 |
Rep 1,119
The way the downpipe sits with xdrive vs without, is no difference so I think that is why there is no mention of it.
11-19-2021, 05:46 AM | #54 |
Rep 190,750
fits the same
11-19-2021, 08:55 AM | #55 |
Noob
70
Rep 254
thanks guys I ended up pulling the trigger on the AA DP because of the EPA Certified factor plus fabspeed's price difference now lets just hope I pass CT emissions (visual and OBDII inspection).
FBO, MHD Stage 2+ E20, Xhp Stage 3
11-22-2021, 09:05 AM | #57 |
Rep 190,750
and check for the wait time before placing an order
11-22-2021, 10:52 AM | #58 |
New BMW owner
325
Rep 842
I had to wait for mine for a while so heed this advice if you have the patience of a 5 yr old.
11-22-2021, 12:03 PM | #59 |
Rep 190,750
Which is 90% of us including me when i buy parts
11-23-2021, 04:44 PM | #60 |
Rep 263
AA fitment for EWG is pretty poor. Could only use one of the brackets, and even that was spotty. Turned what should have been a simple install into a profanity laced ordeal :/.
11-23-2021, 04:48 PM | #61 | |
Rep 190,750
Spot on fitment. You either got a defective product or its a bad install
11-23-2021, 06:22 PM | #62 |
Rep 263
I'm going with defective product
I tried every which way, several times, and could not get the bracket posts to line up and get the flange to be flat against the turbo. I was hoping removing one bracket would do the trick, but it still wouldn't line up properly without loosening the bracket as much as possible. I have to pull it all out again now since it never did seat properly, and is leaking. I consider myself fairly mechanically inclined - 4 or 5 downpipes on my other cars - including 2 other N55's, turbo swaps, heads, cams, engine swaps, etc - so pretty sure it wasn't a bad install..... :P |
11-24-2021, 09:10 AM | #63 | |
Rep 190,750
11-24-2021, 09:52 AM | #64 | |
Rep 263
I expected some trouble, as I did find several other complaints about this same issue during my research. Not a lot of those mind you, but there were some out there that gave me pause. The no CEL guarantee was enough to go for it anyway. I'm easily hitting 2 more PSI now with the stage 2 tune and DP, so performance is excellent.
2018 340i F30 Xdrive
11-24-2021, 11:51 AM | #65 | |
Rep 190,750
11-24-2021, 12:46 PM | #66 |
Noob
70
Rep 254
ordered mine on thursday and arrived the following monday I guess I got lucky.
