BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Rough idle engine shaking after car is warm
Studio RSR
      08-08-2021, 02:38 PM   #1
Beasty_916
Drives: Bmw 435i
Hey all this is my first post here I am at a lost of what is going on with my 2014 f32 435i. It’s a very odd issue when the car starts in the morning it idles ok with an occasional engine shake for a second or two. After the car is warmed up from driving around I let it sit for about an hour or so and I come back to turn my car on and the engine is shaking and choking while the rpms rev up automatically to 2-3k rpm for a few seconds then comes down to a normal idle. It almost sounds like the car is going to stall when I turn it back on after engine is already warmed and has sat for an hour. It also doesn’t seem like it picks up as fast anymore almost like it’s in limp mode. Car has about 85k miles I’ve done all the maintenance on time and don’t drive insanely hard on the engine. I’ve replaced charge pipe, spark plugs, air filter, change oil every 5k miles, did fuel injector cleaner twice and poured chevron 91 octane gas, cleaned my MAF sensor twice. I have a feeling it is a bad sensor but just don’t know which one, I’ve scanned using obd multiple times with no misfires or any errors that stand out to me. I attached the obd reading so you can see what issues it’s reporting. I’ve also read multiple other forums but can’t find a fix so I’m going down a rabbit hole please help
Here is a video of the issue
      08-08-2021, 06:58 PM   #2
thejeremyman9
thejeremyman9's Avatar
4362
Drives: 2015 BMW 335i
Tuned or no?
Any other modes besides the CP?
If i had to just guess, it does sort of seem/sound like a fuel injector problem, but again, that's just a guess in the absence of more information. Did it get progressively worse over time?
cfm56d7b5886.00
      08-08-2021, 09:05 PM   #3
Beasty_916
Drives: Bmw 435i
No tunes at all on the car. No other mods on the car bone stock other than I did a muffler delete 3 years ago. The issue did seem to get worse over time, as a test i was revving the car in park steadily at 4k rpm for a couple seconds and when i let go of the gas to let the rpms come down the engine was shaking. I have a feeling its something to do with how the car is getting air or fuel.
      08-09-2021, 08:05 AM   #4
TheJungatron
TheJungatron's Avatar
352
Drives: 2020 M340i RWD- USA
yeah, lack of information code information here makes it hard.
If I would have to guess id do the following in order of price.
Check charge pipe and boot pipes again
clean MAF sensor again
replace air filter
swap plugs / replace plugs
replace coils / swap coils
fuel rail clean
replace fuel rail
replace fuel rail sensor
replace high pressure fuel pump and get turbos and go stage 3 :-)
Might be something simple or not.
Good Luck!
2020 - M340i RWD | Executive
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade)
(Retired - 2010 328i)
(Retired - 1987 325i Vert)
cfm56d7b5886.00
      08-09-2021, 11:33 AM   #5
thejeremyman9
4362
If it only happens when warm it could be something with closed loop (O2 sensors), but without a data log or more info its really just guessing. I personally don't think its anything with plugs/coils or you would have issues across the board. Does it ever smell rich?
      08-09-2021, 12:02 PM   #6
Beasty_916
Drives: Bmw 435i
When you say smell rich are you saying like a rotten egg type of smell? I am asking because yesterday I was pushing the engine hard to see if would stall and when i came back it smelled like rotten eggs in the garage from the exhaust lol. I think i may order a new MAF sensor but ive cleaned it twice what do you think?
      08-09-2021, 12:11 PM   #7
thejeremyman9
4362
Rich would smell like fuel. Not sure why you would get rotten egg smell from the exhaust with a stock cat...
I don't want to make any specific recommendations without seeing more data or something because you are just going to end up throwing parts at the car.
      08-09-2021, 12:42 PM   #8
Beasty_916
Drives: Bmw 435i
the Carly adapter has a function to log data and send it to me via email. I just dont know which logs i should be capturing. I put all the capable log data i can capture.
      08-09-2021, 01:08 PM   #9
thejeremyman9
4362
That's a lot... Can you just turn them all on and we can disregard what we dont need in post processing?
The key thing will be capturing a short log when the problem occurs so we can check for anything unusual
      08-09-2021, 01:29 PM   #10
Beasty_916
Drives: Bmw 435i
I think it only allows 6 captures at a time but ill see what I can do
      08-09-2021, 02:22 PM   #11
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [10.00]
I had a very rough idle issue on my 435i that turned out to be the a bad coil. I replaced them all and the car runs like new. You could disconnect one coil at a time to see if you notice a difference.
      08-09-2021, 02:23 PM   #12
thejeremyman9
4362
These are probably a good starting point:
Air mass flow
Desired idle speed
Engine speed
Filtered rail pressure value
Manifold absolute pressure
O2 sensor int.
Rough running cylinder 1
Target throttle angle
      08-09-2021, 02:27 PM   #13
Beasty_916
Drives: Bmw 435i
Yeah i thought about starting there and replacing the coils and MFA sensor.
      08-09-2021, 02:28 PM   #14
Beasty_916
Drives: Bmw 435i
Air mass flow
Desired idle speed
Engine speed
O2 sensor int.
Cool thanks man, I'm going to run those logs when I drive and when I turn the car back on after its been sitting. Thanks!
      08-09-2021, 02:48 PM   #15
cfm56d7b
Tuned or no?
Beasty_916, when was the charge pipe installed?
102001 can be thrown if charge pipe has not been seated properly. Worth investigating.
      08-09-2021, 03:06 PM   #16
Beasty_916
Drives: Bmw 435i
Charge pipe was changed to VRSF April 2020 with no issues after the change. Sparks were changed at 60k miles.
      08-09-2021, 04:54 PM   #17
cfm56d7b
Got it. Still suggest to check the fit - just in case.
      08-09-2021, 05:15 PM   #18
Beasty_916
Drives: Bmw 435i
will do thanks guys, I just ordered new ignitions coils and will run the logs today and report back!
      08-09-2021, 09:49 PM   #19
Beasty_916
Drives: Bmw 435i
I provided two sets of logs. Carly logs are little weird. The first set with start time of 16:42 is when I started logging right after cold start and driving around.
The second set of logs at 18:55 is after the car was warmed up and sitting for about an hour and half, I started logging before the car started shaking and auto revving at 18:55.
      08-10-2021, 11:54 AM   #20
thejeremyman9
4362
You need to upload these to datazap
https://datazap.me/u
      08-10-2021, 12:18 PM   #21
Beasty_916
Drives: Bmw 435i
Cold start logs
https://datazap.me/u/beasty916/log-1...=0-1-2-3-4-5-6
The breaks in the logs are me starting and stopping the logs on the carly app
Logs after car has been sitting for an hour
https://datazap.me/u/beasty916/logsa...=0-1-2-3-4-5-6
      08-10-2021, 12:42 PM   #22
thejeremyman9
4362
Cold start logs
Well you can see some strange behavior but unfortunately I am just not sure how to interpret the carly parameters or how to pinpoint what might be wrong.
You are still getting no codes, even shadow codes? I think MHD lets you scan for codes for free via their app, you might try that.
Without any codes or anything remote diagnosis may not be possible.
