BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Road noise after coil overs installed.
Studio RSR
      09-01-2021, 12:57 AM   #1
awschubert
Drives: BMW 328i
I installed some bc racing coil overs on my 2016 328i and only the drivers side is making a lot of road noise and almost like some rattling not clicking. The noise is more than normal. It is definitely just coming from the drivers side and I am wondering what everyone's thoughts are that could be wrong. I checked everything and all of the joints and gaskets looked good so just racking my brain to figure it out. I have an appointment for an alignment check tomorrow too.
      09-01-2021, 06:37 PM   #2
andrew3series
Drives: BMW 340i xDrive
For me it was a metallic clunking after coilover install, turned out to be bushings. (Coilovers have less dampening than stock so it exposed the bushing failure noise to an annoying level)
      09-01-2021, 09:17 PM   #3
awschubert
Drives: BMW 328i
Thanks for sharing!! I don't feel like it's a metallic clunking I guess for me to explain it like I can just hear the road noise way more just from the front drivers side. Maybe as I'm driving home tonight it sounds kinda like something is loose. I also need to raise it up cuz now that I've drove it's way to low for my liking and maybe some of those adjustments will fix it. I'm gonna take the wheels off in a couple days on my day off and make sure that the camber didn't change and is the same on both sides and see if raising the car helps and make sure everything is secure and I didn't miss something. I'll post an update but still curious other input too.
      09-02-2021, 11:52 AM   #4
cfm56d7b
awschubert, did you also install camber plates with BC coilovers? Was the installation done by a shop or DIY?
      09-02-2021, 12:10 PM   #5
awschubert
Drives: BMW 328i
It was diy and yes I did install camber plates
      09-02-2021, 12:39 PM   #6
cfm56d7b
This thread discusses BC coilovers camber plates (and alternative camber plates) which can be noisy:
https://f30.bimmerpost.com/forums/sh....php?t=1459014
      09-02-2021, 01:22 PM   #7
awschubert
Drives: BMW 328i
Ok thanks, I'm doing a quick browse thru and it's not really a clunk that happens it is a constant annoying road noise for the most part. I made adjustments to my ride height last night and made sure every thing is torqued to specs.
      02-16-2023, 06:01 PM   #8
F32Spawn
Drives: BMW 335i
Hey sorry to dig up your old thread. I just installed my Coilovers (Broadway Static) and I’m having the same road noise you described. It’s not metal clunking. Did you resolve this issue?
      02-17-2023, 04:07 PM   #9
Jvac
Drives: 2015 335i rwd
This is pretty much the reality when you install aftermarket suspension parts, namely camber plates. They don't have the sound dampening that oem strut mounts have so they transmit more of the road noise as well as mechanical noises from the moving parts of the car to the cabin. It's just the way it is
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
      02-18-2023, 10:16 AM   #10
F32Spawn
Drives: BMW 335i
I 100% agree with you and I’ve had plenty of cars lowered on Coilovers. And I’m accustomed to all of the more noticeable noises. But for some reason this seems irregular. It’s like a cross between a rubbing and a clunking noise if that makes sense. It’s almost like a “hollowness” noise.
      02-18-2023, 02:26 PM   #11
Jvac
Well, I don't run bc coilovers so I can't say what's normal but I have read many comments here about their noise issues. I don't know if what you're describing is normal or not. But there's definitely added clunking and thrumming/vibrating type noises from my Milway plates when riding over bumps and cracks especially audible at low speeds.
