09-15-2021, 05:11 PM | #1 |
Rep 146
Mppsk mid-pipe clamp failure
I have a 2018 440i GC X-Drive w/ MPPSK which I purchased with 15k miles back in May. Recently, there has been a rattle coming from the mid pipe on startup so I brought it in to be checked out and the mid pipe clamp corroded and failed causing the exhaust to sag and touch the frame.
BMW Fairfax is refusing to replace the clamp under my factory warranty because they cannot find any documentation that the exhaust was installed by BMW, despite the problem having nothing to do with installation and everything to do with shit hardware on a (clearly OEM) $3k exhaust system. The technician even said to my face maybe someone swapped out the OEM clamp that comes with the kit and replaced it with a shitty one... total BS. I've always been a huge proponent of this system despite the high cost due to the perceived benefit of BMW support in the event something goes wrong. Clearly I was wrong! Can't imagine not honoring warranty on such an expensive system in this very clear case of hardware failure due to poor manufacturing standards. I am hoping to appeal this to BMW. The repair cost was $279. Any advice would be appreciated. Mostly here to rant though and admit to the MPPSK haters they may be right because I doubt this would happen with Dinan etc.
2006 330xi M-Sprt (Blk) SOLD
2014 428i XDrive Sport Stage 2 (Blk) BLEW UP 2015 428i X-Dr M-Sprt Dinan Exhaust (Blk) SOLD 2018 440i X-Dr GC LOADED MPPSK (Blk) NY/DMV Based |
09-15-2021, 05:55 PM | #2 |
Rep 4,876
Well that just sucks!
Seems like complete BS that they wouldn't cover that under warranty though. I'm 99.9% sure you can buy and install the MPPSK exhaust from the parts counter, and just need BMW to load the mapping. |
R$28i60.50 |
09-15-2021, 06:02 PM | #3 |
Rep 146
Exactly!! Makes no sense. And it's not even like it seems like the exhaust is wrong or damaged. The clamp is just corroded!
09-16-2021, 03:13 AM | #5 | |||||||
Rep 3,872
I have almost been refused to have my MPPSK registered in the car approval, as it was installed by a BMW workshop in Germany, however my local roadworthiness authority claimed they have no oversight and control over workshops abroad (I am not in Germany), so in theory... it is not guaranteed that it was installed correctly, hence roadworthy. Yes - complete BS - but same principle, just one step further. In my case though that could not be substantiated, as if the local authority does not recognise BMW's own quality assurance system, covering also their network of workshops around the world, they should not allow BMW vehicles on the roads at all... In your case - you should be able to claim the money back from whoever sold you the car without declaring that the MPPSK is not installed by BMW and as such - not a warranty-covered item. It can get worse - turbo- or cat-converter- related failure and BMW rejecting to cover it under warranty, as "somebody unauthorised" installed a MPPSK system. Legally - they are entitled (if they prove the exhaust could have contributed or caused the failure). Quote:
A BMW workshop would NEVER load the MPPSK mapping, if the system was not installed by them (or at least another authorised BMW workshop), for reasons mentioned above. If it was me, I wouldn't do it either or I would offer to charge you for an installation inspection first to ensure compliance - for what I know, the system may have been modified, installed wrongly or on a cheap mid-pipe clamp... Tomorrow you will come to me with a warranty request, since I enabled your MPPSK. But instead, you should go to whoever installed it for you and ask for warranty there... After all - you wanted it cheaper... You got it cheaper - you saved money from the BMW warranty. You simply cannot have the cake and eat it too...
09-16-2021, 07:05 AM | #6 |
Rep 975
A dealership doing regular dealership BS. I'm shocked. BMW of Fairfax is a joke.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
09-16-2021, 08:59 AM | #7 | |
Rep 4,876
This was 5 years ago, so maybe I misunderstood, they misspoke, or I forgot. |
09-16-2021, 09:17 AM | #8 |
Rep 3,872
Peculiar...
Doubtful that anyone would do that (why would they...? What is in it for them, except risk...). At least in Germany or Europe in general, no authorised workshop would agree to that, as it is against all procedures and principles. It's like hypothetically buying all the car components separately, building a complete BMW in your own garage and going to BMW to fix the issues with it under warranty thereafter, since the parts are all BMW Good luck The assembly/installation, as well as the tools and personnel involved, all have to be approved, trained and under quality assurance for anyone to give warranty. Makes sense to me, even if it looks silly in some cases. In this case, given the negligible problem and low cost, I would have indeed expected goodwill. But there is hardly any legal ground to claim warranty, I fear...
CajunBMW1288.50 |
09-16-2021, 09:28 AM | #9 |
Rep 3,872
@R$28i
It would be interesting to see a photo of the condition which your MPPSK exhaust is in... a clamp, even a low quality one, does not corrode to the extent that it breaks over a night and out of nowhere... on a 2018 plate car! I would be much more concerned about WHY this happened than about the cost for its repair. Where do you park/keep your car?
09-16-2021, 10:20 AM | #10 |
Rep 1,641
I can add that like others above I had the mppsk added to my 340. From my experience, BMW was very particular about the installation and the installed tune. I used the dealer and received numerous documents from them with the key codes and warranty info about this exhaust and tune. Apparently I was the first to get this done at my dealership. They were very excited but also very cautious about doing it right. To their credit I have had no issues in the 2 1/2 years with it on. As far as I can tell from looking under the car and during my washes and detailing, everything looks good and the exhaust is still very new looking. I am lucky that we have mostly warm hot and dry weather with occasional deluges of serious and torrential rains.
I am surprised that for good will they did not fix it since they can tell that it is original mppsk exhaust, especially if unmodified. My dealership always goes out of their way for me. But I have purchased multiple BMWs all from this dealership. With that stated, I unfortunately think it is their right to not warranty something they believe was not installed by BMW. Good luck and I hope you get this resolved. I still enjoy my 340 and the mppsk, as stated above, is great. Even the newish service advisor noticed the mppsk and the growl when he fired it up yesterday. He said it was one of the best sounding cars he has heard in a while (I am guessing he hasn't had too many M cars in recently). I had it in for a free oil change since it is still under warranty. So I hope you can enjoy the 440 and that the mppsk adds to the fun of your car. |
R$28i60.50 |
09-16-2021, 10:32 AM | #11 |
Rep 3,872
^ Actually…. MPPSK sounds better than most M cars! No kidding! Has been recognised for that many times…
The only way to have an appreciably better sound is 2 more cylinders…. Or 6….
R$28i60.50 |
09-20-2021, 11:07 AM | #12 |
Rep 146
UPDATE: It turns out the exhaust was installed as part of the factory build option which i was able to confirm with the original dealer that sold the vehicle in 2017-18. They have now sent me their internal documents / build sheet showing the M exhaust as an original option.... I will be sharing this with BMW Fairfax as soon as i get their manager on the phone and presumably expect them to reimburse me. Amazing that they did not see this in on their end and I had to play detective to get this settled.... will update on reimbursement efforts
CajunBMW1288.50 |
10-04-2021, 11:14 AM | #14 |
Rep 146
UPDATE: They have agreed to refund the cost after quite some time spent facilitating contact between the VA dealership and the Canada dealership the car was ordered from.
I showed them the REX screenshot showing that the car was optioned from day 1 with the Canadian "M Performance II" package which includes what the US market refers to as the MPPSK. Very happy that this was cleared up. I still have yet to receive the refund nearly a week later but remaining patient.
10-04-2021, 12:32 PM | #15 | |
Rep 1,641
R$28i60.50 |
01-15-2022, 09:38 AM | #16 | |
Rep 327
Thanks to Skyhigh for steering me to this. @R$28i - was your rattling sporadic? Or pretty consistent? Mine has only made the sound once so far. Mine was a dealer installed option, and there even is this little sticker, however faint, adhered to the underside of the bonnet stating dealer code. My BMW new car warranty is through 2023 so I'll ask them to check it out next time I bring it in if the issue doesn't come back up again. |
R$28i60.50 |
01-15-2022, 09:51 AM | #17 | ||
Rep 146
It was only at startup especially worse when cold. In retrospect due to the midpipe touching a piece of the frame due to sagging from the failed clamp. Once warm it didn't make any noise presumably because it expanded and was snug against the frame. I'm sure the dealer will be able to tell if this is the case / you could probably tell just by looking under the car to see if the midpipe is sagging. If not that I would guess it's a failed valve in the muffler. Regardless they should cover it under warranty!
jnj2455364.50 |
01-15-2022, 10:13 AM | #18 | |||
Rep 327
[IMG][/IMG] |
01-15-2022, 10:18 AM | #19 | ||||
Rep 146
jnj2455364.50 |
01-17-2022, 05:34 AM | #20 |
Rep 454
I had this issue when I get my CTS turbo downpipe installed by a shop. I thought they didn't clamp it back on correctly but they said the system wasn't installed correctly, but the shop fixed it anyway. This is one year after I installed my MPPSK.
03-27-2022, 06:59 PM | #21 |
Rep 327
Apologies, can someone point to where it would be touching? I've been working on my father's car so I've kept my car parked outside the last 3 days. Temps have been fluctuating between 35-50oF and so this morning was the first time i heard the rattle after having driven it 8 miles to the gym and returning to it 1.5 hours later.
Crawled under tonight to really look at it, nothing seems obviously loose or touching. Loads of pictures below: |
03-27-2022, 07:01 PM | #22 | |
Rep 146
