02-16-2018, 08:26 PM | #111 |
Rep 228
Looks like I saw the wrong one.
I was in 3005 DISPLAY_PIP_CONFIG. CID_DISPLAY_SIZE showing 6_5, 7_0, 8_8, 10_25, current set on 6_5. CID_DISPLAY_RES = 800_480, 1240_480, 1440_540, 1600_600, 1920_720. Current set on 800_480 DISPLAY_SIZE_RESOLUTION was in 3006 Navigation, couldnt locate it in 3001. It was already set to 10.25_1280X480 Available option = 6.5_800x480, 8.8_1280x480, 10.25_1440x540, rse_9.2_800x480, rse_10.x_180x720 |
02-16-2018, 09:11 PM | #112 |
Rep 37
hello guys! sorry to invade this post but i just bought the 8.8" screen to replace my 6"
i've done so many coding with esys but now... it simply doesnt work it keeps asking for the PIN. i unput the pin but it asks again, do we have other way around it? thanks in advance |
02-17-2018, 04:18 PM | #113 |
Rep 1
Hello i have a 2013 F30 328i with the basic 6 inch screen and looking to the upgrade for the bigger one. Is this what i need to buy?
https://m.ebay.com/itm/BMW-3-F30-F31...00?_mwBanner=1 |
02-18-2018, 09:07 AM | #114 | |
Rep 565
02-18-2018, 09:10 AM | #115 | |
Rep 565
02-18-2018, 09:11 AM | #116 | |
Rep 565
EDIT: If you want to retrofit the whole head unit (not just screen), that's a very complicated thing to pull off and out of the scope of this thread. Search the forums for "NBT retrofit". |
02-18-2018, 07:24 PM | #117 |
Rep 808
Quick question I'm hoping someone can help me - I installed e sys today to do some coding on my car, and found that I have HU_ENTRYNAV, not NBT or CIC.
The weird thing is my car was built in 2012, so I'm not supposed to have ENTRYNAV? Just trying to figure out if the screen upgrade is possible. Thanks! |
02-19-2018, 06:10 AM | #118 | |
Rep 565
HU_ENTRYNAV > HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_ENTRYNAV > EXBOX > DISPLAY_VARIANTE = breites_display Don't change them, just see if these options are available to be set. EDIT: You can take a photo of the main iDrive menu and post it here, that may help, too. |
02-19-2018, 11:47 AM | #119 | ||
Rep 808
Also for what it's worth I do not have navigation, and the car is Canadian spec. |
02-19-2018, 01:54 PM | #120 |
Rep 565
That indeed looks like HU_ENTRYNAV. Be sure to check eSys to be sure. Are you sure your car was made in 2012?
EDIT: Here's a link to pictures of iDrive versions: http://support.mycarly.com/knowledge...cc-cic-or-nbt/ |
02-21-2018, 06:38 PM | #121 |
Rep 2,044
Hello BMW Experts!
Don't get discouraged with your search for the correct screen. I just scored a coveted, 'A' condition, 12v 65506822626 screen, which should be a direct plug-in for my '17 330i. For $150. I think I just have to unscrew the old screen & screw this one in, no coding? Murf |
02-21-2018, 06:56 PM | #122 | |
Rep 808
02-21-2018, 10:14 PM | #123 | |
Rep 228
02-22-2018, 03:06 AM | #124 | |
Rep 565
PS: The only matte screen is the 6.5" screen on cars without navigation. All others are glossy. |
02-22-2018, 06:11 AM | #125 |
Rep 2,044
I got it on:
https://www.partshotlines.com/ The look-up database is just terrible. I put in "2017 330i" and nothing came up. I put in "2016 440i" and this came up, out of a 2017 330i...! Murf |
02-22-2018, 06:17 AM | #126 | |
Rep 2,044
Murf Last edited by Littlebear; 02-22-2018 at 11:05 AM.. |
02-22-2018, 06:20 AM | #127 |
Rep 565
02-22-2018, 06:27 AM | #128 |
Rep 2,044
02-23-2018, 04:32 AM | #130 |
Rep 2
Hi guys,
my F31 LCI is from 11/2015, I do not have navigation and have the small screen. Idrive says the version of media is MV-130.007.002 does it help? Also when I put my VIN (K627781) into realoem I see only possibilites for screen with navigation. My question si what is the chance to upgrade to 8.8 screen in my car? And could you suggest what other retrofits for my car would come into considaration with only a little effort? :-) Time has changed since my e46 and the options and variation of units is amazing. Thanks a lot. |
02-23-2018, 04:36 AM | #131 | |
Rep 565
If you want to be 100% sure, get the ENET cable first, download eSys software and check HU_ENTRYNAV coding. Then buy the screen on eBay. |
