05-12-2017, 03:52 AM | #1 |
Rep 62
cic to nbt upgrade
I've been searching but nothing clear has been showed up except going full retrofit from nothing.
Rather I already have cic system, and wants to upgrade to nbt. mine comes with HUD, was wondering if those bimmertech nbt retrofit will sync up with my current display and hud. anyone has done cic to nbt upgrade? |
05-12-2017, 09:10 AM | #2 | |
Rep 1,975
Drives: 2020 G20 320i M Sport
Depending on what kind of sound system you have, you may need to do a direct wire jump over to the fuse. HUD will work fine as long it's coded correctly. If you have a backup camera, you will need to change the pinout on your quad lock to work with NBT.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
mqfresh1.50 |
05-12-2017, 02:34 PM | #3 | |
Rep 62
05-12-2017, 02:38 PM | #4 |
Rep 1,975
You're going to need to take the amp trigger wire and tap it to the fuse because the NBT is not going to know how to turn on the amp. Also, you'll need a new USB and Bluetooth Antenna as those are currently connected to the Combox. Also note that your AM/FM antenna wires are different so you will lose AM radio.
Once you disable the combox, you'll also have to terminate the most loop so that DTC messages and Service Internals can show up properly on the instrument cluster. Also, your microphone will need to be disconnected and you'll need to run it to pins 17 and 22 on the quad lock as that too also goes to the combox currently. We usually don't recommend this retrofit due to the amount of work involved. HU_ENTRY to NBT is much easier as HU_ENTRY is wired exactly like an NBT due to the combox not being present.
05-12-2017, 05:54 PM | #5 | |
Rep 62
Man thats much more hassle than I expected |
05-15-2017, 02:24 PM | #6 | |
Rep 59
I really appreciate any feed back this will be my first retro fit . I have baseline model so it would be Hi Fi system I believe |
05-15-2017, 02:27 PM | #7 | |
Rep 1,975
These NBT EVOs are meant to work with the ATM module and without that, you will not be able to get your GPS position. At this point, you can either purchase an ATM emulator or try and get an ATM from donor but these are very difficult to wire. Also, just because it's NBT EVO does not mean it's ID5. This appears to be an ID4 unit.
05-15-2017, 02:33 PM | #8 | ||
Rep 59
05-15-2017, 02:35 PM | #9 | |
Rep 1,975
http://carsystems.com.ua/bmw-product...tm-emulator-en Are you able to exchange it for a first generation NBT?
05-15-2017, 02:37 PM | #10 | |
Rep 59
05-15-2017, 02:40 PM | #11 | |
Rep 1,975
Just treat it is a movie player and multimedia device.
05-15-2017, 02:46 PM | #12 | ||
Rep 59
05-15-2017, 02:51 PM | #13 |
Rep 1,975
Correct.
Also, if this head unit has software from November 2015 or later on it, it may disable itself if it detects that it's being installed into vehicle with a different VIN. All of our NBT and NBT EVO retrofits are flashed on our bench and pre-coded and activated to your car's VIN so you wouldn't have to worry about this issue.
05-15-2017, 02:53 PM | #14 | |
Rep 59
05-15-2017, 02:56 PM | #15 | |
Rep 1,975
You can consider purchasing one of ours later. Since your vehicle is a base model, it will literally be plug and play if you go with a first gen NBT.
05-15-2017, 02:59 PM | #16 | ||
Rep 59
05-15-2017, 03:04 PM | #17 |
Rep 1,975
If you get the ATM emulator as well as the Can Filtering harness, you should be ok. I don't think anyone else here has used an ATM emulator as of yet so you will be the first to find out
05-15-2017, 03:08 PM | #18 | |
Rep 59
05-16-2017, 12:04 AM | #19 | ||
Rep 59
05-16-2017, 12:13 PM | #20 |
Rep 3
You can use what you have, you just need carsystems emulator. It contains a built in CAN filter, so you don't need extra parts besides ATM emulator. You will obviously need to get or solder all the missing wires.
05-16-2017, 01:48 PM | #21 |
Rep 62
05-16-2017, 04:36 PM | #22 |
Rep 59
I'm just going to buy NBT non EVO so it's easier lol
