06-07-2018, 10:57 AM | #177 |
Rep 152
Anyone know why I get a message STOP flashing on my reverse camera? Not sure why just wondered if anyone had a clue. It's not a huge deal just a bit annoying.
06-07-2018, 12:42 PM | #178 |
Rep 88
Finally I know how to fix the distorted sound. You have to reduce the media volume in the settings menu as shown in the picture. My volume was set to max. And the aux volume for oem-side behaved strange (it did not affect the sound volume) until I found this setting.
vanillahunter3.50 |
06-08-2018, 03:14 AM | #181 | |
Rep 132
steve498 Looks like I got a different reverse camera model than you. Because my video cable is different. I wired it up like my drawing and camera is working fine: Quote:
06-08-2018, 03:24 AM | #182 |
Rep 78
thanks Wacky I was going by your suggestion and currently GND cable is in boot lining, Im I have routed cable so I just need to install Head unit to be able to tell wheter GND is required or not (hopefully not! )
06-08-2018, 03:50 AM | #183 | |
Rep 132
Seems Louie sent out two different camera models. Last edited by wacky007; 06-08-2018 at 04:04 AM.. |
06-08-2018, 04:22 AM | #184 |
Rep 152
I wired mine up the same as your diagram so perhaps I explained it badly. Yours also has that annoying stop message flashing which is coming from the video feed itself so I guess we're stuck with that. Also, how is your DAB signal? Mine seems worse than before installation and I'm wondering if it's the camera causing it. I might unplug it and see how it goes for a while.
06-08-2018, 04:37 AM | #185 |
Rep 132
What I mean is that my video cable looks completely different than yours.
No second yellow video plug, no red plug... Yes, STOP message is flashing all the time. I didn't test DAB after camera install, will do it today or at weekend. |
06-08-2018, 04:58 AM | #186 |
Rep 152
Oh I see strange. Well camera works fine so it'll do. I've also narrowed it down and don't believe the camera is at fault. So, I put the android unit into aeroplane mode as it's giving off radio signals obviously and it's solved the problem I think. Dab has been fine so far touch wood.
06-08-2018, 07:31 AM | #187 |
Rep 584
Are you using an OEM DAB antenna or one that came with the module? I messed up installing mine, didn't ground the copper part to body work so it doesn't work too well when travelling.
Mick |
06-08-2018, 07:42 AM | #188 |
Rep 152
This is for the OEM DAB antenna. I have not got the aftermarket one sorry.
06-08-2018, 08:07 AM | #189 | |
Rep 606
Can you also tell me when you minimize the DAB app and use the navi, if the sound stutters? I know it does with the zou_whatever app but I know you use the other german app. Thanks! |
06-08-2018, 08:55 AM | #190 |
Rep 152
It's used on my iDrive system, separate to the android system so no wiring or modifications were needed and I use the bmw's navigation and with DAB sounds fine. The sound on android also sounds perfectly fine at maximum audio with the AUX.
06-08-2018, 09:03 AM | #191 | |
Rep 606
You use bmw navi and DAB but also the additional DAB from Ugode right? I am going to install a DAB splitter to be able to have DAB from BMW and an external module connected to my Ugode. I think I am the first that does this |
06-08-2018, 09:09 AM | #192 |
Rep 152
I use BMW Navi and BMW DAB. I don't have any additional DAB or splitters.
06-08-2018, 09:43 AM | #193 |
Rep 606
06-08-2018, 11:03 AM | #194 |
Rep 78
Supernova6663.50 |
06-08-2018, 01:16 PM | #195 | |
Rep 152
I find where I live in the UK DAB is non existent. It's awful so it usually is FM radio. Therefore I did not get a dab box because it would sit there 75% of the time cutting in and out or with no signal. I'd rather use my radio and split screen with nav on iDrive I just installed a radio app and Spotify to the unit so I can use my internet for radio stations. I'll try to install Netflix on there soon |
06-08-2018, 04:05 PM | #196 |
Rep 78
how did you guys get sound of android unit? do you need to connect rca coming from audio cables to aux in ? I didnt have any optical cables to switch over
original harness |
06-08-2018, 11:43 PM | #197 |
Rep 42
Just installed unit (did it really carefully)
however it only displays "no signal" and oem side os working fine. what should i do now? I think cable is connected properly as I have sound on my oem system. (took green and black optic cables from the original harness and put it into new harness) Radio works fine too. It seems like android unit is not booting up at all. Please help! I already contacted Louie about this but no reply yet.[IMG]undefined[/IMG] |
06-09-2018, 12:40 AM | #198 |
Rep 42
Another question!
My unit booted up after I waited 20 mins with ignition off. I changed some settings and I wanted to download Waze from playstore. But it says "this device is not compatible with app version". How did you guys install Waze to the unit? Did you download apk file from the internet and put it into sd card slot to install it? Thanks in advance! |
