10-02-2017, 01:47 PM | #1 |
Rep 13
Audio upgrade
The sound on the audio is rubbish. I have enquired about a HK type retrofit.
The prices quoted are so high. In order to get an amp, 2x 8" sub woofers under seat and replacement all round speakers, the cost is between 1250-1650 depending on who u ask. I've been advised that this is a rainbow system and it actually sounds better than the HK. Has anyone had this retrofit installed, what did u pay and does it sound spectacular? Last edited by Bmw175; 10-02-2017 at 01:59 PM.. |
10-02-2017, 03:26 PM | #3 |
Rep 13
How much did that cost you? I'm going to be keeping the car for another 7-8 years so reckon I could justify the outlay but I'm finding 1250 hard to swallow.
10-02-2017, 09:55 PM | #4 |
Rep 7,484
You could do a lot or all of this yourself and save on labour. 1100-1600 is the ballpark dependent on what brand is installed professionally.
Many audio shops do us a favour because the true cost of the install would mean no one would have it done. My friend had a subwoofer installed in the boot of his F30 with HK. He was charged 90 and the job took 3-4 hours. The Rainbow can take down the HK. Other brands that are close if not better: Focal, Gladen, MB Quart and, Eton. Personally, I would look to the Eton. If you are keeping your car you may as well invest and enjoy. You can always sell the gear after or transfer some or all to your new car. The HK is not all bad. The centre channel is a phasing disaster and the underseat subwoofers come into their own on a higher power amp. You could even get used HK subs and a pre loved JL amp. Slap on some JL tweeters and now you have a banging set up with crystal clear highs and deep lows for less than 800. |
10-03-2017, 08:45 AM | #6 |
Rep 13
Thanks for your comments. Problem is that I don't have a clue about fitting the system myself. I'm just debating whether to go with a 1250 price tag, I've not even heard it. I've been advised that the rainbow is much better than HK. Does anyone know of any decent fitters in the Birmingham uk area?
10-03-2017, 12:40 PM | #8 |
Rep 7,484
10-03-2017, 03:59 PM | #9 |
Rep 778
Just change the mids and add tweeters to begin with, makes such a massive difference and you might find that is enough for you.
Made enough of a difference to stop me doing anything else and is a relatively cheap solution. |
10-03-2017, 04:55 PM | #10 |
Rep 13
Dyl- will u get a bassy sound with that?
The cheaper option is around 800 and has the following; upgrade the front door speaker with the Audison Prima range, which includes a 4″ speaker and tweeter. Then a 4 channel rainbow or hertz amp is used. I don't want the whole road to shake when I drive by, I just want strong and clear bass, alongside nice sound. Will this be the equivalent of a HK? |
10-03-2017, 08:45 PM | #11 |
Rep 7,484
The standard subs if you have them are pathetic. You need HK subs or other. They won?t rattle the car next to you in traffic but fill the cabin nicely.
What system do you have? Do you have tweets in the door frame and subs underseat? |
10-04-2017, 02:38 AM | #12 |
Rep 1,705
As ever with these things, I think it's worth auditioning 2 or 3 options. The HK is pretty good, certainly a step up from the standard audio set up. However I'm often struck (irritated) by how much better the Meridian system is in my wife's Evoque. I find the HK does well with simpler music, but the soundstage can get a bit muddled when there is a lot going on. It's fine as a factory fit, but I'd look around if you are are retrofitting.
10-04-2017, 03:06 AM | #13 |
Rep 13
I just have the standard system. Not sure what tweeters or subs are installed, all I know is that sounds very sub par. The system in my yaris sounds better which to me is an absolute joke given the level of the BMW i.e. M Sport.
10-04-2017, 04:05 AM | #14 | |
Rep 778
I came from a Golf GTI with a factory audio upgrade, I owned it alongside my 4GC for about 9 months. Stepping between the two the audio was miles apart. I decided initially to just add tweeters (and change mids) to see if it made any difference, and it does. A massive difference. I did one side first then used the fader L&R and check. The side without the tweeter sounds underwater. I'm happy enough with it now, and wouldn't go to the effort and large cost of adding an amp or changing the under seat subs. Incidentally the subs in a 'base' system are in a sealed housing that is impossible to get into without damaging it. I'm not saying it's going to be as good as any of the previous suggestions but I believe the very nature of adding tweeters is the biggest jump in improvement you can do to the 'base' audio. |
10-04-2017, 04:15 AM | #15 | |
Rep 13
Very useful. No I don't have any tweeters in corners of front doors. With the upgrade you had, did the bass become stronger? That's my main issue, I want stronger and more bassy sound. |
10-04-2017, 04:30 AM | #16 |
Rep 1,705
If you don't change the subs you're not changing performance at the very lowest frequencies. But, by replacing the tweeters and mids, you should get better separation with more distinct highs, mids and lows (less muddy). So your perception of bass may be improved. You may also be able to go louder without everything becoming messy.
Dyl432.50 |
10-04-2017, 04:35 AM | #17 | |
Rep 13
10-04-2017, 04:41 AM | #18 | |
Rep 778
First mod I did to my car, and the best. |
mcoops1757.00 |
10-04-2017, 02:26 PM | #19 | |
Rep 233
10-06-2017, 07:40 AM | #20 |
Rep 306
I had the base system, then I had John Klies audio fit and set up their stage 3 package, which consists of Rainbow speakers and tweeters, Rainbow subs under seats and an Audison Prima 8.9 amp which has a digital sound processor, it was 1600 which wasn't cheap, but the parts alone are like 1200, so for a few hundred more id rather someone do it all properly, they also spent half a day tuning the sound and doing the timing for each speaker which makes all the sound come from infront of you even though there is no front speaker.
10-06-2017, 07:44 AM | #21 | |
Rep 306
10-07-2017, 11:13 AM | #22 | |
Rep 13
