04-08-2021, 01:33 PM | #1 |
Rep 890
Drives: F32 428i Xdrive
New arms or just new bushings?
Hey everyone,
So it's about time... my lower control arm bushings need replaced as they are leaking. I've been seeing some threads about how people replaced them with Turner or Powerflex monoball style bushings and wanted some feedback on what may be a better fix or feedback on how others feel after doing the swap is it really a concern that when you get the old bushings pressed out the "tolerance" of the old arm is widened? And if that's the case, should I just go oem? Based off fcp I can get the pair of new arms for 160 plus their awesome warranty, and on that note, where is the listing for the monoballs for xdrive? I definitely think I want to do a performance upgrade as the old bushings were quite floaty so my preference is to go poly if it's the better option for xdrive Sorry if this is a simple question, I just want a cost effective way as other than getting bushings out, I'll be diy'ing this myself Edit: found the power flex ones |
04-09-2021, 10:05 AM | #2 |
Rep 416
I was also on the fence and I do love my spherical bearing on my E34 and E24 race car.
But considering the cost of the two arms: 500+ I decided that HD Meyle bushings pressed into the arm will be much easier than pressing the bushing out. I will end up with a stiffer bushing and a brand new arm. Your choices: - Meyle HD thrust arms (slight improvement) - Your stock arm with bushings removed and monoball pressed in. - Brand new Lemforder (OEM) arms with bushings removed and monoball pressed in. - Brand new arms with monoball already pressed in/ installed. Cost effective is this: https://www.millway.se/bmw/3-series/f30-f31-f32.html But on back order. Next cost effective is the Meyle HD at $70 an arm/bushing. And yes, I bought them from FCP
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
djacinto355.00 |
04-09-2021, 11:04 AM | #3 |
Rep 890
Blank
Thanks for the advice
Yeah so far my thoughts were the lemforder with the monoball. Unfortunately, I don't think there's prepressed in for xdrive at least as far as I've seen Turner has the arms prepared for the rwd but not xdrive. I'll try contacting them to see if they could just do it for me
04-11-2021, 11:00 AM | #5 | |
Rep 890
otherwise I posted the link for the bushings themselves from powerflex above for xdrive. Also note these are for the lower arms as well I haven't found pre-pressed monoball upgrades for the xdrive so I am on the lookout for those |
04-11-2021, 03:56 PM | #6 | ||
Rep 5,391
Upper Control Arms will dramatically improve the steering, making it much more precise upon acceleration and braking. Below is the xdrive link. Choose upper or lower or both... https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 |
djacinto355.00 |
04-11-2021, 04:21 PM | #7 | |||
Rep 890
johnung4525.00 |
04-11-2021, 07:57 PM | #8 |
Rep 890
@johnung what does the ride feel like now? Did you do both or just lower?
How long are they supposed to last since they're not fluid filled
04-11-2021, 11:38 PM | #9 | |
Rep 5,391
The monoballs reduce the excess play of the stock bushings like a race type bushing would. But monoballs have so much more freedom of movement that they don't introduce more NVH, (Noise Vibration Harshness) like a race bushing. In a very positive way, they do transmit to the driver's hands, through the steering wheel, a subtle feeling of the road that is missing from the vague F3x steering. |
JakOG43.50 |
04-12-2021, 12:04 AM | #10 | ||
Rep 890
Did you end up doing both or just one set? How long have you had yours on now
04-12-2021, 09:05 AM | #11 |
Rep 416
For information, I just replaced all 4 arms on my F30 Satuday, the front end is much tighter now and the ride more firm (go figure).
'16 M4 bone stock
04-12-2021, 09:25 AM | #12 | |
Rep 890
Do you have a gauge based on manufacturer for longevity?
04-12-2021, 10:00 AM | #13 |
Rep 416
- Meyle HD thrust arms and bushing not liquid filled
- Lemforder (OEM) control arms. They will last another 100k miles or more. I didn't fancy spending 500USD in thrust arms alone. FCP has great prices on arms so I placed an order. I got all 4 with 2 axle bolts for $300.
'16 M4 bone stock
04-12-2021, 10:01 AM | #14 | |||
Rep 5,391
I have friends who have one or both pairs installed. Really big improvement without the Noise Vibration Harshness. |
04-12-2021, 10:18 AM | #15 | |
Rep 890
04-12-2021, 10:19 AM | #16 | ||||
Rep 890
04-12-2021, 12:31 PM | #17 |
Rep 416
The arms come with bushings already pressed in, just install the arms.
'16 M4 bone stock
04-12-2021, 12:33 PM | #18 | |
Rep 890
I really appreciate the help! Also you got the link? I can't seem to find it atm
04-12-2021, 03:48 PM | #19 |
Rep 416
Here is the link for one control arm:
https://www.fcpeuro.com/products/bmw...854723#fitment The Meyle HD are using a stiff bushing instead of the liquid filled OE one. Check fitment but these were the pn for my 335ix, arms are one for the right and one for the left each. BMW Axle Bolt With Compression Spring 2 x Genuine bmw - SKU: BMW-31206795249 BMW Control Arm Lemforder - SKU: LEM-3711701 & SKU: LEM-3711601 BMW Control Arm Meyle hd - SKU: MEY-3160500069HD & SKU: MEY-3160500068HD
'16 M4 bone stock
04-12-2021, 05:49 PM | #20 | |
Rep 1,934
Didn't know they made a bmw arm but this is a nice find. Thank you for making me spend more money 🤣
frchdragon338.00 |
04-12-2021, 07:05 PM | #21 | |||||
Rep 5,391
Poly bushings are old style bushings with added Noise Vibration and Harshness compared to monoballs that are designed not to have those drawbacks. I know guys with M cars who have purposely installed monoball bushings because they are such a big improvement. |
04-12-2021, 09:01 PM | #22 | |
Rep 416
If I had $500 laying around, I would absolutely buy the monoball, even $300 I would buy. I love the monoball and there is no comparison. (I had them in my E34 and in my race car) But for $140.00 the Meyle HD are a good buy. I wouldn't just put them in if the stock ones were not leaking. So if money is not an issue: Monoball, else Meyle HD is a good replacement over stock. (Don't tell anyone but I am waiting for the millway monoball to be back in stock)
'16 M4 bone stock
