BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > 265/255 Track Square Setup
      11-25-2020, 04:50 PM   #1
nickf30
Drives: 2014 335i xDrive
Trying to get the car set up (F30 335ix auto) for next season:
Current:
KW V3
Drop 1 Inch
Stock Brake
EC7 ET35 18 x 8.5
No Spacer
Hankook RS4 245/40R18
1 Rim Bend little + rear tire kinda done
Add GC camber plate looking for 2 to 3 degree
Option 1:
265 Square on 18 x 9.5 ET35 Apex EC7 or Bimmerworld TA5R. Hankook RS4 (fat) or something little less fat
Camber?
Spacer?
Option 2:
255 Square on 18x8.5 replace 1 EC7
or 17x9 TA5R or Apex ARC8
Camber?
Spacer?
Option 3:
275/35R18 RS4 rear on 2 new 18x9.5-10 EC7 (Staggered 245/275 xDrive)
No need for camber.
spacer?
Any thoughts/ideas?
My current setup at NJMP:
      12-02-2020, 11:22 AM   #2
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
Having more negative camber from stock (option 2) would help much more than just running with wider tires(option 3). I would stick with no spacer, replace the rear tires, run -2/-2.5 camber on a 255 square setup. Some better pads and rotors over stock to decrease braking zones when coming into corners.
      12-09-2020, 04:43 PM   #3
brigade24
brigade24's Avatar
Drives: 2013 335 X-dive
RS4 is a good lapping tire...
you can comfortable run -2.5 to -3 degrees of camber up front with a 265 square setup. -3 will be tough on the street for tire wear unless you can do your own alignment on the front at the track and set it back for the trip home (this will require a will to learn and some toe plates). you'll need a minimum 10mm spacer upfront to make it work. I run a 15mm upfront and at max negative camber (-3 degrees), i am almost inline with the fender...zer0 rubbing but I'm on stiffer springs and bigger sway bar.
a 265 et35 setup in the back will easily fit with no spacers. you might need a bit of camber in the back. I run -2.3 and it might be a bit much for the rear...
if you run xdrive on track, i advise you to stick to a square setup. if you plan on running xdelete on track then you can go staggered.
