BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > MAF sensor plug clip broke
      09-25-2019, 07:36 PM   #1
maatt
Drives: '18 340i MPPSK
Installed Agency Power Intake today, however when I was removing the harness from the MAF sensor the clip came out completely, when i tried to push it back in the clip snapped. I've tried searching google and ebay but haven't found anything apart from the whole wiring harness which is $300.
if anyone has any info on where I can source the clip?
      09-25-2019, 09:17 PM   #2
j1980mac
Drives: 2018 X3 M40i
I've broken a few different clips on mine. So fragile they are. As long as they are tight, need not to worry.
      09-26-2019, 06:23 AM   #3
maatt
Ahh I was really hoping to replace the clip!
      09-26-2019, 06:50 AM   #4
j1980mac
I feel ya. I'm OCD about things like this, but luckily I forgot. Not anymore! I'm going to have replace mine now.
      09-07-2020, 03:40 PM   #5
WhiteLotus
Drives: 2016 340i
Did you end up finding a replacement? Fortunately where I live there are plenty of totaled B58 BMW so I'll probably buy one from a for-parts bimmer.
I was changing the air filter and cleaning the airbox and the clip flew back fell in the engine bay where it vanished.
      09-08-2020, 07:47 AM   #6
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
I was able to go through the dealership to get a replacement harness clip and locking mechanism. Initially they said they didn't have one but I pushed them to keep looking. It was like $35 which was outrageous for what it is but it worked. It has the plastic bits and all these tiny plastic barrels you have to thread the wires through. It's pretty delicate surgery to do it correctly but it was worth it for me.
Note: for me it was my wastegate position sensor that was broken but I imagine they could get the MAF one as well.
2020 X3M
MG Flasher; Wedge Performance E50 tune
MSS Urban; Rohana RFX11
      09-08-2020, 10:13 AM   #7
WhiteLotus
Drives: 2016 340i
Thanks. I just want the little gray locking clip though lol. The actual harness plug connector is fine and clicked in nicely. I don't think I need it. Was willing to spend a few dollars just because I like things done well (to a fault maybe)
Called the dealer and explained but the part number they gave of 12527615491 doesn't come up with much pictures and seems like it's what in one of the plugs.
      09-09-2020, 05:26 PM   #8
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: 20 330i,16 X3,18 SQ5,17 A7
Mine is broken too.
My question is. How easy/difficult is it to replace the plug? I've broken a bit of the black part that holds the grey clip in. It fits in tight and locks and works fine. But I'm OCD and want to replace the plug with no broken tab. I was wondering if it is a DIY or if a local workshop could do it for me.
Edit - Part that is broken is the part I've circled in red. It broke when I used a plier to try to lift up the locking tab beneath the grey clip. But it was dark and I couldn't see it and tried lifting the wrong part. That's how it broke. I'm looking at replacing the entire plug but not sure if its possible.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      09-09-2020, 08:43 PM   #9
Supr3me
Supr3me's Avatar
I replaced the plug/locking clip assembly. See my post in this thread from a couple of days ago
2020 X3M
      09-11-2020, 10:47 AM   #10
VipinLJ
Petrolhead
VipinLJ's Avatar
Ahh. I thought only the grey clip part was broken. How much did they charge for labor? I'm scared to ask my dealer here since they'll want $50 for the plug and $500 for labor
Current:
      09-12-2020, 08:27 PM   #11
Supr3me
Supr3me's Avatar
I think I paid like $35 for the replacement plug assembly and I did the surgery myself. I was able to disassemble the broken plug part way and then use the new housing without having to fully disassemble every wire, which would have been much more difficult.
2020 X3M
VipinLJ1483.50
      09-12-2020, 10:55 PM   #12
VipinLJ
Petrolhead
VipinLJ's Avatar
Ahhh. I thought of buying a plug from BMS for the 3.5bar sensor since it looks like the same plug and doing it myself. But I'm not sure I'm capable of pulling it off.
Current:
      09-20-2020, 07:00 PM   #13
WhiteLotus
Drives: 2016 340i
If you change it, can you mail me your old gray tab? Lol it seems yours is fine. I'll pay shipping lol.
      09-20-2020, 10:11 PM   #14
VipinLJ
Petrolhead
VipinLJ's Avatar
If I do, I will. I'll check my plug out in a few days. Looks like it'll break off and I won't be able to use the grey tab. If so, I can post it to you.
Current:
      04-20-2021, 03:11 PM   #15
leew102
Drives: F30 BMW 340i xdrive
sorry to revive an old thread...did you ever get yours fixed? I just broke mine too at the black clip part that goes over the nub on the the MAF sensor.
      04-20-2021, 07:16 PM   #16
Wires
Drives: 2016 340i xDrive
Grey lock, or black clip? The grey lock is "optional". It just 100% prevents the connector from dislodging. Black is required since it keeps the connector together.
      04-20-2021, 08:28 PM   #17
leew102
Mine is the black one that's broken. The grey one is ok.
      04-21-2021, 12:30 AM   #18
VipinLJ
Petrolhead
VipinLJ's Avatar
Nope. I haven't gotten it fixed. In my car, it didn't break off completely. Still clips into place perfectly. I totally forgot about it till I got this notification today
Current:
      04-21-2021, 12:59 AM   #19
leew102
Luckily mine also still clips into place and only comes off if you pull it with a good amount of force so I will also probably just forgot out it.
      04-21-2021, 08:46 AM   #20
Wires
You would need to find some place that sells that connector to swap it (that can be a bit of a ughhh moment though).
My plan "b" suggestion would be get that adhesive lined heat shrink (has hot melt glue inside) and slide it over the connector end and MAF plug to "glue & secure" into place.
leew10212.00
