03-16-2018, 08:33 PM | #1 |
Rep 81
Buy new V-band clamps before downpipe install?
Hey all,
I'm planning on putting in a new CTS downpipe into my 2014 335xi (EWG) this spring and I've been having the internal debate about purchasing new v-band clamps as part of the install. It seems like some do but a lot don't. Any feedback from you guys that have done in the install? My car has 40k on it and I'm in the northeast so I wouldn't be surprised if its a bit crusty down there. It's about $60 for 2 new clamps so If I could avoid the added cost that be great but if not I'd rather be safe then sorry. Thanks! |
03-16-2018, 08:45 PM | #2 |
Rep 92
I didn't buy one for the first 2 times I had my downpipe on and off ( for emissions) now that I'm about to reinstall it again, I bought a new gasket/Vband combo from ECS tuning.
The old one gets a little bent up after it goes on and off a few times. |
03-16-2018, 09:04 PM | #3 |
Rep 965
Drives: 2016 F36 435x MSport
its a small price to pay for added security against leaks. At the very least get a bottom clamp with the integrated gasket.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
03-16-2018, 09:12 PM | #4 |
not good, but bad
333
Rep 361
I think the concern is this piece getting mangled up:
[IMG]https://i0.wp.com/*************/wp-content/uploads/2018/02/IMG-20180208-WA0004.jpeg[/IMG] Inside the vband: [IMG]https://i2.wp.com/*************/wp-content/uploads/2018/02/IMG-20180208-WA0002.jpeg[/IMG] Check out my install guide in the link below, I personally didn't change it, but the next time I think I will have to.
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube Last edited by badbread; 03-19-2018 at 10:48 AM.. |
03-16-2018, 10:29 PM | #6 |
Rep 81
This is partially my concern also. I’ll have to take my downpipe off in a year. Maybe I’ll look to replace them then.
03-16-2018, 10:34 PM | #7 |
Rep 5,776
I have taken my DP on and off a couple times and will say the lower clamp should be replaced each time but the upper one is re-usable.
Last car: 2011 335i Msport. JB4. Vrsf CP |
03-16-2018, 10:44 PM | #8 |
Rep 808
I'll let you know tomorrow when I pull everything apart! I bought a new lower clamp because of the likelihood of those little tabs getting bent out of shape, but I plan to reuse the upper clamp
03-16-2018, 11:11 PM | #9 |
Rep 5,776
Yeah, those little tabs get all bent up...one time I took my new lower clamp back off because it didn't look right and they were bent, so I bent them back in place and no exhaust leak. Pretty simple stuff, but like a CP more labor intensive.
03-17-2018, 07:41 PM | #10 | |
Rep 808
Car on lift at 10 am, off the lift at 4:30 with a new inter cooler, charge pipe and down pipe (and bm3 flash). This included a quick run to grab a random socket we were missing and a lunch break. I took my dad for a test drive and he said it felt as powerful as his Tesla, so I'll consider that a win! |
03-17-2018, 10:07 PM | #11 | |
Rep 5,776
03-18-2018, 08:42 PM | #13 |
Rep 92
03-26-2020, 06:20 PM | #14 |
Rep 22
Do I have all the parts?
I ordered the CTS Turbo Catless 4" Downpipe for N55 (EWG).
Mine came with a single nut/bolt combo to mount it? Are those the only parts that should've come with it? I assume I'm reusing existing nut/bolt from the factory downpipe? I read guidance and will at least be purchasing a lower V band clamp. Thank you! |
03-27-2020, 10:16 AM | #15 |
Rep 190,725
+1
03-29-2020, 11:09 AM | #16 | |
Rep 7,598
When i replaced mine with fabspeed i had the gasket, top vband, and lower vband on hand. I ended up only using the new lower vband - that is pretty much unavoidable due to the way it clamps. I reused the top vband and even the gasket. My car is from CA and relatively low miles however you you might want to have those parts on hand as well. The only place there is a separate nut/bolt is for the side support bracket. I reused stock ones there as my fabspeed didnt come with anything. |
03-29-2020, 11:37 PM | #17 |
Rep 22
It's the bolt pictured here. Mine also came with a nut. I feel like they are just extra because from watching install videos and reading instructions the factory mounting points are used. Thanks for the reply! |
03-30-2020, 02:49 AM | #18 | |
Rep 53
03-30-2020, 08:06 AM | #19 |
Rep 237
I just did a downpipe yesterday, live in the Northeast. I probably could have reused the clamps, but bought new ones with the downpipe anyway. The upper clamp became a little twisted coming off, but could have been reused if necessary. You will need a new upper gasket anyway though and the lower clamp contains an integrated metal sealing washer so might as well do it once and do it right
03-30-2020, 11:51 AM | #20 | |
Rep 7,598
The upper gasket can be reused if it doesnt look crushed or damaged in any way. I was more concerned to try and remove mine and fit the new one than just leave the OEM, and mine doesn't leak or have any issues. But again, have it on hand and see how it looks when you get in there. Bottom clamp pretty much 100% needs to be replaced. |
01-12-2024, 08:21 PM | #22 | |
Rep 7,598
and this post https://f30.bimmerpost.com/forums/sh...16&postcount=6 |
