BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Dorch Stage 3 HPFP Kit
      06-02-2021, 04:25 PM   #1
-Eidos
Low Boost Boy (LBB)
223
Drives: 2018 BMW M2 (LBB)
For those that have seen my progress towards building a direct-injected only N55 car capable of 600+whp SAE on full E85 (Ethanol sensor reading at least 85% E) here: https://f87.bimmerpost.com/forums/sh...4&postcount=25
I just got the okay from Dorch to let everyone know that they will be starting production on the Stage 3 HPFP kit soon!
Some additional information from Chris at Dorch:
"As for the production kit, the final flow percentage gain number still may change, so that’s the only thing not set in stone. That call will be made in the next month here as we finalize more testing before ramping up production (finally!). The kit will come with a new flange and it will work with existing S1 and S2 kits, but depending on when the original HPFP kit was purchased, their pump may need to be sent in for an update service. This will most likely be free of charge with the purchase of the lift kit."
Speedtech Stage 3 (7670) | Remus Exhaust | Wagner EVO 3 | XClutch | Dorch Stage 3 HPFP | EU5 M5 Injectors | Walbro 525 | EOS EKP | BendCalibration Flex Fuel Kit | MSL Thermostat | TC Kline | SPL | Schirmer Diff Lift Kit | Millway | 3DDesign | RKP | TRE
Full E85 DI-Only 620WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      06-03-2021, 08:30 PM   #2
5w20
Drives: Bmw 435i
Definitely interested and will be contacting them for more info.
      06-03-2021, 09:01 PM   #3
Phantom10R
Drives: 2015 335i, 2015 X3 x35i
you planning on running twin lpfp?
2015 335i xDrive 11.37@121.9mph w/bm3 ots map
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @N55David For pics and updates!
Youtube: @ n55david For videos or Racing etc
      06-04-2021, 01:07 AM   #4
thejeremyman9
thejeremyman9's Avatar
2789
Drives: 2015 BMW 335i
A single 525/hellcat pump should support 600+ whp.
      06-04-2021, 01:12 AM   #5
5w20
Drives: Bmw 435i
Iím not opposed to it. Iím looking into options I have for ~600whp. I would just prefer to run full E85 but would still consider a E85/meth mix.
      06-04-2021, 12:00 PM   #6
-Eidos
Low Boost Boy (LBB)
223
I’m not opposed to it. I’m looking into options I have for ~600whp. I would just prefer to run full E85 but would still consider a E85/meth mix.
A single Walbro 525 should be sufficient for low 600's. However, it flows a lot and you run the risk of blowing a line in the LPFP assembly. I had to upgrade mine to a sturdier line. You will also need to run the EOS BPM4 EKP to support the single pump.
      06-10-2021, 10:01 PM   #7
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
this pump will outflow the fx180 correct? I'm looking for 600 on e85 with a flex fuel analyzer for simple fill and kill on one tune. MHD is coming out with all necessary components very soon as bm3 has is my understanding.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      06-10-2021, 11:33 PM   #8
-Eidos
Low Boost Boy (LBB)
223
For sure lol.
None of the current pumps on the market come close to the stage 3. Should be between 115% to 125% increased flow over stock. We'll find out the specifics once Dorch finalizes their testing.
      11-24-2021, 11:17 AM   #9
-Eidos
Low Boost Boy (LBB)
223
Here is the official product page for the N55 lift kit that pairs with Dorch Stage 1 and 2 pumps that is coming soon with some more information:
https://dorchengineering.com/product...-hpfp-upgrade/
It will add an additional 49% flow on top of either the stage 1 hpfp or stage 2 hpfp.
The stage "2.5" setup (Stage 1 + Lift Kit) will yield 117% flow over stock.
The stage "3" setup (Stage 2 + Lift Kit) will yield 160% flow over stock. This is the setup that I'm currently testing for Dorch on my DI-only build.
      11-24-2021, 01:09 PM   #10
terryd5150
Head Fry Cook at McBurgertown
Drives: 2015 435i M-Sport 6MT
Thanks for the update, Eidos.
      11-28-2021, 10:15 PM   #11
thejeremyman9
2789
It's unfortunate this isnt compatible with OEM HPFP, still waiting for a HPFP solution that does not require a tune.
      11-28-2021, 11:41 PM   #12
johnung
Okay so based on the revised numbers on the Dorch website, the Lift Kit will essentially create these HPFP options from Dorch:
HPFP cc/rev %> List$
Stock 0.837 ——— ——-
Dorch1 1.221 +46% $1,100
Dorch2 1.465 +75% $1,600
D1+Lkit 1.818 +117% $1,900
D2+Lkit 2.181 +161% $2,400
-Eidos222.50
      11-29-2021, 02:42 AM   #13
-Eidos
Low Boost Boy (LBB)
223
One can dream! Cali life
I'm assuming it's because you want to be able to smog on the stock tune while keeping the hardware the same (Or only having to swap out the downpipe)?
      11-29-2021, 10:39 AM   #14
mike@x-ph.com
mike@x-ph.com's Avatar
Sub'd
CHRISTMAS SALE - UP TO 20% OFF DINAN/ER/WAGNER/CTS||https://x-ph.com/sale/
Phone number 702-494-9435
      11-29-2021, 01:53 PM   #15
thejeremyman9
2789
Correct, i want to be able to completely uninstall tune/software from DME to be able to smog and retain HPFP. I am on fabspeed DP and i am not worried about any of my other hardware for smog check. So as of right now i can still (in theory) pass smog just fine because everything i have installed is compatible with stock tune, and i don't expect them to notice or care about anything they might see like MST inlet or a CP.
There's no way i will be swapping a HPFP every 2 years to smog, so HPFP upgrade is basically a no go unless/until there is another option.
johnung2515.50
      11-29-2021, 04:02 PM   #16
johnung
Yeah, the B58TU HPFP runs off the stock tune DME but then there's potential engine risk to take on with hardware incompatibility.
      11-29-2021, 05:24 PM   #17
435gc
435gc's Avatar
141
Drives: 2015 435i Gran Coupe xdrive
WMI a no go?
      11-29-2021, 06:04 PM   #18
thejeremyman9
2789
Originally Posted by 435gc View Post
WMI a no go?
Its an option as you can install it stealthily enough to be undetected and just disable on stock tune but not something i personally want to do as i would rather keep everything DME controlled.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
