07-23-2020, 10:54 PM | #1387 |
Rep 141
Ok guys last log I post in a while (I hope) haha
https://www.bootmod3.net/log?id=5f1a...90c676ad312cd2 |
07-24-2020, 05:02 AM | #1388 | |
Rep 192
I have a long trip today were I'll burn through most of the second tank using the same map to let it adapt. I'll try to log when I'm close to my destination and see how it's looking. 93 map on 93oct Shell gas. I've been doing some research and apparently Shell is the best one can get in this country. Even with the corrections I have noticed the 93 map seems to pull noticeably harder than the 91. |
07-24-2020, 06:11 AM | #1389 | |
Rep 8
There are 3 logs. First MHD stage2+ HPFP 102 RON map with e30 fuel https://datazap.me/u/jspbmwm140i/log...og=0&data=4-24 Second MHD stage2+ HPFP e30 map https://datazap.me/u/jspbmwm140i/log...og=1&data=4-24 Third MHD stage2+ HPFP e30 map https://datazap.me/u/jspbmwm140i/log...og=2&data=4-23 I think all is ok. Only I am worried about the boost (turbo health) Thanks!!! |
OzBMR574.50 |
07-24-2020, 07:25 AM | #1390 | |
Rep 585
Interesting that you tested the Stage 2+HPFP 102_95 map with E30. Thanks for sharing. Do you have Dragy? Any 100 - 200 km/h times?
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
07-24-2020, 07:58 AM | #1391 |
Rep 1,010
OzBMR Mate but why do you think the turbo not able to achieve boost target ?
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
07-24-2020, 08:12 AM | #1392 |
Rep 106
yea that looks strange...
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35) https://theone1973.imgbb.com/ |
07-24-2020, 08:50 AM | #1393 |
Rep 35
Hi guys, currently running mhd stage 2. Looking to buy the jb4 to run with mhd so would be doing a back end flash. I’ve downloaded the maps from the thread on n54tech. What map would I use for just standard 93oct fuel?. Says to use the ‘RACE’ one for just 93 but there’s multiple maps that say race. I’m looking To go WMI very soon. Is jb4 and mhd thr best route to go down?
07-24-2020, 11:24 AM | #1394 | |
Rep 8
With e30 fuel the map stage2+ HPFP e30 always gives more power that the map 102_95. But maybe the sensations are heavyest with the 102_95. For me is better e30 in that map |
07-24-2020, 11:28 AM | #1395 | |
Rep 8
There said more than 20 psi is dangerous. With stage2+ the boost is between 21 and 22. |
07-24-2020, 03:43 PM | #1396 | |
Rep 69
07-24-2020, 04:09 PM | #1397 |
Rep 281
Not put any in yet I’m afraid. Got a bit concerned with a few of the posts so order an ethanol test kit so I know exactly what I am putting in. Was pretty happy with that log with just the fuel to be honest much better than before.
Kit will likely be a few weeks as coming for USA but will post one I have the logs I’ll do a 93 tune before and after. |
07-24-2020, 06:10 PM | #1398 | |
Rep 585
Of course ignition timing is also important and the timing in the logs looks good indicating correct fuel for the tune. If you compare Purcel_Andorra logs to mine for the same map at same RPM points the values are almost identical for load actual and torque act. clutch Nm and indicate the car is achieving the required torque as per the tune.
07-24-2020, 06:31 PM | #1399 | |
Rep 585
If you are determined to use meth consider only using JB4 as the meth controller and forget about the JB4 BEF maps.
07-24-2020, 06:48 PM | #1400 | |
Rep 585
The stock ECU tune for M140i and M240i sees maximum boost of typically 17 - 18 PSI tapering to 12 PSI by redline. Fuel isn't limiting boost and hasn't for quite a while since DME flashing. If you are using the car for circuit racing where you are WOT lap after lap, using the Stage 2+HPFP tunes will likely result a shorter turbo life, but for most of us for street use I think the turbo will hold up OK.
fake_bimmer6.00 |
07-25-2020, 06:37 AM | #1401 | |
Rep 1,010
Yeah definitely I looked at the other parameters and they are looking good, just wondering why boost/load target not achieved ? I wonder if the turbo is maxed out or is it another reason as running a maxed out turbo is not healthy.
07-25-2020, 01:47 PM | #1402 |
Rep 8
Yes. I wonder if the turbo is maxed out too. There is the reason I am worried in this case
07-25-2020, 08:44 PM | #1403 | |
Rep 452
had about a quarter tank left of over of fuel, so I added about 7 gallons of E30, and topped off the rest with 93. reflashed stage 2+ map, and reset adaptations. also installed the new NGK plugs gapped at .022 https://datazap.me/u/aleksandersuave...og=0&data=3-22 Oddly enough..the plugs in my m240ix were already NGK 94201..identical plug and part number. Wasnt expecting that to be the case. What are your thoughts on the new log sir? Probably going to get the spool fuel analyzer soon. |
07-26-2020, 01:31 AM | #1404 | |
Rep 585
07-26-2020, 08:42 AM | #1405 | |
Rep 452
Just curious..did you also already have NGK 94201 plugs in your car? I was expecting to see something else stock. |
07-26-2020, 09:56 AM | #1406 | |
Rep 415
When replacing them a few months ago at 50,000 miles I pulled out NGK 94201
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
07-26-2020, 10:50 PM | #1407 |
Rep 82
Trying to figure out why my timing looks so bad. BM3 Stg 2 catless dp, just changed plugs and gapped to 0.022.
Log #1:https://www.bootmod3.net/log?id=5f1e...729b753dbae823 Log #2: https://www.bootmod3.net/log?id=5f1e...0b434801a15eef Bad fuel or something else?
2016 340i - BM3 Stg 2 - XHP Stg 3
07-27-2020, 02:37 AM | #1408 |
Rep 585
My car was built in 2016 and had Champion plugs from the factory
kern4174451.00 |
