BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Air pipe rattle
      12-09-2014, 05:29 AM   #1
Xplosiv166
Drives: F32 440i M Sport Plus
Air pipe rattle
Hi All,
Noticed a rattle coming from what looks like the air intake pipe, can somebody with a 330d check if they have the same issue? and or if they have a rubber clip or support stopping the pipe from vibrating, as mine seems to hang loose over the top of some metal pipe work
A video can be seen here helpfully showing the issue:
http://1drv.ms/1waY3k9
i am just wondering if maybe i can fix this, or maybe a part has fallen off??
Current: None
Previous:
E92 320d, E92 LCI 330d
F30 330d, F32 440i
      12-09-2014, 03:38 PM   #2
DTP1980
DTP1980's Avatar
Drives: M5 F10 LCI Monte Carlo Blue
Very interesting. Both our 335d and 435d have exactly the same rattle and it is very pronounced and, frankly, sounds cheap.
Initially I thought it was the actual electrical box that's directly above as I was able to stop the rattling when I pressed against the internals in much the same way as you did on the inlet pipe. However no matter what action I took to dampen it, it continued. I feel more convinced that the problem was just as you pointed out.
If it is the pipe, the fix should be really easy by sticking some Velcro (just the soft side) between the pipe and the electrical box. I shall do this on the weekend now. In fact, 435 in for a service tomorrow, so will make BMW investigate it too and see if we come to the same conclusions.
      12-09-2014, 04:33 PM   #3
teaston
Drives: X3 M40d
I just checked mine and i had the rattle too, not quite as pronounced as yours though.
So i pulled the pipe out (use flat head screwdriver to prise both side out) then stuck a strip of velcro (the fluffy half) to the top of the pipe and it's completely cured it!
Here the velcro with the pipe still out:
Iyrix100.00
      12-09-2014, 04:35 PM   #4
teaston
Drives: X3 M40d
And with the pipe back in:
      12-09-2014, 04:37 PM   #5
Xplosiv166
Mine is going back to the dealers, so we will see what they do.
if you turn the fans and radio off in the car you can also hear it, the design is piss poor, should have been a rubber section instead.
Your fix is probably going to be better than the dealer so i may cancel and do it myself (as i have a horrible idea that they may try something dumb, like cable tie), looks like the stuff BMW has used is either too thin or has not been applied correctly or wears out after a few 1000 miles
Just got to make sure that adhesive is strong and there is no way that can be sucked into the engine, although i am guessing the filter box will stop it, any other suggestions on fixing this??
Current: None
Previous:
F30 330d, F32 440i
      12-09-2014, 04:40 PM   #6
teaston
Drives: X3 M40d
if you turn the fans and radio off in the car you can also hear it, the design is piss poor.
If you look at my pics it appears BMW knew about the rattle and put some thin sticky felt type stuff on the corners, just not thick enough to do the job properly though!
      12-09-2014, 04:53 PM   #7
Xplosiv166
Hi,
Yep that is what i guessed, i wonder if that felt has a part number
I am guessing this is not a know fault as the stealer has asked to have my car for the day! i think i may fix this one myself.
Current: None
Previous:
F30 330d, F32 440i
      12-09-2014, 05:02 PM   #8
teaston
Drives: X3 M40d
Hi,
Tbh you might as well, it took me 5 minutes, in the dark!
      12-09-2014, 05:06 PM   #9
Xplosiv166
Hi,
only concern is that the Velcro could fall off and get sucked into the engine, maybe remove the BMW felt, clean the plastic with some IPA and then apply the Velcro or find something with some stronger adhesive. As i am guessing that the Velcro will eventually ended up
a) falling offf
b) beaten so flat that it needs replacing again
Current: None
Previous:
F30 330d, F32 440i
      12-09-2014, 05:18 PM   #10
teaston
Drives: X3 M40d
Hi,
a) falling offf
It's stuck very well, and with the bit that's still visible there should stop it from wanting to go inside the pipe. It's up to you though obviously.
      12-11-2014, 02:03 PM   #11
amaar_malik
Drives: Slammed F30 330D M Sport
Mine was loose, took it to the dealer and they tightened it with an extra clip. They told me it happened because my car was to low.. Clearly not !
      12-11-2014, 04:06 PM   #12
DTP1980
DTP1980's Avatar
Further to my earlier post, the 435 was checked for it's rattle - dealer said they'd fixed it and that it was caused by the airbox which had come loose!
      05-02-2018, 03:02 PM   #13
vadimo
vadimo's Avatar
Drives: 2014 F30 320D X-Drive
2020 M340i  [0.00]
i have this problem too what exactly do i have to remove to get to this pipe?
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
      07-13-2018, 03:28 AM   #14
TomJ79
TomJ79's Avatar
Drives: F31 330d
Bump - just discovered I have the same issue. Has the Velcro trick lasted?
      07-13-2018, 04:32 AM   #15
TomJ79
TomJ79's Avatar
Drives: F31 330d
Never mind...just used some 3M rubber tape, sticks like sh*t to a blanket although it’s quite thick so was a bit of a bodge squeezing it back in. Will wait and see how it fares
      07-13-2018, 06:05 AM   #16
evdok
evdok's Avatar
Drives: 330D M/SPORT xDRIVE INDIVIDUAL
Mines been doing it as far back as I remember, so thats the culprit
Happy Motoring
Evdok
      07-13-2018, 09:01 AM   #17
evdok
evdok's Avatar
Yep just like teastons photos
      07-15-2018, 05:09 AM   #18
evdok
evdok's Avatar
Just checked mine & it vibrates against the pipe running underneath it, a quick tug upwards has silenced it....for now
Happy Motoring
Evdok
      07-15-2018, 06:06 AM   #19
TomJ79
TomJ79's Avatar
Drives: F31 330d
Good to see the quality we all pay for shining through
Still, it gives me a chance to fix something simple on my car, which makes me think I know what I’m doing when it comes to engines. Which I most definitely don’t.
      07-15-2018, 07:38 AM   #20
Hooded
England
1669
Drives: F30 330d M-Sport
Ah yes, 40/50k for a premium brand car that needs tape to stop the doors creaking and Velcro in the engine bay to stop rattles ...nice!
Iyrix100.00
      07-15-2018, 05:37 PM   #21
evdok
evdok's Avatar
It kind of makes you feel quite unique
Happy Motoring
Evdok
      07-16-2018, 05:29 PM   #22
Colmsport
Drives: 320d M Sport
When do you get this 'rattle' & is a problem with all diesel F30's?
Reason I ask is that I've noticed a slight rattle on mine, typically it only happens for a few miles after start up & on a certain rev range - sounds almost like the air filter housing is vibrating...
