04-06-2015, 09:16 AM | #67 | |
Human
932
Rep 1,200
I'll check today and report back
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album 2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album |
04-06-2015, 10:27 AM | #68 | |
Human
932
Rep 1,200
They did order the incorrect version. PDC on the left, PMA on the right:
04-06-2015, 10:34 AM | #69 | |
Rep 1,136
I absolutely love Rheingold now that I got it working on my laptop, it has helped me with figuring out the problems I was having with my Park Assist retrofit. I wish mine were a simple sensor replacement, instead every so often I get both PDC and Park Assist malfunctions, and the code I'm getting is an "Ultrasonic Sensor: Short Circuit to B+ positive" error, but it isn't kind enough to tell me which sensor has the error. Instead, my test plan in Rheingold is that I have to remove both bumpers and go sensor by sensor through all 10, removing each one and running the test to see if it detects the fault when a particular sensor is removed, then reconnecting it and moving on to the next one. |
04-06-2015, 12:27 PM | #70 | |
Rep 1,035
04-06-2015, 12:57 PM | #71 |
Rep 1,136
That was my initial thought, but since its part of the test plan the system calculated, maybe it knows not to look for that sensor if the test is being run on it. I'll find out at some point this week. I think since my PDC was working fine before, I'll start with the two PMA sensors and test those since they are the easiest to access, if they aren't the cause then I'll have to wait until the weekend to drop the bumpers and test the others.
04-07-2015, 01:36 AM | #72 |
Human
932
Rep 1,200
Just a small update...
I confronted the dealer and told me that the PDC sensors work with the PMA system and that they are indeed the correct ones. Moreover they told me that initially the system worked, but somehow it got screwed up. I honestly don't understand how this could be true and why the PMA would suddenly decide that it had an incorrect version of sensor.
04-07-2015, 07:49 AM | #73 |
Rep 1,035
04-07-2015, 08:35 AM | #74 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
So there must be some difference in the sensor itself??
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
04-07-2015, 09:11 AM | #75 |
Human
932
Rep 1,200
That's what I thought.
Also, I don't think that the car would complain about a sensor version if they were inter-changeable.
04-07-2015, 09:26 AM | #76 |
Rep 260
I hope you sort this one out been following it.
Just as a note since you know where the PDC unit is you know they have now changed it with an updated version (Better camera and item detection graphics) - Apparently its the PDC unit not the camera. Also they have AUTO PDC for front now so you don't have to always turn the pesky front PDC on.... |
04-07-2015, 11:01 AM | #77 | |
Rep 1,136
05-10-2015, 04:17 PM | #78 | |
Rep 12
I already had my issue fixed with the help of Max from EleBest Pte Ltd (they sell the parts and install or help to install them) I updated my initial post with the complete info. Happy retrofits! |
05-11-2015, 09:47 AM | #79 |
Rep 41
i have done that one month ago ,F35 328GT .the customer need the front PDC kit , i think if you add the FA 508 then code the ICM ,the PDC button will be work .i have check the line's pin for the ICM it's right! so it's my opion
05-14-2015, 09:44 AM | #80 | |
Rep 42
Are the sensors interchangeable or not? |
06-24-2015, 08:37 PM | #81 | |
Rep 578
08-23-2015, 11:58 PM | #82 | |
Rep 176
08-24-2015, 07:27 AM | #83 |
Rep 176
Also when it comes to this:
Afterwards the modules need to be coded. The simplest way is "ESYS -> Expert -> Code" Select all ECUs and on "KIS/SVT Target" press "Detect CAF for SWE" E-SYS will calculate the changes needed for the new VO options Afterwards press "Code" and wait around 2 minutes Do you select each ECU individually or do you do it from the top level? |
09-07-2015, 07:59 PM | #84 |
Rep 578
finally had a chance to finish this project up... I'm having the same problem as the original poster, my console switch still isnt' working, would love to get that figured out.. Would be really helpful when pulling forward into parking spots. The switch lights up red when the lights are on but neither button works. I plan to add Top view & side view cameras so i went with the switch that supports that. I did exactly this... i double checked it...
The instructions state that a cable should connect pin 2 on the console to the ICM and on my car that was already connected. What the instructions are missing is pin 1 and in the end the connections should be: Centre Console <-> ICM PIN1 GN/GE(Green/Yellow) wire <-> PIN28 PIN2 GE/BL(Yellow/Blue) <---------> PIN6 should already be connected PIN3 <-------------------------------> PIN13 should already be connected few notes worth mentioning that hopefully saves some of you some steps... To remove the battery cover, there are (3) 10mm screws that only turns 1/4 of a turn to release, in this photo you can see i have the socket on the middle one, you will need to remove the battery cover to expose your way to through the firewall.. Now, the wonderful mistake i made that I thought i was saving so much time... When i was doing the reverse camera & rear PDC i thought I would save all this time by running the cables from the REM up to the front of the car & just rolling in a bundle until i was ready to do front PDC... boy was i wrong... The connector that connects to the PDC sensor in the front are not going to fit through the small round circle to get through the firewall... after staring at this for about an hour.. i remove all the panels, all the pins to the REM so i could pull the cable back through the car & start from the hood side... It was getting late in the day & i missed the grommet connectors twice & had the pull the cable back.. i was getting ill to say the least. You will have 3 grommets you have to go thru if you take this route... my finger in this photo is on the 1st one that you don't have to drill a hole through.. the next 2 you do... make sure you get the cable through the grommets at the appropriate time so you can avoid rework... ... this one has a hole already for the battery cover... once you run the cable thru it the battery cover is like a phillips head screw & can go right back in the same hole & not pinch the cable Here i'm pointing out where it goes thru the firewall Front photo of an msport with the different brackets holding the sensors. the msport bumper goes inward so the (2) 30mm brackets keep the sensor level instead of firing down to the ground... close up shot.. thought they came out great with this automotive paint.. way better than the brush on touch up paint... buy this stuff if your thinking about this project & need to paint your sensors.... I had (2) valencia orange sensor & (2) black sensors that i sanded down & repainted. It's worth noting... if you want OEM look you could go a step further & after drilling the holes you can paint the inside that was just exposed with the paint i suggest above... think about it this way, BMW dips their panels & they have predrilled the holes for the PDC sensors.. so those holes are same color as your car... i have a silver car so after i drilled the center of the holes are black... yes there is a black coupling ring but you will see what i'm saying.. the bracket keeps you from shoving the sensor all the way in the hole so unless you have a black car, you will see the newly drilled holes in your bumper unless you paint the inside of them.. i choose not too, still came out looking OEM IMO. After i got everything cabled up... i removed option 507, added 508 & VO coded the affected ECUs (which were FEM_Body, REM, HU_CIC & ICM). Wish my switch would work!!!!!! Anyone have any suggestions, i'm all ears!!!! Last edited by steelerfan; 09-07-2015 at 08:10 PM.. |
PauloP0.00 |
03-11-2016, 01:07 PM | #86 |
Rep 1,479
Al
03-12-2016, 09:37 AM | #88 |
Rep 23
Justo some questions:
I don't find the first item: Install.kit, Park Distance Control,front 66202338070 1x Where do you buy it? This item include: 61 13 1 367 599 Cable tie 61122334361 Retrofit cable set, PDC front 1 $89.07 01 29 2 338 017 Installation instructions1 $0.00 66 20 6 923 000 i Decoupling ring PDC torque converter4 $1.99 The 61122334361 Retrofit cable set, PDC front 1 $89.07 Don't included the Cable Set Front bumper 61129260019???? Thank you. |
