02-28-2020, 10:06 AM | #1 |
Yiolli
26
Rep 119
BMS Tune Motivation Thread N20 N26
Let's see who has survived with the a BMS jb or jb4 the longest without serious problems in their F30/F32 N20 N26!
This will serve to motivate more members to tune and also relieve my anxiety over my brand new jb! Also can help by knowing what issues people have had so we can get ahead of them How long have you been running your tune and at what mileage? Think any maintenance resulted from the modifications? Any tips / suggestions? Thoughts on performance? |
02-28-2020, 10:25 AM | #3 |
1296
Rep 3,533
Wrong forum buddy.. and i have zero plans to run a jb4 for anything lol
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
02-28-2020, 10:41 AM | #4 |
Yiolli
26
Rep 119
02-28-2020, 11:12 AM | #5 | |
1296
Rep 3,533
I mean the main reason to not use a JB4 is that software solutions are vastly supperior... soooooo what else is there?
02-28-2020, 11:29 AM | #6 |
Rep 237
Sounds like you don't have much understanding about tuning. Jb4 is a piggyback, something that modifies signals in and out of the ecm. It works, but is arguably a half ass way to do it. Modifying/flashing the software at the ecu is the correct way. The only situations I see where you would piggyback over flash is if your under warranty, if flashing is not available, or if you needed a specific feature on the jb4 not currently available in bm3 or mhd.
Before you do any sort of tuning/adding power you need to make sure your fluids are maintained/clean. I used to think this went without saying but I couldn't be further from the truth Just based on your thread here, you should do some more googling and searching the forum for the numerous other threads that will help you gain the knowledge you need. If you have anxiety over the platform you chose, you made a mistake somewhere or didn't fully research or comprehend the information |
02-28-2020, 12:13 PM | #7 | |
Yiolli
26
Rep 119
So personally it doesn't matter to me that I could have a flash tune that's more smooth with power delivery, etc. For me the question is "am I more likely to spend money on car maintenance if I use a piggyback vs flash ?" Please let me know if my thought process is utter trash! Also reducing my oil changes to 5k miles. Any other fluids you would keep at eye on at 51k miles? |
02-28-2020, 12:22 PM | #8 |
Yiolli
26
Rep 119
I have a JB which is $390 and there's no work required. What price range are you comparing as vastly superior?
02-28-2020, 01:59 PM | #10 | |
Rep 237
You would end up doing the same maintenance tuning either way. But I can definitely recommend, being a mechanic, you change the trans and all driveline fluids if your keeping the car for a long time. If your xdrive that includes transfer case and front diff as well. My rear diff fluid was garbage at 3yr/22k, surprisingly. The 8hp fluid was slightly darker than new, and the 4 magnets in the pan were lightly dusted with shavings. I do 3000mi oil changes personally, but that's because fluid maintenance is nothing compared to replacing powertrain assemblies. We have had a couple dead n20/26 engines come through the shop in the past year so if you don't already change your oil yourself, you could do that to make up the extra cost of lower mileage intervals. I could go into more specific supporting mod stuff but I have n55, and was already established this is in the wrong section best of luck though, tune smart, maintain your car like it's the space shuttle and it should reward you with far less headache and money out of pocket over the course of ownership. |
Yiolli25.50 |
02-29-2020, 08:10 AM | #11 |
1296
Rep 3,533
02-29-2020, 08:22 AM | #12 |
Yiolli
26
Rep 119
02-29-2020, 10:05 AM | #13 |
Yiolli
26
Rep 119
But then we're changing software. Isn't there something to be said about having the piece of mind of getting some extra performance without changing too much about your car?
I'll admit I don't know much about the ECU but it feels like a risk to be changing software. Not to mention warranty Also is it really vastly superior stage 1? Or is it just slightly smoother, more options for later. |
02-29-2020, 10:20 AM | #14 | |
Rep 1,105
02-29-2020, 02:09 PM | #15 | ||
Yiolli
26
Rep 119
02-29-2020, 02:30 PM | #16 | |
1296
Rep 3,533
02-29-2020, 04:26 PM | #17 | |
Rep 949
Yiolli25.50 |
02-29-2020, 04:33 PM | #18 | ||
Yiolli
26
Rep 119
02-29-2020, 07:36 PM | #19 |
Rep 949
03-01-2020, 10:28 AM | #20 |
Rep 461
I've had jb4 for a little over a year. No complaints related to reliability. The only complaint I had was with daily drivability. Boost would kick in hard like there was a on/off switch.
I bought the mhd flasher and uploaded the BMS back end race flash. Now it's a dream to drive. Just like stock but way faster. Also the linear throttle function that mhd has is awesome and made the purchase worth it just for that. BMS support has been great as well. Best of both worlds especially if you already have a JB4 and want a better running car and dont want to fork out the money to fully switch tunes. |
03-01-2020, 10:32 AM | #21 | |
Yiolli
26
Rep 119
03-02-2020, 04:23 PM | #22 | |
Yiolli
26
Rep 119
Was in ECO PRO.....and I stepped on it to merge into the middle lane (morning rush hour) and the car MOVED like I've never seen before in eco pro. It's like the boost just came out of nowhere once your foot goes past a certain point EDIT: this is NOT a complaint. Nice to feel it working |
