12-31-2019, 09:59 AM | #419 | |
Rep 7
I am definitely going for the European version, not the Chinese one. If you can send me the instructions with pin identification required to identify the correct cabling, that would be great. I am going to do the same and get some wire taps to avoid cutting the cables. All the best for the New Year! |
12-31-2019, 10:01 AM | #420 | ||
Rep 139
12-31-2019, 10:14 AM | #421 | |||
Rep 139
SLI Pin 10 (Red - 12v) ======> A71*1B Pin 1 SLI Pin 5 (Black - GND) ======> A71*1B Pin 7 SLI Pin 9 (Yellow - CAN1 H) ======> A71*1B Pin 6 SLI Pin 4 (Blue - CAN1 L) ======> A71*1B Pin 12 |
01-10-2020, 07:43 AM | #423 |
Rep 740
Dont think so since the speed limit info is on the map data.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
01-11-2020, 02:30 AM | #424 |
Rep 56
I am talking about HU_ENTRYNAV, that is with navigation, and not HU_ENTRY that is without navi.
I found on a german forum someone who claim he retrofitted chinaclone on a car with hu_entrynav, I just wanted a second confirmation. https://www.f30-forum.de/index.php?t...sten/&pageNo=1 Anyhow, I have ordered the emulator from ebay, I will keep you informed if it works or not. But delivery from China is not so fast, can take up to two months. |
01-12-2020, 01:21 PM | #426 |
Rep 843
01-29-2020, 02:28 AM | #428 |
Rep 31
Hi guys, SLI adapter some of you use made in Romania is manufactured by my company since 2015, i was pointed to this thread by a customer so just let you know i am also available here to answer your questions or offer support.
x-m4n148.00 |
01-29-2020, 04:29 AM | #429 |
Schmollbraten
12509
Rep 1,985
Thats cool Adrian, now since 2015 as we had phoned the last time at installation
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
02-09-2020, 01:55 PM | #430 |
Rep 143
SLI Emulator Without KAFAS
I would like to thank everyone on this thread for all the info that helped me do this mod.
So I'd like to contribute what I can as well. I initially ordered the Chinese module from Ebay, and while the numbers were correct, I wasn't happy that the graphic was the red/white European circle (I live in the US). So through this forum I found our friend Adrian's website and purchased his module too. I will say that his module not only works exactly as you'd expect (correct graphics and speed readout), but it also does the overspeed graphic that some of you have asked about. Also the module itself is a bit smaller and easier to stick behind the cluster. The only negative about the box from Romania is that it comes with bare wires, and you're meant to splice them into your car's wires. I decided I wanted a less intrusive solution, so I combined the best of the two modules, wiring from the Chinese one, and the actual circuitry/box from the Romanian one. This way it made it plug-and-play. Which is nice if I ever want to unplug it. Here are some photos: Chinese Ebay Box with harness cut off Romanian box spliced up to the harness from the Chinese box (Blue/Black and Yellow/Black wires were not used in my case because I don't have a KAFAS camera or module) Finished harness and module wrapped in Tesa tape, ready to plug into the car's current connectors Speed graphic and the overspeed line (deeper red under the needle) in Comfort Mode Speed graphic and the overspeed line (deeper red under the needle) in Sport Mode Regarding coding: I don't recall if it was in this particular thread or another (I've perused so many forums about this) someone mentioned that the way to go for this mod is NOT to VO code 8TH, but to just FDL code a couple of parameters. I fully agree with that assessment. VO coding, if you don't have the hardware that the car expects to see (KAFAS), will throw out errors. After initially having VO coded 8TH, I reversed it (removed it from SALAPAS), and instead only changed the following codes: Code:
HU_NBT2: SPEEDLIMIT_INFO aktiv DKOMBI: SPEED_LIMIT_GENERATION sli_gen_2 KI_PIA_SPEED_LIMIT aktiv Sorry for the lengthy post, but hopefully this helps anyone venturing into this mod. Take care! Last edited by EvntHrzn; 02-09-2020 at 08:47 PM.. Reason: Wording |
02-10-2020, 12:09 AM | #431 |
Rep 31
Indeed our adapter does not have a PnP wiring option mainly because it has many functions which requires different wiring scenarios depending on car configuration.
Also, for us, this is an universal module for which we developed many software applications that can be used for retofits not only in BMW cars but also in Mercedes Benz cars. Depending on firmware loaded on this module it can be used for NBT/EVO activation on donor VIN, Sport Display data conversion, Night Vision system activation on donor VIN, PDC and TRSVC protocol conversion for CIC retrofit in E7x series and some specific data conversion for some retrofits for example protocol conversion when NBT/EVO system is retrofitted with KAFAS1 present in car, HBA protocol conversion in pre-LCI cars when ZGW is upgraded to ZGW-02 4/8 SK, ZBE5 to ZBE4 protocol conversion when Gxx iDrive controller is retrofited in Fxx cars and more. Also for this adapter hardware we developed firmware for alarm system notifications, in cars with DWA (factory alarm system) adapter is able to detect CAN data when alarm is triggered and send out a control voltage that can be used for SMS notifications with 3rd party GSM tracking systems.
Current cars: 2016 F13 640XD ; 2017 F36 420XD
Past cars: 2010 E93 320i ; 2008 E60 530XD ; 2006 E90 320D |
EvntHrzn94.00 |
02-18-2020, 04:05 PM | #432 | |
Rep 129
02-21-2020, 11:16 AM | #433 |
Rep 83
i ordered the one from aliexpress
https://www.aliexpress.com/item/3288...35404c4diXGIpQ works perfect on 6WB in my 2018 F36 once above speed limit, the tacho gives a red area under the needle |
02-22-2020, 05:58 PM | #434 |
Rep 2
I have read the whole thread ... yes really!
What I would like to know (because no one has said so) is ... If I use a Chinese Emulator, apart from the KPH graphics problem, will the display read MPH units AND KPH units if I switch my display settings to either? I will be travelling Europe but live in the UK so I want to be able to switch between the two when I want. Would appreciate any answers ... |
02-23-2020, 04:03 AM | #435 | |
Rep 139
If you can switch your speedo to read kph the speed will then show as kph. Hope this makes sense. |
02-23-2020, 05:21 AM | #436 | |
Rep 2
I have HUD so won’t display SLI on instruments, just on the screen so no problem! |
02-23-2020, 05:25 AM | #437 | ||
Rep 139
03-01-2020, 10:04 AM | #438 |
Rep 30
I have only one question? Does it work with F30 CIC 10.2012 with Business Navigation 6.5” maps MOVE 2019 and 6WA cluster and HUD.
I think is a HU_CHAMP2 Last edited by Suprnowa; 03-01-2020 at 10:12 AM.. |
03-01-2020, 01:42 PM | #439 |
Rep 139
03-09-2020, 11:25 AM | #440 |
Rep 766
