07-31-2017, 09:22 PM | #1 |
Rep 625
N55 P112E Code?
Anyone have any idea why I am getting this code / how to fix it??
I have been noticing horrible low end power.... could this be the issue?? Ive searched around and havnt found aything on it yet.. P112E - Manifold Absolute Pressure to Throttle Angle - Too Low (Bank 1) Google results say possible faulty sensor ... (which one ) Any help would be appreciated |
08-01-2017, 09:52 AM | #2 |
Rep 6,990
Yes, it sounds like you may have a boost leak somewhere between the turbo and the throttle body. Low intake pressure usually indicates that condition. It could also be a TMAP sensor, near the throttle body, but a cracked charge pipe is the most common issue.
08-01-2017, 10:16 AM | #3 | |
Rep 625
I have a replaced charge pipe though with a VRSF one.... I've double checked the silicone bracket before but I'll do it again ... Any other symptoms of a bad sensor? That's what I'm thinking.... It's also not consistent about the lack of low end power... some days it's good some days it's bad |
08-01-2017, 12:49 PM | #4 | |
Rep 6,990
08-01-2017, 06:24 PM | #5 | ||
Rep 625
Just daily driving is horrible at times and I get honked at every red light cause it takes me forever to get moving !! A Ford Focus is faster then me off the red light -.- |
08-02-2017, 06:44 AM | #6 |
Rep 6,990
Again, the mechanism that opens and closes the wastegate may not be operating properly. If you have the pneumatic model, it could be a deteriorated vacuum hose; if you have the electronic model, it may not be responding properly or not calibrated. Best to have it checked at a qualified Indy shop or a dealership.
08-02-2017, 06:21 PM | #7 | |||
Rep 267
08-02-2017, 10:08 PM | #8 | ||||
Rep 625
08-03-2017, 07:28 AM | #9 |
Rep 6,990
Wait...that sounds like "limp mode". You definitely need to get that looked at. Does your car have the M-Sport package? I've had something similar happen due to a faulty auxiliary cooling radiator/fan assembly (which is only on M-Sport models), but the code that threw was different. I still think you may have something wrong with your wastegate actuator.
08-03-2017, 08:22 AM | #10 |
Rep 775
Let us know what the dealer / mechanic says.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
08-03-2017, 10:24 AM | #12 |
Rep 625
Haven't gone to a dealer yet (no warranty)
I'll have to find an Indy that is good around my area (Chicago)!!! And see like if I do a trans adaptation reset (through the BMWAI coder app)... it'll work better for a few days!!! If I punch it I have good power just daily driving I can barely move and rev high as hell :/ I'm gonna try cleaning MAP and MAf sensor and see what happens (recently replaced MAF but had same issue before anyway) |
08-14-2017, 06:28 PM | #13 |
Rep 625
Update....
Replaced MAP sensor and same problem!! Any ideas here? Can't go to mechanic until Thursday and it's a nightmare to drive my car and am wasting fuel like crazy.... quarter tank every 100 miles |
09-27-2017, 12:48 PM | #15 |
Rep 488
"Manifold Absolute Pressure to Throttle Angle - Too Low (Bank1)"
The fault is recognized when the relationship between the indicated intake manifold pressure and the mass airflow calculated based on throttle-valve angle is not correct. Potential problem source(s): - Measured value for intake manifold pressure (absolute) is too low - Defective plug or wiring harness - Vacuum leak within induction tract/crankcase - Incorrect throttle-valve angle - Pressure sensor defective ------------------------------------------------------------------- Check intake system and crankcase for leakage - Check throttle valve (contamination, carbon deposits, icing) - Check wiring harness between intake-manifold pressure sensor and DME - Check plug, wiring harness at electric throttle-valve actuator - Replace pressure sensor - Replace throttle valve
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
ronanz1819.50 |
09-27-2017, 12:55 PM | #16 | |
Rep 625
Last thing left is replace throttle body... I know my battery is bad... could it be causing these issues |
09-27-2017, 01:10 PM | #17 |
Rep 488
Did you check for leaks using a pressure or smoke test? Inspected every centimeter of the wiring harness to make sure it's not damaged somewhere? I'd want to verify all of that before spending that much on a new TB. Maybe just some TB cleaner is needed? Is the TB gunked up and not opening/closing all the way? I wouldn't think battery has anything to do with it.
09-27-2017, 03:35 PM | #18 | |
Rep 625
I replaced both map and tmap already |
01-05-2018, 10:23 AM | #19 |
Rep 345
What was the fix
izaazk - did you ever get this resolved? my 335 is having the same issue and can't seem to locate the fault anywhere. I did replace the boost solenoid a while back and the new one is making the same noises as the old one. Not sure if this is connected or not.
01-09-2018, 11:11 AM | #20 |
Rep 625
I never resolved it man... i gave up and traded out the car... i took every avenue and just thought it might be the DME at the end of the day
01-10-2018, 10:13 PM | #21 | |
Rep 345
