BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Forgot drainage?
      08-21-2019, 09:01 AM   #1
BWbimmer
BWbimmer's Avatar
Drives: BMW F36, E36, E93
Forgot drainage?
Why ist this happening and is in only on my car? I expected som dainage holes?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required
      08-21-2019, 10:51 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Mine is the same way, they probably decided that it wasn't worth the bother when evaporation would do the same job. It's not like there's anything that will rust.
      08-21-2019, 12:40 PM   #3
Machinebuilder
Machinebuilder's Avatar
279
Drives: 640 IX GT
It is a strange design but there are no drain holes. And they use it on many models. Their engineers must have their reasons but its is odd.
      09-02-2019, 06:02 AM   #4
Skyhigh
Skyhigh's Avatar
1879
Drives: BMW F36
Has been discussed around here before. (If someone finds the link, please post it).
Bottomline:
- Design is as is, as the same plastic molding is used both for LH and RH vehicles (reversed wipers)
- No drain holes is a weird design decision, but a fact
- Some users have drilled holes in there with no negative effect observed.
I am inclined to do the latter, but would like to know what is underneath and whether the water has a safe path out...?
      09-02-2019, 07:47 AM   #5
Billfitz
Billfitz's Avatar
And there's the rub. Water on plastic, no harm done. Water on metal = corrosion.
      09-15-2019, 08:12 AM   #6
RAK92
Drives: 2016 435i Coupe M Sport
Yep, this is normal. There are no drain holes. Again, someone posted a pic with a hole drilled into the plastic to allow the water to drain. I just don’t know what’s underneath so not sure if that’s a safe option.
Every time I was my 2016 435i, after rinsing, I immediately open the hood and take an old towel and blot out the pooled water in those areas first. It’s not just become a habit to get that water out.
      09-25-2019, 05:00 AM   #7
1QuikWS6
No 55mph
1QuikWS6's Avatar
1619
Drives: F32 435ix MSport
I drilled a hole on my 435 - the water will then drain down to the lower piece of plastic exactly where the little 'funnel' is that directs rest of water down thru the normal drain route to underneath the car
Been that way for yrs, no harm done, there is nothing in the path of the water draining that will get damaged
Just because BMW didn't put one there originally doesn't mean that putting a hole in is a bad thing - there is a TSB out for the very bottom drain vent that BMW DID put in that needs to be removed due to the fact that it clogs and water will NOT drain completely - so it's not like BMW engineering is foolproof
      09-25-2019, 04:12 PM   #8
Skyhigh
Skyhigh's Avatar
1879
Drives: BMW F36
Could you provide a photo of your drainage?
      10-17-2019, 07:22 PM   #9
sunshine235
Drives: 2020 BMW 440i xDrive
You mean none that YOU CAN SEE!! Yes, it is there.
      10-17-2019, 07:24 PM   #10
sunshine235
I see LOTS of RUST!!! Better take care of that!!!
      10-17-2019, 09:33 PM   #11
Billfitz
Billfitz's Avatar
Since when does plastic rust? All I see is dirt.
      10-21-2019, 08:27 PM   #12
EDWYER
Yoda of mods
EDWYER's Avatar
1670
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
It is dirt. He is mistaking the reflection on the left side for rust.
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      11-12-2019, 05:32 PM   #13
ian332isport
ian332isport's Avatar
Drives: F31 340i Shadow Edition
My F31 has drainage slots/holes from the factory. September 2018 build.
      11-13-2019, 04:12 AM   #14
Skyhigh
Skyhigh's Avatar
1879
Drives: BMW F36
Photos please.
      11-13-2019, 03:44 PM   #15
ian332isport
Originally Posted by Skyhigh View Post
Photos please.
I'll snap some pics if it ever stops raining.
      11-14-2019, 07:29 AM   #16
ian332isport
Here you go.
      11-21-2019, 02:01 AM   #17
Skiddz
Drives: 2021 X4 MC
^^^^ interesting. Are the holes connected to anything underneath (such as a drain tube), or does it openly drain onto the "shelf" and wire harnesses before eventually draining onto the ground normally?
      11-22-2019, 03:05 PM   #18
ian332isport
I'll have to check, but I think it just drains onto the "shelf" underneath. Certainly nothing like a drain tube connected to them.
