BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Replace transmission at 50k?
proTUNING Freaks
      02-22-2020, 12:57 PM   #1
daryl rsv4
Drives: BMW 435i
Not what I wanted to hear but that was the diagnosis of my 14’ 435 Msport yesterday at SSR. Car has stage 2 bootmod, VRSF catless down pipe & VRSF chargepipe. Car has been tuned since 18k, now has 54k. I do not beat on my car and am pretty good about routine maintenance (oil changes every 3k). I have had an O2 sensor that has been bad for the last 6 months that I have neglected, but the reason I made the appointment at SSR along with changing my spark plugs. I have experienced bogging, sluggishness at times but attributed it to the O2 sensor and plugs. I have to take the day off of work when I make the 50 mile drive to SSR as is typically an all day affair (with traffic to and from).
Transmission code present for slipping. Damn. Used transmission (3 month warranty) + labor + O2 sensor (couldn’t get one yesterday) =$3500.
Thoughts?
      02-22-2020, 01:00 PM   #2
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
whats the code for slipping?
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      02-22-2020, 01:11 PM   #3
daryl rsv4
Drives: BMW 435i
I’m looking at my invoice and it doesn’t state the codes. He (tech) showed me on his hand held and I don’t remember. I just texted him to ask specifically what codes they were.
      02-22-2020, 04:38 PM   #4
5soko
5soko's Avatar
333
Drives: M5
I wonder if bm3 uses tq scaling on their tune only option, and also wonder if their tcu tune is scaling just ecu tq or an a actual tcu tune
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      02-22-2020, 05:38 PM   #5
ctt300
Drives: F30 335i
Does it feel like it’s slipping, do rpms jump? I highly recommend a second or even a third option in cases like this. I wouldn’t trust that diagnosis. These transmissions are very stout and can take quite the beating. Guys track their cars without issue.
Bogging down isn’t generally going to be a trans issue, but surely an engine issue, like maybe bad plugs, replace those if haven’t already. Do you have the stock air box or another cone filter deal?
Replace the bad O2 sensor, clear codes and drive to see if you still feel the bogging issue. When is that occurring -any more details?
      02-22-2020, 08:13 PM   #6
thejeremyman9
thejeremyman9's Avatar
4361
Drives: 2015 BMW 335i
This was my first thought - wondering if he had micro slip in 3rd/6th and after running the tune for a decent amount of time, just wore out the trans.
Also agree with other posts that you should fix the known issues, clear all codes, and try driving the car a bit more.
      02-22-2020, 08:59 PM   #7
daryl rsv4
Drives: BMW 435i
It sometimes feels clunky. If I stop at a stop sign and then try and accelerate it will have no power. For whatever reason, whenever I turn left
(I’m assuming because im off the gas) and then try accelerate, it’s clunky with no power. The other night I was entering a downhill right hand on ramp onto the fwy, (the same one I take every night) going home from work, and usually by the time I get to the bottom and entering the fwy, it feels like I’m in 8th gear and the car has no power, so I have to get off the gas and get back on. This particular night, i get off the gas and get back on, and the car accelerates but the rpm’s stay high (5.5k +) and don’t back down, so I hit the gas again to try kick the rpms down and they stay high. I then got a drivetrain malfunction message on my display. I let the car decelerate and the rpms stay up so I get off on the next exit and pull over, put in park and turn the car off and let sit for few mins. Start the car and everything seems back to normal.
Again, I attributed everything to the 02 sensor/ plugs until I got the drivetrain malfunction message. I did have my plugs changed when I was at SSR on Friday. I have the stock air box btw.
I appreciate everyone’s input..
      02-23-2020, 09:03 AM   #8
ctt300
Drives: F30 335i
This particular night, i get off the gas and get back on, and the car accelerates but the rpm’s stay high (5.5k +) and don’t back down, so I hit the gas again to try kick the rpms down and they stay high. .
Yeah, that sound def like trans slipping? Did you just buy this car? Is it from a big dealer or private person? I’d be telling them something..
      02-23-2020, 10:12 AM   #9
daryl rsv4
Drives: BMW 435i
No, I have had the car since Jan 17’. Picked it up as a CPO w/ 14k..
      02-23-2020, 11:57 AM   #10
thejeremyman9
4361
Are you Xdrive and how often have you launched it?
      02-23-2020, 03:34 PM   #11
ctt300
Drives: F30 335i
Try getting a goodwill repair from BMW NA since it’s at what 65K miles now?
      02-23-2020, 04:12 PM   #12
daryl rsv4
Drives: BMW 435i
No, rwd..
      02-23-2020, 04:13 PM   #13
daryl rsv4
Drives: BMW 435i
What’s a goodwill repair? I’m at 54k..
      02-23-2020, 07:00 PM   #14
ctt300
Drives: F30 335i
Goodwill repair in the warranty world is repairing or reimbusing for repair just outside the warranty window of time/miles. BMW and other manufacturers will take care of failure costs when this occurs. They do advertise their lifetime transmission fluid life, so I'd stick em' to it.
You have nothing to lose ad it is only fair that this is covered by them.
harkes1077.00
Rebound152.50
      02-23-2020, 07:25 PM   #15
daryl rsv4
Drives: BMW 435i
End of last summer when I took it to the local BMW dealer for my radiator fan, they covered it as it is a CPO. That’s right when I got the CEL (O2 sensor) and they wouldn’t touch it because of the tune. I highly doubt they’ll do anything about the transmission..
      02-23-2020, 07:33 PM   #16
ctt300
Drives: F30 335i
Ha, tell them that the manufacturer has to prove that the mod caused the failure per the Magnuson-Moss Warranty Act. Be prepared to contact an attorney to fight for your rights though...
https://en.wikipedia.org/wiki/Magnus...s_Warranty_Act
      02-24-2020, 03:50 AM   #17
harkes
harkes's Avatar
China
1077
Drives: M135i, E39 M5, NSX and AE86
Magnuson-Moss bla bla bla... Who in here is ready to face BMW Corp in court if they dont want to comply. Hardly anyone I'd think - and BMW (and any other car manufacturer) knows this. In real life that Warranty Act isn't worth anything - sadly.
(A Dane in China)
Poochie9104.50
      02-24-2020, 04:29 AM   #18
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
End of last summer when I took it to the local BMW dealer for my radiator fan, they covered it as it is a CPO. That's right when I got the CEL (O2 sensor) and they wouldn't touch it because of the tune. I highly doubt they'll do anything about the transmission..
It's cute how that Magnuson-Moss Warranty Act always gets thrown around here, like it's gonna magically make a dealer shake in their boots and give in to any of your unjustifiable demands.
Are your pockets deeper than BMWs? If not, then threatening them with meaningless nonsense, like Magnusson Moss, is as effective as praying..
      02-24-2020, 08:19 AM   #19
Korvo
Respect My Authoritah
Korvo's Avatar
Drives: 2014 335i M-Sport
This forum should have an "autobahn" feature for anyone that mentions Magnuson-Moss.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
      02-24-2020, 11:10 AM   #20
thejeremyman9
4361
One other thing not mentioned yet here, if you really think the trans is bad anyways, is you could try flash XHP and see if it makes a difference.
Other than that, you can try the goodwill warranty route, as it does hurt to ask. A friend of mine got his motorcycle engine covered under that (parts only) when it dropped a valve about 300 miles outside of warranty during normal driving (he had video to prove it). Maybe try a different dealer you didnt go to with the tune? (Did you actually go in with the tune still on, or did you remove and flash back to stock and they detected it anyways?)
      02-24-2020, 11:40 AM   #21
daryl rsv4
Drives: BMW 435i
I went in with the tune as my radiator fan took a shit in 90-100 degree So Cal weather and needed to get in ASAP and didn’t get a chance to flash back to stock.
I’m going to get another opinion/ estimate today.
What would be the better option, rebuild or swap with a used trans?
      02-24-2020, 12:39 PM   #22
daryl rsv4
Drives: BMW 435i
The codes were 4204C-1 gear ratio monitoring in fixed gear, clutches C &D disrupted.
