11-06-2019, 04:34 PM | #2994 |
Rep 40,733
PM sent.
11-09-2019, 09:27 PM | #2995 |
Rep 23
Hi Shawnsheridan,
Can you please send me the latest PSDZdata files? I can't believe I need to code to replace my battery :-/ Thanks so much! |
11-09-2019, 10:05 PM | #2996 |
Rep 40,733
PM sent.
11-14-2019, 02:59 PM | #2998 |
Rep 40,733
PM sent.
11-14-2019, 04:18 PM | #3000 |
Rep 40,733
PM sent.
11-14-2019, 08:08 PM | #3001 |
Rep 7
Hi Shawnsheridan
I'm having issues with Token and esys - Pin incorrect every time I have run scripts, changed dates, changed laptops to no avail. Can you send me a link please to the latest software for me to try that? Thanks a million Dobbie |
11-14-2019, 08:10 PM | #3002 | |
Rep 40,733
http://tokenmaster.blogspot.com/2019...r-pro-282.html
11-14-2019, 08:45 PM | #3003 |
Rep 7
Hi Shawn,
I'm using 2.8.2 but keep getting incorrect pin, I have tried running rearm script (resets token) and moved the date to 2018 (for this version) but still incorrect pin when I try and code Dobbie |
11-14-2019, 11:00 PM | #3004 | |
Rep 40,733
11-15-2019, 08:03 AM | #3006 |
Rep 40,733
PM sent.
11-15-2019, 04:16 PM | #3007 |
Rep 5
Shawn, you have been so helpful in the past both through your posts over the years and you even helped me in person once and i was panicing because my engine wouldnt start. anyway I'm really in a pickle here. I have no head unit or display, basically.
I really need help i have searched until my fingers and eyes have bled. I have done something to cause my display to do show nothing but "No Signal". (even after the car is turned off.) I tried to vo code the original back it was missing the CAFD for NBT2. when i went to vo code it back, trying every one of the 6 available detected CAFDs I was getting an error "VCM-Update is deactivated. VCM will not be updated." but I managed to get rid of that by enabling the two options update TAL and MSM processing and somehow that got ride of that. The only remaining issue to figure out is why I have no display and how to FDL or VO code it back to working order. when I try, the [Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on IHKA (the ECU itself not the underlying CAFD) => Select CODE.] this is the error that i get [HU_NBT2 - 63] - [Exception - HU_NBT2 - 63] job failed with negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; ECU: HU_NBT2_63_ETHERNET severity: ERROR I am able to fdl code and VO code all other modules just fine now that i got rid of the "VCM update is deactivated", just not able to fdl or VO code anything in the HU_NBT2. Please help ! :-( (also Please send me the above PM as well, I am going to load the E-SYS pro onto my main computer. I am going nuts with using the win 7 VM and constantly changing the date back.) 2016 BMW 540i Xdrive build date July 2015 Thanks in advance. Last edited by AlphaGeeky; 11-15-2019 at 04:35 PM.. |
11-15-2019, 04:41 PM | #3008 | |
Rep 40,733
11-16-2019, 04:57 PM | #3009 |
Rep 11
PSdZ Update
Trying to remove SOS Call Malfunction error on 2015 F30 because I disconnect TMB antenna. New software updated at dealer now causes error to show constantly on the dash and cannot dismiss it.
Have I-Level F020-19-7-539. E-Sys 3.27.1 and Pro launcher 2.8.2.162 with PSdZ 63.3. Getting CAFD file not found errors when reading SVT, determined I need newer PSdZ and maybe E-sys versions? Can you help with either? Thanks 2015 F30 No Nav These are present; S6ACA Intelligent Emergency SOS Call S6AEA Teleservices S6NHA Handsfree With USB Interface |
11-16-2019, 05:03 PM | #3010 | |
Rep 40,733
11-16-2019, 07:10 PM | #3011 |
Rep 11
Thank you!! Data file caused two entries that show up now when connecting in E-sys now,
F020_19_07_562_V... F020_19_11_534_V... Assume choose the 19_07 since my I-Step is F020-19-07-539 ? Also getting E-sys lockup when activating FA, green bar keeps advancing and repeating but never completes. E-sys without loader it activates in a few seconds, with loader nothing. Also getting the "Loading: E-Sys Launcher PSdZ API Module Failed! Error C:\ProgramData\TokenMaster\E-Sys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries." error |
11-16-2019, 07:16 PM | #3012 | |
Rep 40,733
Replace your E-Sys Launcher PREMIUM with this PRO version: http://tokenmaster.blogspot.com/2019...r-pro-282.html
11-16-2019, 10:28 PM | #3013 | |
Rep 11
I have I-Level F020-19-7-539. E-Sys 3.27.1 and Pro launcher 2.8.2.162. D/L from tokenmaster site. I will try a remove/re-install of the Launcher. Edit: Tried remove/re-install launcher. Same error "Loading: E-Sys Launcher PSdZ API Module Failed! Error C:\ProgramData\TokenMaster\E-Sys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries." Last edited by rabbitf30; 11-16-2019 at 11:35 PM.. |
11-17-2019, 01:23 AM | #3014 | |
Rep 7
