04-11-2019, 09:35 PM | #1 |
Rep 77
Access to rear damper adjusters
Anyone ever try to install the remote rear damper adjusters on the F30? KW SC adjusters are at the top but bolts are from the bottom unlike other shocks I've installed whick unbolt from in the trunk. I found a video and took a screen shot showing there is hole above the shock that looks like would go into the trunk. I'm going to pull the trunk liner before I get them installed and see if it's possible.
And if there is no access through the trunk from some other obstacle I found these from tckline. Might be hoky though. Last edited by daac; 04-11-2019 at 10:40 PM.. |
04-12-2019, 07:52 AM | #2 |
Rep 8,500
This is one of the big disadvantages of dampers such as KW which use independent adjusters for compression and rebound, but which are located at different ends of the dampers. It's not too much of a problem for the fronts (because the adjusters can be accessed from inside the engine bay) but getting to the rear top adjusters is a PITA.
It's one of the main reasons that I avoided KW (and ACS rebranded) and looked at Bilstein and Ohlins - adjuster(s) are at the bottom of the damper body.
cfm56d7b5886.00 |
04-15-2019, 09:01 AM | #4 |
Rep 891
There is a plastic cap on top of the OEM top hat that protrudes through that hole so it is blocked unless you remove it.
04-15-2019, 11:22 AM | #5 |
Rep 77
04-15-2019, 02:35 PM | #6 | |
Rep 891
Looking at Bimmerworld's F30 build photos you can see that the top of the rear fenders are completely obstructed.
kern4174449.50 |
04-17-2019, 01:17 PM | #7 |
Rep 77
04-17-2019, 02:16 PM | #8 | |
Rep 891
04-18-2019, 06:06 AM | #10 |
Cheapskate
4450
Rep 4,993
Yeah that cap has a pin that goes in the hole for alignment if I remember correctly. It also covers the screw to prevent dust from getting in (if that's even a concern in that location). You'd have to drill a hole to get access through the trunk.
I don't think the TC Kline mounts are a good option because it's like adding a spacer to the shock. I did the opposite as Watsey. I stuck with KW, but got V1s because I knew I wouldn't have the patience to mess with dampening lol. |
10-04-2019, 09:33 PM | #11 |
Rep 77
not yet. they just arrived last week and had an appointment to install this week but my car is stuck at the dealership for some repairs and missed my appointment. I have another thread going and I will update it when the install is complete
10-05-2019, 10:44 AM | #12 |
poopycat
266
Rep 791
Is this a setup where you can run heavy duty fiber reinforced hose over the adjustment part?
I had some coilovers on an RX8 when it first came out and I ran a length through a plastic cap to the knurled adjuster. Worked great for a very long time. Oh, old but good: http://www.swankmonkey.com/mazda/rx8...djustment.html |
10-06-2019, 11:07 AM | #13 |
Rep 205
Drives: 14 F30 335i xDrive
I have KW V3 and ran into this same problem. I was able to route the extenders through in the back, but it takes a little drilling as there's no direct hole though. It's easy and is not compromised in any way. I've been meaning to put together a little DIY on it but have been too busy. I'll try to find some time to do that (with pictures) shortly.
Logicoeur992.50 |
10-06-2019, 06:43 PM | #14 | |
Rep 77
10-07-2019, 03:16 AM | #15 | |
Rep 10,256
10-07-2019, 12:06 PM | #16 | ||
Rep 205
10-07-2019, 12:12 PM | #17 |
Rep 1,934
It's a packaging problem, across the board. Their club sports allow both adjusters on the bottom. PSS10 is doubly adjustable, but with a single dial on the bottom. BC is in the same boat as KW Vx.
10-07-2019, 01:30 PM | #18 |
Rep 205
That's interesting. Sounds like it's a cost thing. Probably the valving and packaging is there to have the adjustments on the bottom as in the KW Clubsport, but that's a more costly design. So in order to hit their price point targets for their Vx coil overs and other value prices coilovers, they have a different, less costly design with the rebound up-top and bump on the bottom.
05-06-2022, 03:45 PM | #20 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
No can do. Unbolt top, pull it down an inch or two then adjust and put it back.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
05-07-2022, 01:17 PM | #21 | |
Rep 205
F3x Rear Shock Upper Adjustment Extenders DIY https://f30.bimmerpost.com/forums/sh....php?t=1659746 |
