02-26-2020, 01:07 PM | #23 | |
Rep 963
Have never used ethanol - what are some general rules to know about that? Is it fine to use with stock fuel system?
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
02-26-2020, 05:55 PM | #24 | ||
Rep 175
Pulled harder, smoothed out my timing, removed knock. Going to start doing it again.
13' 335xi PWG M-Sport 8spd - BM3, CTS Turbo FBO, H&R Sport Springs + Spacers, BMW MPE
aps335.50 TurboCanadian6.00 |
02-26-2020, 10:26 PM | #25 | |
Rep 7,606
Its fine with stock fuel system. Really the only limiting factor for a FBO car is the HPFP if you go to a relatively high Exx ratio (say, E30+) and are in cold temps (<60F). At that point you just reach the limit of what the HPFP can supply. But just mixing in a few gallons and running a 91 octane OTS stage 2 tune shouldnt put you near that limit, unless you are in very low temps (<30F). |
aps335.50 |
02-28-2020, 05:50 PM | #26 |
Rep 963
Alright - so I was able to flash the TCU and got a bunch more logs now. Stage 2 ACN 91, DSC off, Costco gas this time around.
Seems like my timing is only a little better but still pretty shit. Still getting knocks right around the time when I first smash the pedal. Not getting peak boost until ~3k which seems intentional. First 4 are 3rd gear, 4th one is 4th gear, 5th is 3rd and 4th: http://www.bootmod3.net/log?id=5e5998afd10b43119366987b http://www.bootmod3.net/log?id=5e599806d10b43119366986a http://www.bootmod3.net/log?id=5e5997c2d10b431193669867 http://www.bootmod3.net/log?id=5e59979dd10b431193669864 http://www.bootmod3.net/log?id=5e599456d10b430de1724389 http://www.bootmod3.net/log?id=5e59934ed10b430de172437d What do you guys think? Still pretty crap? On the timing issue, only thing I can think of - I did the spark plugs myself - gapped NGK 97506 to 0.022. First time I've ever done this. Could I have fucked something up that would be causing the wacky timing?
02-28-2020, 07:57 PM | #27 |
Respect My Authoritah
368
Rep 873
Are you PWG? You're not holding boost very well. Almost 5psi off target near redline in most of those logs.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
02-28-2020, 08:45 PM | #28 |
Rep 963
Yeah, that's been the case in almost all my logs PWG problems
02-29-2020, 06:29 AM | #29 |
Rep 364
02-09-2021, 09:01 PM | #30 |
Rep 119
Will there be any gains to be had by using a Dorch Stage 2 pump with this file?
Are you going to be releasing a Stage2+ E30 tune for the n55 pwg like there is for the ewg motor? |
02-10-2021, 12:06 AM | #31 | |
Rep 141
PWG n55s limitations are its turbo not fueling. Wouldn't make sense to install a stage 2 pump without a bigger turbo. |
02-10-2021, 12:45 AM | #32 |
Rep 7,606
05-02-2021, 12:53 PM | #34 |
1296
Rep 3,533
you'll need to go custom for.ypur car if.you want anything more really power wise. assuming you aren't 100% maxed out now, it varies a little car to car.
