03-09-2023, 09:37 PM | #3477 |
Rep 43
Just removed my cracked eps motor. It’s hard to disconnect the electrical part from the mechanical part(only mechanical part was cracked) even with 3 tabs open. I may just need to buy a new motor and reprogram it.
New to the cable coding. Can I get the link to download the software? Thanks! |
03-10-2023, 09:43 AM | #3478 |
Rep 6
shawnssheridan has the correct files and can get them faster to you then me right now atm.
03-11-2023, 12:07 AM | #3479 | |
Rep 43
kano007 Where did you get the rack? Do you need to do alignment also? I opened the motor/belt housing assembly today. It's really hard to tell why the steering is making noise. Only thing I could imagine is the belt itself but it looks ok. Found no where to buy the belt itself so may end up buying a used rack as well. |
03-11-2023, 08:38 AM | #3480 |
Rep 40,936
03-11-2023, 02:45 PM | #3481 | |
Rep 6
giraffewt15.00 |
03-21-2023, 05:15 AM | #3482 |
Rep 5
e-sys problem
Hello Shawn
I have an F36, E-Sys 3.30.1, E-sys launcher pro 2.8.1 and PSDZData 4.27.20. When I run a "read coding data" on a "CAFD", it displays a "report 1 errors. Would it be possible to send me the latest version of "PSDZData", please? Thanks in advance |
03-21-2023, 11:15 AM | #3483 |
Rep 40,936
PM sent.
03-22-2023, 12:54 PM | #3486 | |
Rep 40,936
For FDL Coding, E-Sys requires a 3rd Party “Mapping” application such as BimmerUtility as it Provides CAFD Mapping. BMW AG made changes to PSdZData beginning with 54.2 PSdZData where they removed (trimmed) all descriptive text from CAFD and FAFP files, making FDL Coding of ECU's difficult, as the FDL Codes can no longer be easily located. The "Mapping" application dynamically maps the trimmed data back into CAFD file making FDL Coding possible. BimmerUtility is NOT needed for VO (FA) Coding nor ECU Programming (Flashing) as these can be performed with E-Sys direct.
03-23-2023, 12:35 AM | #3487 |
Rep 6
giraffewt
Hi, Want to follow up on the EPS replacement you did because I am doing the same thing. Shawn told me I need to buy a rack older than my car otherwise if there is a FSC in the rack I won't be able to use it. What's your consideration when you bought the rack? Did you have to import FSC as well in coding? Thanks! I didn’t look up anything like that I just made sure it was rwd and nothing I didn’t have like an extra steering option. I didn’t listen to that because I had a mechanic replace it before and he didn’t say anything about that. I know that the one i purchased was newer then I expected but no problems at all. I don’t think it matters in that way you’re basically just telling the ecu this is the steering rack |
03-23-2023, 11:58 AM | #3488 | |
Rep 43
So you don't have S216 Servotronic (change steering feeling in different speed/driving mode)? Thanks for the info! |
04-24-2023, 07:47 AM | #3489 |
Rep 9
shawnsheridan in latest esys provided by you, should the transmitter tool be available or has than been depricated? Haae some seat removal airbag coding errors to clear. Cheers!
04-24-2023, 10:03 AM | #3490 |
Rep 40,936
It's not in newer E-Sys versions, but you can add it back in. PM sent.
05-02-2023, 09:14 AM | #3491 |
Rep 11
Hi shawnsheridan , I'm looking for psdzdata 3.63.3 full for downgrading my ACSM module on F60 as it throws a non-removable error code ever since I flashed it to the latest. Would you be able to help please? Thank you in advance!
05-02-2023, 10:10 AM | #3492 |
Rep 40,936
No, old versions not maintained. I have always only the latest version.
05-31-2023, 05:19 AM | #3493 |
Rep 2
Hi shawnsheridan, can you help me with what cable I need and latest E-Sys versions. It's my first time coding. I have a 2013 F34 and am adding paddle shifters.
Thanks for answering |
05-31-2023, 05:40 PM | #3494 |
Rep 40,936
Any~$20 USD ENET Cable off Amazon should work fine. PM sent.
06-06-2023, 09:45 PM | #3496 |
Rep 40,936
PM sent.
06-18-2023, 06:11 PM | #3498 |
Rep 40,936
PM sent.
