09-21-2021, 04:45 PM | #45 | ||||
Rep 36
I did exactly this. Walked into my garage on a cold start, unplugged my MAF sensor, and started the car up with it unplugged. After continually doing that "stall then catch itself" for a week straight it actually started up perfectly fine and idled great! What does this mean now? I'm going to let the car idle like the other guy said for a little and then turn it off. Once turned off I'll plug the MAF back in. I guess my new question is… What's broken? What needs replacing? Maybe nothing and once I start it tomorrow it will be back to normal again? All I know is that unplugging and MAF and starting the car with it unplugged cured my issue. |
09-21-2021, 04:54 PM | #46 | |
Rep 7,600
IIRC you said reflashing also made the problem go away temporarily. If the above doesn't work, you can try resetting adaptations without a reflash and see if that makes it go away as well. If you havent already, you can try cleaning the MAF also. I think replacing the MAF would be the last resort. |
09-22-2021, 11:28 AM | #47 | ||||
Rep 36
Appreciate all the help on solving this issue. Considering 2 shops + BMW suggested fuel pump work after observing the cold start bog… spending $160 on a new MAF (if the issue actually comes back) is a real win. Lucky enough to live 30 minutes from FCP Euro as well. Will update in the future if anything else arises. Thanks again all - Austin |
jcordier160.50 |
10-03-2021, 02:04 PM | #48 |
Rep 9
Just thought I would add to this again as there seems to be varying resloutions to this issue. After running 2 treatments of TECHRON and switching to SHELL V-Power fuel it only did it once after that. I am not sure if it cleaned up the injector or the pump or both but it was 99% gone vs every single morning.
After tuning to BM3 Stage 2 it has not done it a single time in months. I did however turn off the coldstart warm up as it is a little to loud for when i go to work at 4 a.m. I did not want to be that guy. Not sure if that fixes it I will turn it back on here in the future and see if it comes back. I will run it for a week or two like that and try to remeber to post and see if it returns. Glad we have made some headway on this frustriting issue!
2015 F30 335i Sportline| VRSF Chargepipe | BMS CAI(HAI)|BMS Intercooler | VRSF High Flow Downpipe | Borla S Type exhaust | BM3 Stage 2 91octane| 19" Black Replica 437M wheels
10-20-2021, 01:27 PM | #49 | |
Rep 2,639
11-28-2021, 06:06 AM | #50 | |
Rep 474
To my engine and it cold starts perfectly again. If you haven't solved it. I'd give this a try.
J. D. Cordier
11-29-2021, 02:38 PM | #51 | |
Rep 7,600
jcordier160.50 |
11-29-2021, 02:53 PM | #52 | ||
Rep 474
J. D. Cordier
09-27-2023, 06:51 AM | #53 | |
Rep 28
