11-17-2021, 09:18 AM | #23 | |
Rep 190,777
Chinese factories and/or US brands tend to copy successful designs. That's why you end up with similar-looking intercoolers. Just because two intercoolers look similar does not mean they will perform the same; you still need to check the core density, design, material, weight, fitment, and wields quality.
11-17-2021, 10:41 AM | #24 |
Rep 125
I saw a log from the guy using the G Plus 5" stepped IC. At 85 ambient his WOT 5 gear pull IAT's went from 98F to 110F which is consistent with my results using the BMS 5" IC. I think max boost was 19 psi in that log.
My sole purpose here is to add facts when they are relevant. Having recently purchased the BMS for about $100 more than the G Plus, I was curious like everyone else. |
sspade2464.50 |
11-17-2021, 11:35 AM | #25 | |
Rep 7,606
11-17-2021, 12:34 PM | #26 |
Rep 706
11-17-2021, 12:50 PM | #27 |
Rep 4,913
No need to worry about eBay quality we have you covered
11-17-2021, 01:01 PM | #28 |
Rep 7,606
MHD state 2+ is the highest map with stock fuel system (IC+DP upgrade required)
BM3 stage 2 is basically MHD stage 2+ equivalent. BM3 stage 2+ requires HPFP upgrade in addition to IC+DP. These are all stock turbo maps. From everything i have seen (and having owned a 5'' and now race) i would say a 5'' stepped IC is fine for a casual driver that is FBO+tune, but if you are going to drive aggressively (long WOT pulls, repeated pulls without cooldown in between, or certainly autoX/track/etc) and/or if you are going to be pushing into the upper teens in boost, you want bigger. With the new options on the market and the relatively small price difference between 5'' and larger ICs it really just makes sense to get the bigger one to begin with unless you KNOW you don't need it. |
n55david1295.50 |
