11-26-2021, 12:21 PM | #1 |
Rep 166
F34 subwoofer 1 to 1 replacement
Hey all,
Hoping someone has experience replacing the subwoofers under the seats in a F34? Here in Denmark the F34 is sold in three different audio setups which means you have the base stereo, the hifi system and the H/K system. Now in my case i got my F34 used and had to come to terms with having the s***ty base stereo system which only comes with the 6,5" subwoofers under the seats. I was looking at the Match MW- 8BMW-D as direct replacements as i'm installing the Alpine BMW hifi kit sometime next week. Can anyone recommend anything else for upgrading the subs? or is the Match units worth the 350$ ? |
11-26-2021, 03:50 PM | #3 |
Rep 166
11-26-2021, 05:09 PM | #4 |
Rep 16,061
This is of interest to you:
https://f30.bimmerpost.com/forums/sh....php?t=1878554 |
11-26-2021, 08:15 PM | #5 | |
Rep 5,392
Note: The basic audio system has 6.5" underseat subwoofers but they should be installed in the same sub boxes that hold the 8" subs. So the Earthquake SWS-8Xi 8" subs fit right in. Make sure to install them with the Earthquake 8" spacer rings, $25/pair. Some early subwoofers are glued into cabinets at the factory. One trick is to remove the entire cabinet and place it in the freezer for maybe an hour. Then use a plastic trim tool or plastic putty knife to work around the stock subwoofer and pop it out |
DavidSTryk23.00 |
11-27-2021, 05:54 PM | #6 |
Rep 2,180
You are recommending an amp that is not compatible with the OP OEM system.
11-27-2021, 06:00 PM | #7 | |
Rep 2,180
