08-06-2020, 11:19 PM | #1 |
Rep 125
Another F31 Suspension Thread
There are 2-3 threads on suspension setups for F31s, but they didn't answer these questions of mine below. My F31 does have EDC.
If I go with springs on a car with adaptive suspension: Is H&R the only manufacturer that makes an F31 variant? Do I need bumpstops? Do I need Bilstein shocks? If yes, why and what is the difference between B6 and B8? Do I need to do anything with EDC? These are pretty noobish questions, looking to learn. |
08-07-2020, 04:57 AM | #2 | |
NewFinishColumbia/detailer
604
Rep 2,096
Maybe. Depending on how much Tavel you have after you lower. Using F80 bumps stops is a way to get shorter ones. Stock shocks will work depending on the drop from the springs. Look into shockware from DINAN. There are other options besides Bilstein. B6/standard height-B8/lowered on springs is the difference. You can code EDC off pretty easily if you go with a non-EDC variant for shocks or coil overs.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
08-07-2020, 01:09 PM | #3 | |
Rep 125
1. is EDC dependent on the types of shocks/coilovers only, not so much the springs? i.e. if i go with springs + shockware, i can leave EDC as is? |
08-07-2020, 03:42 PM | #4 | |
Rep 90
Drives: 2016 F31 Msport/Track handling
But then again, I know KW sells a HAS ( height adjustable spring ) kit for M4's that keeps the stock EDC shocks and to my knowledge does noting to the coding of the stock EDC control unit. Maybe we are over thinking what the EDC system does in each application, or how sensitive it really is to changes in ride height and spring rates, especially on 3/4 series vehicles. I didn't really care much for my EDC on the wagon, so I had it coded out when I moved to the KW's. It's not my daily so I've pretty much gotten used to not having a "comfort" setting.
2018 S213 AMG E63S Estate: Diamond White - Money-pit/Garage Queen
2004 CL9 Acura TSX 6-speed: Satin Silver - Peak JDM 2018 BEV2 Chevy Bolt: Nightfall Gray - Daily driver Last edited by hon2bmw; 08-07-2020 at 04:42 PM.. |
08-07-2020, 05:08 PM | #5 |
Rep 1,425
This has been shared/discussed before, but KW has a coilover range called DDC that is plug-and-play directly to the vehicle's EDC system. So, just like the factory EDC rocker, you can change the driving dynamics/dampers on the fly. I have them for my F31, and have been very pleased. They are one of the more expensive options, however (~$3,000 USD).
Here is a link to the product: https://www.kwsuspensions.net/products/coilovers/ddc
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
11-26-2022, 01:58 AM | #6 |
Rep 44
Hi there, firstly, I’m in the UK. How did you get on?
Research & find a decent BMW dealership & request a quote which includes parts breakdown… I did & that gave me all the parts ;-) You can also use https://www.realoem.com/bmw/enUS/select to research your parts / other items; but be warned, it’s not always accurate; especially if you have factory upgrades! I have a 2014 F31 320d Touring rwd with Adaptive M chassis (Drive modes, Eco, Comfort, Sport, Sport+) I absolutely love the stock config & ride; but at 155k miles, my front struts, springs, mounts need replacing! If it helps; I contacted Monroe who inform me that yes; they manufacture the BMW OE & they only supply to BMW Dealerships as BMW have exclusivity; they wouldn’t supply to me as an Indy directly. I have searched high & wide for other options; be warned & steer clear of eBay “from Hong Kong / China” & I certainly wouldn’t entertain second hand! I searched for a shock refurbish service centre; there are a few in the UK; but that’s not possible for me as all I’ve enquired with want the shocks off the car & sent to them. So, other than a complete change to Bilstein or other (quite expensive; but if you can afford, go for it!), the BMW dealership price is very competitive at just over Ł1k for both fronts with mounts & all fixings & inclusive of VAT & labour. |
11-29-2022, 04:09 PM | #7 | |
Rep 785
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
