11-15-2018, 02:47 PM | #1 |
Rep 54
Fellow California F3x drivers, what do you run?
So being limited to 91 Octane is a bummer here in California, I could drive ~20 miles to a station that sells 100octane and mix with 91, but its not worth the hassle every time I need to fill up.
I drive a 2015 435i This is the reason i'm running the BMS Stage 1. I also have the BMS intake and have a AWE Touring axle-back on the way since i was disappointed with the MPE. (my e92's MPE was 3x louder, hence my disappointment) I was curious to what others here or elsewhere limited to 91 at the pump run on their cars? Is a catless DP worth it if i cant run stage 2 because of gas restrictions? Last edited by Trap35i; 11-15-2018 at 02:55 PM.. |
11-15-2018, 05:06 PM | #2 |
Rep 1,827
If you're looking for a flash tuned stage 2, just get a map for 91 and you'll be fine.
91AKI isn't the best, but it won't cause any problems if your tune is mapped for it. I run Shell or Chevron 91 a vast majority of the time with my stage 2 tune (mapped for 91AKI). Occasionally, I'll swap to my E30 map and fill up with about 4 gals of E85. Car seems to run smoother and I get a noticeably harder kick in the pants. But for day to day driving, 91 is good enough for me, especially since E30 drops my mileage a bit.
11-15-2018, 05:16 PM | #3 | |
Rep 54
11-15-2018, 05:27 PM | #4 | ||
Rep 1,827
11-15-2018, 11:49 PM | #5 |
Rep 54
Have you dyno'd it? What kind of numbers do you pull with your set up?
11-16-2018, 12:38 AM | #7 |
Rep 5,776
Yeah, I'm with you on that--have not seen (from watching IAT) a huge need to upgrade the IC. I run 91 Oct and e85 with stage 2+ 91 oct e30 map.
11-16-2018, 09:58 AM | #8 |
Rep 1,499
When I lived in LA I ran the E30 map fairly consistently
11-17-2018, 10:33 AM | #11 |
Rep 160
Throw in 2.7 ounces of boostane professional with every fill up = approximately 94 octane. It ends up costing a about $2.50 a fill up to rid yourself of shitty 91 octane gas.
11-21-2018, 01:15 AM | #12 |
Rep 310
i run 5 gal of E85 with my Cali 91 octane, FBO on BM3 Stage 2
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current |
11-29-2018, 04:35 AM | #13 |
Rep 716
Drives: F90 M5
Im in LA with a FBO m235i on bm3 91oct stage 2 ots and love it haha
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
11-29-2018, 06:27 AM | #14 | |
Rep 232
I have an F30 N55 EWG Stage 2 91 octane BM3 with FBO. Are you saying all I would need to safely run a few gallons of E85 to a full tank of 91 octane is an E30 map??? It can't be that easy! I don't need any supporting mods for fuel (HPFP, LPFP, upgraded injectors, etc...)? Is that right? So I have a hi-flo catted downpipe, fmic, charge pipes, intake, and a BM3 tune. Would I need anything else to run an E30 map fairly safely? |
11-29-2018, 07:22 AM | #15 | ||
Rep 1,827
11-29-2018, 07:49 AM | #16 | |
Rep 1,499
That is correct. You don't need anything else. I generally run 4 gals of E85 with 12 gals of 93 octane, a calculated E29 mix (when in Cali I was topping off with 91 octane obviously) with no other supporting mods with no issues. The main issue you might run into is a dip in fuel pressure if the HPFP can't keep up due to too much E85. I'm EGW, FBO + bm3. Make sure to get a test kit and test the ethanol content before adding to your tank though.
https://www.fuel-it.com/pro-series-ethanol-test-kit/ http://www.georgebelton.com/E85Calculator.php Quote:
Tags |
bmw, california, f32, stage 1 |
