10-26-2021, 11:49 AM | #199 | |
Rep 7,606
12-06-2021, 03:31 PM | #209 |
Rep 7,606
Uh what? You first need to confirm your local requirements to figure out how many monitors can be not ready (if any). Then from there figure out your solution. The easiest thing may be to just swap back in the OEM DP. You may or not may need to remove BM3, which you can easily do yourself, depending on your state/local requirements.
01-06-2022, 02:35 PM | #211 |
Rep 11
Drives: F30.335Xdrive
Hello guys, looking for the pdf file too. Please help.
01-10-2022, 11:39 PM | #212 |
Rep 6
I would love the pdf as well!
2013 335i Alpine White 88k miles and going!
bm3 stage 1, jb4 (map 0), ER Downpipe, M Performance Exhaust, ER chargepipe, bms intake, Fuel-it Stage 2 LPFP, HR Sport Springs, 19" Morr FS77 M Performance Alcantara Steering Wheel |
03-15-2022, 06:48 PM | #216 |
Rep 103
I'm posting on someone's else's behalf, of course.
I personally abide by all laws, rules and regulations. While this might not work for all. Those living in states that allow for 1 "not ready" sensor, it should. Unnamed person has a 340i with a B58, catless DP and BM3 tune. To pass IL emissions, person flashed the stock tune and left all settings at OEM, then in the DTC Deactivation area, entered the codes as pictured. Performed a drive cycle on the way to work and then again on the way to the emissions station. ODBII Scan tool was used prior to testing to confirm system was ready as it was gonna get. This resulted in a PASS with no CEL or codes thrown. Hope this helps some people that don't want to crawl under their car to reinstall their OEM DP just for emissions.
2016 340i M-sport 6MT Alpine White
M Perf LSD - VRSF catless DP - BMS intake - Dorch Stage 2 HPFP - BM3 Stage 2+ MultiMap - Bilstein PSS10 B16s 550i clutch upgrade - OEM 437s PC'd - M Perf BBK - Megan Racing Rear Trailing Arms - VAC Monoball Control Arms |
Bloom_435i23.50 the_blesss15.00 |
04-26-2022, 12:19 PM | #217 |
Rep 4
Inspection "Readiness" on custom flash possible?
I have a 2017 440i with an aftermarket catted (high flow) DP and Bootmod3. My mechanic says that there are no fault codes, but it says it is 'not ready'.
Inspection time is coming up.... I found this guide on how to do a drive cycle. Hope this will help. https://www.instructables.com/How-to...or-Smog-Check/ However, is it possilble to do a drive cycle and get it into a readiness state without flashing back to the stock map? (I had some problem getting the stock map loaded last time I tried). |
04-26-2022, 12:33 PM | #218 | |
Rep 7,606
04-26-2022, 12:42 PM | #219 | |
Rep 146
You didn’t specify which catted DP you have, as some of them will throw a CEL once you turn that option off in BM3, while some will not. |
04-26-2022, 12:48 PM | #220 | |
Rep 7,606
